Old 11-22-2008, 12:41 PM   #751
Originally Posted by GMS_Racing View Post
My 2.0 is my first 8ight and my first nitro 1/8 so im asking for some help. After a gallon and a 1/2 i ate up the clutch...what do you guys recommended replacing it with?? keep the losi clutch and just replace the shoes, or replace the entire thing?? thanks for your help
Well a gallon and a 1/2 sounds right for the stock clutch for wear. Personally I never liked the stock Losi shoes. If you want shoes that will last longer try the King Headz 7075 shoes, or the Dynamite MaxLife, or the Losi longwear shoes, or the M2C shoes. I have used all of them except the M2C, but heard the M2C were great shoes as far as wear and performance.
Losi-Runner is offline   Reply With Quote
Old 11-22-2008, 03:18 PM   #752
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
Thanks for the info guy..went with the dynamite maxlife w/ gold and silver springs. Replaced the bearings too they were close to going too. I used the losi ones..do the ceramic bearing get better life?
GMS_Racing is offline   Reply With Quote
Old 11-22-2008, 03:39 PM   #753
cornerspeed's Avatar
The Losi clutch bell bearings are very good. Ceramics may be just as good, maybe, but more expensive.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 11-22-2008, 04:21 PM   #754
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
i just dont like the origional wing
i used my origional wing for ages but it did crack down through all the supports very quickly
the supports on the rc8 are alot thicker and their plastic has alot more flex in it
we have some massive jumps here and i rearly land on my wing. but when i do its a big landing
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
Old 11-23-2008, 09:30 AM   #755
Integra's Avatar
little mod i did to my 1.0 chassy's
Old 11-23-2008, 09:37 AM   #756
The silver springs are going to cause premature wear because they are a bit too stiff for buggy. Try 4 gold rather than 2 gold 2 silver.
mbrienzo is offline   Reply With Quote
Old 11-23-2008, 12:10 PM   #757
baruke1's Avatar
Trader Rating: 17 (95%+)
Integra, did you anodize your quick change engine mount black?
baruke1 is offline   Reply With Quote
Old 11-23-2008, 12:56 PM   #758
CaLaBeR's Avatar
Nope that is a Kings Headz motor mount i believe...
CaLaBeR is offline   Reply With Quote
Old 11-23-2008, 02:40 PM   #759
I've run my 2.0 for 3 weekends now and am pretty happy with it, especially thru our tracks rythum section.
One thing I have noticed is that the rear end is loose compared to my 1.0. I am running Truhe's setup which includes 5/7/2 for diffs, 40wt/25wt for for shock fluid and the stock tires that came with the roller (I run Bowties on the 1.0). Our local track is pretty dusty and loose. Am I noticing the difference in the tires? What other suspension settings could I use to plant the rear end?
CJKinney is offline   Reply With Quote
Old 11-23-2008, 02:57 PM   #760
Integra's Avatar
your feelin the tires imo.
Old 11-23-2008, 02:57 PM   #761
GMS_Racing's Avatar
I went to 30wt oil in the rear cause mine kept pogo sticking on short jumps..seemed to settle down the back end all together too
Old 11-23-2008, 02:58 PM   #762
Integra's Avatar
as Calaber stated....its a KH mount....makes it a little more challenging to get the mesh 100% along with the etched lines....but it still does the trick...i got rid of my Losi quick mount real fast as i found it to Stick alot and make it a pain to remove the motor.
Old 11-23-2008, 05:56 PM   #763
nazprerunner's Avatar
Trader Rating: 20 (100%+)
I'm buying the new 2.0 and selling 8 but what from the old car is still usable on the new car shock/ diffs drive shafts?
nazprerunner is offline   Reply With Quote
Old 11-23-2008, 08:31 PM   #764
Integra's Avatar
same diffs same drive shafts but the 2.0's will be a little thicker and with a harder steel pin supposedly.......most of the plastics...minus the steering rack and rear diff case.
Old 11-23-2008, 09:04 PM   #765
My bet is the tire as well. I'll swap them next weekend and see (if the weather holds). I may try 30wt in the rear as well, ran it in the 1.0 and liked it.
So, is the 2.0 shimmable rear diff done by a change in the case, the plastic bearing housings or in a change in the gear machining?
BCE speed Losi 8ight 2.0 3mm chassis xxxtcr Nitro Off-Road 355 12-17-2012 12:05 PM
Adam Drake talks about the new 8ight 2.0 Sylvain Nitro Off-Road 545 05-30-2010 06:57 PM
losi 8ight & losi 8ight 2.0 figure8racing21 Nitro Off-Road 7 03-05-2009 01:41 PM
