how to eliminate understeering on my buggy(hyper7)?
hey guys can you give me some tips or set up for the hyper7 buggy?how can i eliminate understeering from that buggy?my current diff oil using in my diffs are 5k front,7k center and 3k rear..should i change my diff oils and c-hubs(20 degrees)into a 22 degrees hubs?
0.o I usually go for either lighter in the front or rear on the diff oil (depending on what it's doing) Also you can move your shocks around. but ive never had a hyper and ive never ran without a front sway bar.
R/C Tech Elite Member
Try 5-7-1 in your diff oils and run with out the front sway bar and the biggest sway bar you can get on the back that is how i run my Hyper 7 and i run in the top 3 all the time at my club races with buggys like the 808 and 777 and jammin x1 the guys just hate getting out run by a Hyper 7.
