Inferno MP9 thread >
Inferno MP9 thread
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 07-02-2013, 03:02 PM
  #14791
Trader Rating: 22 (100%+)
Well it is now freed up. But there is a ticking noise coming from the car as it rolls. Everything is free but it's making a noise now. Toy cars can really get to you!
CBeeler46 is offline
Old 07-02-2013, 04:30 PM
  #14792
Tony Marks's Avatar
If you can't find what is doing it visually, it's most likely in the diffs. Again, with run time it will wear in and they will mesh to each other. And yes, yes they can. lol
Tony Marks is offline
Old 07-02-2013, 07:22 PM
  #14793
kman16jr's Avatar
Trader Rating: 56 (100%+)
Originally Posted by GMS_Racing View Post
Hey you cant post on here until you have one Kevin.
LOL matt you caught me!
kman16jr is offline
Old 07-02-2013, 07:25 PM
  #14794
Guest
U might think I am nuts but look at the center diff an drive shafts and break disks. I bet that is what our hearing.
kyoshoracer77 is offline
Old 07-02-2013, 09:00 PM
  #14795
Hello, I need some help!!
The mp9 tki3 come with this piece?? : 2mm Offset Kyosho Aluminum Rear Hub Carrier Set (Gunmetal)
[KYOIFW414]
Now comes with this piece, I need to change for this piece?? : Kyosho 93mm HD Rear Universal Swing Shaft Set (2) (TKI3)
[KYOIFW425]
I appreciate the help!!
Victor hugo is offline
Old 07-02-2013, 09:33 PM
  #14796
rfleck's Avatar
Trader Rating: 58 (100%+)
Center diff cups touching brake pads is most likely the case.
rfleck is offline
Old 07-02-2013, 09:37 PM
  #14797
juninho_foz's Avatar
[KYOIFW414]
[KYOIFW425]
cara , a peça KYOIFW425 , se usa mais na frente,por precausao ok? atraz nao tem necessidade.
juninho_foz is offline
Old 07-02-2013, 09:42 PM
  #14798
Guest
[KYOIFW414]
[KYOIFW425]
No. Just use the 91mm .. on the nitro I have never popped the 91mm out. Now some people have in the front and then use the 93.
Old 07-02-2013, 10:55 PM
  #14799
Are Kyosho MP9's really worth the extra money ?
The kit price is more expensive than any other buggy....but does this really mean better quality ?
BuggyTalk.com is offline
Old 07-02-2013, 11:05 PM
  #14800
LosiPRRACER's Avatar
8 World championships -
In all seriousness, please look at it like this aswell, Compare what other cars come with... the TKI3 comes with Alloy rear hubs, alloy front upper plate, alloy upper centre plate and quite literly the best diffs and defently the best drive train.
The tki3, comes with THE BEST out of the box best drivability - This is why even pros dont change much from standerd setup - how many "things" have mugen already alterd just to keep up. losi already drilling more holes and altering.
Kanai built the Mp9 platform in the words of - Build it once, build it right.
and the Tki3 is just to make the best car... better.
Anybody with any brains would buy a MP9 TKI3 and be done with all the other brand "problems and issues"
and just to sum it up... theres a reason other brands are using genuine kyosho performance parts to increase performance and durability........
LosiPRRACER is offline
Old 07-02-2013, 11:17 PM
  #14801
toyoter91's Avatar
Trader Rating: 47 (100%+)
I have broke more parts on my TKi3 in two weeks than I did on my RC8 in a year and a half... I wouldn't call it a durable 8th scale. Its probably one of the more fragile ones actually, at least as far as front arms are concerned. There are a few other rather lame things about the platform / kit in general but nothing too bad.
It is, however, a very very good race car and I am glad I jumped ship.
toyoter91 is offline
Old 07-02-2013, 11:19 PM
  #14802
boil them... then good luck breaking them.
Old 07-02-2013, 11:25 PM
  #14803
toyoter91's Avatar
What is the process on that actually? I have been meaning to look it up, even prior to me running the car
Old 07-02-2013, 11:38 PM
  #14804
all i did was get a decent size pot of water on the stove top. turn heat to half put the parts in(i did every part i thought i should) let her slowly boil away for 20-30mins, make sure you stir them every 5 mins and turn them around within the water not letting them come out. then turn heat off and move pot... keeping parts in the water untill cool
i havnt broken anything in 2 full race days and one practice session. i've had some pretty big impacts...
The idea behind this is when nylon is heated within water the nylon takes on water particles... softening the plastic.. making them a bit more flexable... the a-arm being so stiff is anther reason why this car performs so well.
Old 07-03-2013, 12:13 AM
  #14805
Guest
Where are then pics of tebo's buggy at. Someone tell u to change them????
