Inferno MP9 thread >
Inferno MP9 thread
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-26-2013, 01:12 PM
  #14716
Well, as my wife pointed out, the brake will prevent the diffs from moving. So I loosened them off and now it works. Whoops! An afternoon well spent.
trr061984 is offline
Old 06-27-2013, 07:42 AM
  #14717
Default Makin' Noise article
Nice job on the Makin' Noise article on Neobuggy, Sean. Recognition for these up and coming drivers is long overdue! Go Cody!
http://www.neobuggy.net/2013/06/27/m...th/#more-29590
dirtn is offline
Old 06-27-2013, 08:00 AM
  #14718
Motorman007's Avatar
Trader Rating: 87 (100%+)
Anyone have a close up of this plastic thing on his fuel line?
Motorman007 is offline
Old 06-27-2013, 08:20 AM
  #14719
Jammin57's Avatar
Trader Rating: 120 (100%+)
The plastic is to keep the fuel line from getting pinched around the front body post, it's not needed but there is pics of it in this thread not sure how far back it is
Jammin57 is offline
Old 06-27-2013, 08:46 AM
  #14720
Old 06-27-2013, 11:43 AM
  #14721
Questions??
Well guys after loosing a couple sets of clutch bell bearings i drilled the hole in my chassis. After another weekend the clutch bell still slightly hit. At my local track we have kind of a step up/table top and its nearly impossible to down side it every time, on a lot of laps you will end up with a flat landing and im certain this is where it occurs. Im going to try the King Headz engine mount to try and slow down a little of the flex. Can any one who has used one give me any pros/cons on the mount. I know a lot of guys are going with the taller set of mounts but thought i would give this a shot. Thanks
RCNUTZ79 is offline
Old 06-27-2013, 12:04 PM
  #14722
McD44's Avatar
Trader Rating: 16 (100%+)
I have the KH mount and I love it. I'm not sure how much of the flex it takes out because I already had the hole drilled but I don't notice any odd wear on the bell or spur that would be caused from too much flex. It is super easy to install and remove the engine that's for sure. I see no cons at all with the mount. Pros are that it's easier to remove and install the engine and more control of the chassis flex in that area. I've never had a screw loosen from the mount either. Very happy with the purchase.
McD44 is offline
Old 06-27-2013, 01:20 PM
  #14723
305M3's Avatar
Trader Rating: 40 (100%+)
Originally Posted by McD44 View Post
I have the KH mount and I love it. I'm not sure how much of the flex it takes out because I already had the hole drilled but I don't notice any odd wear on the bell or spur that would be caused from too much flex. It is super easy to install remove the engine that's for sure. I see no cons at all with the mount. Pros are that it's easier to remove and install the engine and more control of the chassis flex in that area. I've never had a screw loosen from the mount either. Very happy with the purchase.
+1. I too drilled the hole and installed the KHZ engine mount and agree with this statement.
The engine comes out super easy and the lock nutz through the bottom prevent it from moving... Great purchase.
305M3 is offline
Old 06-27-2013, 03:55 PM
  #14724
Trader Rating: 68 (100%+)
They make some awesome engine mounts for several different cars. Ran one on the Losi truggy a few years back. Best mount in the business.
Greg B is offline
Old 06-27-2013, 06:08 PM
  #14725
Thumbs up
Thanks a bunch guys I have mine and have it installed. Gonna give it a try Saturday! If mother nature permits! Lol
RCNUTZ79 is offline
Old 06-27-2013, 06:48 PM
  #14726
offroad dude's Avatar
Trader Rating: 30 (100%+)
Are you guys running the KH with the extended brace
offroad dude is offline
Old 06-27-2013, 07:12 PM
  #14727
HH
HH's Avatar
I've been running the King Headz engine mount extended version for the past few months and I am very happy with it.
I would say its all upside with zero downside.
EDIT: The $49.99 price tag may be a downside for some although that does get you a complete engine mount with an original design.
The Agama mount that a lot of people seem to be quite happy with is only about $12, although that is only for the upper portion of the mount.
HH is offline
Old 06-27-2013, 07:59 PM
  #14728
McD44's Avatar
Yes I have the extended version.
McD44 is offline
Old 06-27-2013, 08:30 PM
  #14729
So i have a friend at AMS and he was talking to Tebo and he wouldn't let him take a pic of his buggy with the body off of it. It has got me wondering new parts ? My friend looked at it said he couldnt tell any difference. My friend runs Kyosho so he knows what an Mp9 looks like.
evolution03 is offline
Old 06-28-2013, 04:43 AM
  #14730
I bought the extended version as well.
RCNUTZ79 is offline
