HAS ANYBODY USED BLUE CHROME TOP ON 8T >
Old 07-02-2008, 05:03 PM
Trader Rating: 42 (92%+)
Default HAS ANYBODY USED BLUE CHROME TOP ON 8T
DOES THE NEWER MODELS FOR OFNA CHROME TOP WORK FOR 8T
I HAVE ONE BUT CANT SEEM TO GET IT LINED UP RIGHT
icemandolmite is offline
Old 07-02-2008, 05:57 PM
soccerlaw's Avatar
Trader Rating: 24 (100%+)
I tried forever and couldn't get it lined up. The best I could do was to sand down the wheel as shown on the Losi website (http://www.losi.com/Products/Support...rodID=LOSK0800) and use one of the nevermiss plates available on ebay. Ended up just getting the ofna truggy box though as it lines up virtually straight out of the box with only minor adjustment (actually got the losi box first but the motors burnt out on the 4th attempt to turn over new engine so it's current on its way to Horizon to get fixed).
soccerlaw is offline
Old 07-02-2008, 08:04 PM
glassdoctor's Avatar
I use one for my 8ightT.
I did some grinding on the adjustment slots to get the pins in the right spot. In fact, I think I actually marked the spot and drilled a hole for two of the pins.
I did sand down the wheel a bit, and beveled it. I used a dremel sanding drum, spinning in the opposite direction of the starter box wheel.
I haven't run it since last summer so it's starting to fade from memory
glassdoctor is offline
