RB .21 s3 fuel question
I have a question about what fuel brand and nitro % to run with a new RB s3
l2g .21 engine. the manual says 15%-25% is recommended but im just wondering what everyone is running. also what plug is everyone running, the motor came with a 6 and just wondering if people are runnning OS's, odonnel's, ect.... any info greatly appreciated...thanks Mike Williams
I am running 30% Sidewinder in mine and it runs great.
Hello,
Werks 30% is the best fuel I have ever run with my RB engines. It clears out well and runs cooler. A good combo would be the Odonnell ODO99 plug, with Werks 30%. If its modified run the ODO97 or hot plug.
Put the RB S5 or S7 crank in your S3, port it, and run a turbo head. I call that the RB Speed... LOL!
I didn't add the shim
I run 25% Byrons in all my RB's & have for a while. The motors are clean on the inside when I inspect them & they run cool & hold up for a long time.
Sorry if this is off topic, but how is your Mach 427 engine running Mike? Did it last long? It looks like a good engine for truggy, and it's super cheap.
Thanks!
Thanks!
you need to add the shim or it will add to premature plug failure
chrobar, the 427 is a great motor. has a smooth power band and pretty good on fuel and great on the pocket book. it has about 4 gallons and good compression and good pinch.
jamminary, i took out 1 .1mm shim and added a .17mm shim in its place. thanks for the info.
jamminary, i took out 1 .1mm shim and added a .17mm shim in its place. thanks for the info.[/QUOTE]
i love my rb motors!!! they are so reliable and run excellent!
well, i love it. runs great and it's not completely tuned yet. how do i determine it the (lsn)idle/air is to fat. it seems a little loaded when i give it gas, but seems good every were else. 240-250 f all day and i got about alittle more than 6 min on a tank...i'm wondering if i need the RB pipe. i have a dynamine 086 pipe. just wondering.
