Inferno MP9 thread >
Inferno MP9 thread
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-17-2013, 06:07 PM
  #14611
THE PHILLY JYNX's Avatar
Originally Posted by rcmoe View Post
Im in the process of replacing my plastic c-hubs and Im trying to figure out how do you determine the degree you want to set the black insert. The set up sheets show you can set it a -1,0 0r +1 degree. Can someone show me how these are read? Im trying to put mines at zero degrees.
You should have 2 sets of inserts for the hubs. A set that the hole is dead center ....that's your zero. And a set that is 1 deg off set that plus 1 if you install them up and neg 1 if you install it down.
THE PHILLY JYNX is offline
Old 06-17-2013, 06:38 PM
  #14612
Trader Rating: 21 (100%+)
Ahhhh...Got it. Thanks Philly!
rcmoe is offline
Old 06-17-2013, 07:08 PM
  #14613
McD44's Avatar
Trader Rating: 16 (100%+)
Has anyone ever run the rear toe inserts on the opposite sides to get more than 3* of rear toe? I'm experimenting with setups (mainly to get to know the car better) and I'm going to try the 2.5 inserts on the "wrong" sides. That will give me about 3.5* of toe I imagine. I am also going to run long rear upper links and a bit more kickup. I'm hoping this will give me a setup that drifts nicely off power and squares up immediately on power. Much like Lamar's javelin that worked with his limp wristed throwing style I am searching for a setup that will work with my ham fisted driving style. (Anyone get that reference?)
Cody's worlds setup is great. I'm just playing around to see what I come up with.
McD44 is offline
Old 06-17-2013, 07:27 PM
  #14614
banana rt's Avatar
im using this set up, and it ran great,, very easy to drive. such a good starting point. but take a note that there is mistyping on set up sheet, rebound=rideheight, rideheight=droop/overall shock length. hope works on you guys too.
Attached Thumbnails Inferno MP9 thread-coryd-mp9-2012-base-loose-track-setup_page_1.jpg
banana rt is offline
Old 06-17-2013, 10:49 PM
  #14615
underway's Avatar
Trader Rating: 51 (100%+)
Revenge of the Nerds...
underway is offline
Old 06-18-2013, 02:07 AM
  #14616
Originally Posted by CoryD View Post
Start with 0. If you want more initial steering go with -1. If you want more on-power steering go with the +1.
I've been drinking a nice wine so I hope I got that right! HAHAH!
You will find that the aluminum c-hubs will give you more steering over stock so I would imagine that the 0's will be just fine.
One thing you didn't mention, which I found out in my own testing is that although the +1 inserts most definitely do give heaps more on-power steering and while the car has less on-power understeer, they induce quite a decent bit of understeer on the way into corners.
If only there were some way to allow the car to drive like it has a -1 on the way into corners and a +1 on the way out. That would be awesome!
Like with any change, everything's a trade-off.
Originally Posted by Tyson72 View Post
I think I will putting a hard rear shock tower in my shopping cart.
Went right over my car lastnight, and noticed a slightly bent rear shock tower. Mine is the darker anodized, so I see y they made a harder one.
The HA parts are absolutely no stronger than the ordinary brown anodized parts. The only difference is in the anodic layer, not the base alloy from which the part is milled. Therefore, the HA towers won't be even the tiniest bit better than the brown kit parts in terms of resistance to bending or torsional loads.
Also, it isn't actually possible to buy the brown anodized kit towers as an official, genuine spare/replacement part. But they've long been available on ebay for HEAPS less than anywhere else in the world (to the best of my knowledge). You can pickup the TKI3 kit rear tower (brand-new, removed from a kit) for about $15 including postage.
Buy the HA if you like the colour I say (or just want to waste your hard-earned $$$).
I haven't ever tried running the rear toe inserts on the wrong side but I have tested the rear camber links in their longest configuration, inside on tower, outside on upright, to see what would happen and indeed the car drifts like there's no tomorrow. SO little traction from the rear end with the very long camber links but at least it did seem to be controllable drifting. Very progressive, but had so little grip I only left it like that for about 10mins and then changed back to normal.
Also, most people run the car with the maximum front kickup, as per all the team drivers or the kit setup, so if you're using any of Cody's setups, he always uses max kickup - not possible to adjust the car to allow any extra kickup.
aaron125 is offline
Old 06-18-2013, 02:55 AM
  #14617
McD44's Avatar
Gotcha, I was referring to the rear kickup actually. The front is exactly Cody's setup actually.
I ran long links at the last race and it did drift ALOT. But as you said it was a very controllable drift which is why I'm hoping the additional toe and kickup will get it to square up under power with the longer links. I'm going for easy off power drift rather than a whipping around along with a car that squares and tracks straight under power. We'll see...
McD44 is offline
Old 06-18-2013, 03:40 AM
  #14618
So are you referring to the rear anti-squat setting when you say kickup?
aaron125 is offline
Old 06-18-2013, 05:26 AM
  #14619
McD44's Avatar
Lol, yeah getting my terms mixed up.
McD44 is offline
Old 06-18-2013, 07:50 AM
  #14620
Cool
Originally Posted by jmackani View Post
So should all the rules be changed when a manufacturer does not meet the specs?
+1
dooug1960 is offline
Old 06-18-2013, 09:47 AM
  #14621
lewis4x4's Avatar
Anyone know where you can get just the inserts as a replacement part for the aluminum Hubs?
lewis4x4 is offline
Old 06-18-2013, 10:05 AM
  #14622
AFAIK the caster inserts aren't available on their own as the ones supplied with the alloy front c-hubs are the same as the ones supplied with the original plastic c-hubs and the inserts can only be purchased along with the plastic c-hubs as they're all part of the same parts tree (if you can call 2 c-hubs and 4 inserts a parts tree).
Sorry to be the one to give you bad news.
aaron125 is offline
Old 06-18-2013, 10:30 AM
  #14623
AZRC4Me's Avatar
Actually this is backwards...the lower hole position gives you +1 caster (lays c-hub down towards rear of car) and the upper hole position gives you -1 caster (stands c-hub more upright towards front of car) when compared with the middle hole insert.
AZRC4Me is offline
Old 06-18-2013, 12:54 PM
  #14624
My error, you are correct.
Old 06-18-2013, 02:44 PM
  #14625
Dyno-Dylan's Avatar
Trader Rating: 36 (100%+)
http://www.amainhobbies.com/product_...rier-Bushing-4
KYOIF421-01
Dyno-Dylan is offline
