Inferno MP9 thread >
Inferno MP9 thread
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-29-2013, 05:57 AM
  #14746
Winner's Circle's Avatar
Originally Posted by tmth3 View Post
anyone else notice on cody king's nats pic of his buggy that he has two steel shock standoffs in the front and two lightweight alum ones in the back? wonder why?
Good eye!
I didn't notice but I'll bet it is because maybe he had a problem with the front ones due to the front taking a bigger beating that the rear.
Lee
Winner's Circle is offline
Old 06-29-2013, 06:05 AM
  #14747
hookem34's Avatar
Trader Rating: 17 (100%+)
The track was brutal on cars, particularly front ends. Probably just a precaution on his part. I run steel on my practice cars for this reason.
hookem34 is offline
Old 06-29-2013, 07:02 PM
  #14748
Originally Posted by CoryD View Post
Could have just been that Tebo was in one of his moods...
I never said he was rude. It just got my wheels to turning about him not letting him take pics with body off. He was nice to my friend. I also thought it was weird because my friend runs a tki3 and stared at it and couldnt tell any difference. Im thinking new parts but what ? If he looked at it close and couldnt tell.
evolution03 is offline
Old 06-29-2013, 07:29 PM
  #14749
Could have been as simple as he might have been running something that didn't correspond to his sponsors, for example a different brand servo due to a failure or whatever, you never know.
Eivind E is offline
Old 06-29-2013, 07:36 PM
  #14750
hookem34's Avatar
Or he is running the new parts for the upcoming MP11......
hookem34 is offline
Old 06-29-2013, 09:09 PM
  #14751
305M3's Avatar
Trader Rating: 40 (100%+)
Whatever he was running, it helped him TQ and win Buggy and place 2nd in Truck at AMS this weekend.
Great runs by all the Kyosho drivers...
305M3 is offline
Old 06-29-2013, 10:27 PM
  #14752
I just looked at the pics on live rc and there were a few of his buggy with the body off. The pics werent real close up. The only thing i could see was an O.S. carb on his orion motor. It also looked like he had the older rear hubs on it that didnt have the offset. Those were the only things i could tell. So who knows why
Old 06-30-2013, 12:16 AM
  #14753
toyoter91's Avatar
Trader Rating: 47 (100%+)
Looks more like an entire OS engine with an Orion cooling head on it
toyoter91 is offline
Old 06-30-2013, 12:56 AM
  #14754
simon0721's Avatar
Yes, Tebo's engine was an LRP ZZ.21C (same as O.S. xzb speed) with the orion cooling head on it. Also the muffler isn't the classic orion, but it seems the O.S. T2090SC.
simon0721 is offline
Old 06-30-2013, 01:05 AM
  #14755
LosiPRRACER's Avatar
LosiPRRACER is offline
Old 06-30-2013, 01:12 AM
  #14756
Old 06-30-2013, 01:19 AM
  #14757
simon0721's Avatar
Originally Posted by LosiPRRACER View Post
Yes, that is what I was talking about. Thanks for the pictures.
Old 06-30-2013, 03:34 AM
  #14758
Drift_Buggy's Avatar
Trader Rating: 22 (100%+)
I have any issue at the moment with my MP9. When using it on its 3rd time out since new I noticed a whining noise starting to happen, checked over, couldn't make out what it was and then not to long later it become much worse. After checking it again I think the noise was coming from the rear diff. I grabbed the centre shaft and noticed that was movement to and from. When I pulled the back end off the buggy and could see underneath the diff case I notice the bevel gear moving around a lot which is what seems to be making the noise as when the bevel gear was pulled against the bearing (further towards centre of buggy) it seems to be making the nosie. Does anyone else require to shim the bevel gear to stop movement?
Drift_Buggy is offline
Old 06-30-2013, 05:48 AM
  #14759
Well, makes sense doesn't it, who wants to suffer one of those Orion engines
Eivind E is offline
Old 06-30-2013, 07:08 AM
  #14760
eper's Avatar
Trader Rating: 14 (100%+)
you could run a shim there but the only time i thought i had to i ended up havind a bad carrier bearing on the output shaft of the diff. i would recomend going through both those first. my bearing looked and worked fine but if you put a side load on the inner race it would slide over about 3mm and then the diff would be able to move side to side. so be sure to really go through them
eper is offline
