Inferno MP9 thread >
Inferno MP9 thread
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-30-2013, 08:43 AM
  #14761
Originally Posted by toyoter91 View Post
Looks more like an entire OS engine with an Orion cooling head on it
Yeah i thought case looked different also so it make sense he didn't want pics of buggy with body off. Im sure Orion wouldnt like him running another motor. The Orion motors are junk i had 2 of them nightmare to tune and dont last very long.
evolution03 is offline
Old 06-30-2013, 09:35 AM
  #14762
banana rt's Avatar
plastic question here guys
any tips for making wing mount more durable?
when u guys usually replace the bulkhead?
banana rt is offline
Old 06-30-2013, 01:41 PM
  #14763
jzemaxx's Avatar
Originally Posted by evolution03 View Post
I just looked at the pics on live rc and there were a few of his buggy with the body off. The pics werent real close up. The only thing i could see was an O.S. carb on his orion motor. It also looked like he had the older rear hubs on it that didnt have the offset. Those were the only things i could tell. So who knows why
I checked his buggy out.....pretty much box stock TKI3. The hubs appeared to be stock as well. Car was flying....lapped the whole field. He had the fastest lap in both truggy and buggy.
jzemaxx is offline
Old 06-30-2013, 03:49 PM
  #14764
teeforb's Avatar
Trader Rating: 94 (100%+)
Are the alum hubs a necessity? If so, what degree?
teeforb is offline
Old 06-30-2013, 03:55 PM
  #14765
hookem34's Avatar
Trader Rating: 17 (100%+)
Originally Posted by LosiPRRACER View Post
I wonder what RX pack he is running. Doesn't look like he is doing balance charge.
Question: are the rear hubs included with the kit 2mm wider or narrower than "standard" mp9 hubs?
hookem34 is offline
Old 06-30-2013, 06:31 PM
  #14766
teeforb's Avatar
I want to order the alum hubs today. Which have better results. The 16 deg or the std alum front c hubs?
If anyone has one i can buy, let me know.
Thx
teeforb is offline
Old 06-30-2013, 07:07 PM
  #14767
Tony Marks's Avatar
Doesn't need to be balanced every time. Saves the trouble of taking it out every time if you want to just pump some extra juice in quickly before the main.
Tony Marks is offline
Old 06-30-2013, 08:19 PM
  #14768
i dont believe the hubs are wider or narrower. The rear hubs that come with the new kits are swept 2mm toward the rear. The ones that came with mp9 were not. Look at where the bearings are inserted on tebos rear hubs they are more underneath where the rear camber link attaches. Someone correct me if im wrong.
Old 06-30-2013, 08:21 PM
  #14769
The stock hexes on the rear that come with the tki3 kits and the tki2 are narrower than the ones on the front.
Old 06-30-2013, 09:18 PM
  #14770
Trader Rating: 25 (100%+)
Thx
I don't think anyone is using the 16deg ones so my advice would be to get the 13deg ones and you should be good. Maybe Sean could chime in?
smelly62 is offline
Old 07-01-2013, 12:33 AM
  #14771
teeforb's Avatar
Ok
teeforb is offline
Old 07-01-2013, 02:27 AM
  #14772
Drift_Buggy's Avatar
Trader Rating: 22 (100%+)
Originally Posted by eper View Post
you could run a shim there but the only time i thought i had to i ended up havind a bad carrier bearing on the output shaft of the diff. i would recomend going through both those first. my bearing looked and worked fine but if you put a side load on the inner race it would slide over about 3mm and then the diff would be able to move side to side. so be sure to really go through them
Thanks for the reply, hopefully tomorrow I will get a chance to quick over the whole assembly.
Drift_Buggy is offline
Old 07-01-2013, 02:35 AM
  #14773
toyoter91's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Eivind E View Post
Well, makes sense doesn't it, who wants to suffer one of those Orion engines
Funny you guys say that. They have been great for me, but I don't run my stuff on the ragged edge. I have been running Orion engines for about a year and a half and have had great luck with them I will admit that I am in the minority with that though. Most people seem to have bad luck with them.
Got 9 or 10 gallons out of my first one that I ran last year.
toyoter91 is offline
Old 07-01-2013, 11:05 AM
  #14774
lewis4x4's Avatar
I never said he was rude. It just got my wheels to turning about him not letting him take pics with body off. He was nice to my friend. I also thought it was weird because my friend runs a tki3 and stared at it and couldnt tell any difference. Im thinking new parts but what ? If he looked at it close and couldnt tell.
I looked at Tebo's buggy several times and I know he took the lid off for many people. He is not running anything that you or I can't get. He is very quite and reserved but is truly a great person and mort important, not a fake...
lewis4x4 is offline
Old 07-01-2013, 11:12 AM
  #14775
I fully agree... I raced with him when I lived in the Midwest. Very cool and collected. He is a kind and laid back person.
Ben Burtle is offline
