Inferno MP9 thread >
Inferno MP9 thread
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-11-2013, 06:57 AM
  #14536
offroad dude's Avatar
Trader Rating: 30 (100%+)
Originally Posted by RCNUTZ79 View Post
I know there has been some talk about anodizing on here and while i agree it dosent last long, it dosent bother me i like the car too much! But after several hours of run time my shock bodies looked a little rough. I thought i would come up with some kind of a protective skin for them. So i found this roll of sticky back "carbon fiber". Anyway this is what i came up with, you guys may think its ridiculous, and im not one to put thing on my cars just for looks but this has a bit of function, protects the shock bodies and can easily be replaced. Turned out kinda cool, and by the way animal balloons are by far the best shock boots!
Before:
After:
I'm not into cosmetics but that looks bada$$. Where did you get it from?
offroad dude is offline
Old 06-11-2013, 07:22 AM
  #14537
Thanks,yeah im not a big cosmetic guy either but the shocks just looked nasty plus this will keep the spring from rubbing directly against the shock body. I was actually picking up oil and filter for my truck at the local Autozone and i seen this stuff. It was in the "go fast" isle. Close to the NOS stickers and the skull shift knobs! LOL
RCNUTZ79 is offline
Old 06-11-2013, 08:09 AM
  #14538
I'm on it...
Old 06-11-2013, 10:17 AM
  #14539
Coach Townsend's Avatar
I'm on it...
just kyosho stickers ole man. And a bead of ca to hold n place
Happy birthday looks who 4T
Coach Townsend is offline
Old 06-12-2013, 05:56 AM
  #14540
banana rt's Avatar
is light blue spring in the front and orange rear still good base overall setup for u guys?
banana rt is offline
Old 06-12-2013, 06:53 AM
  #14541
lewis4x4's Avatar
Default New Paint Scheme on MP9's
Had to share my new paint scheme. Props goes out to Larry Genova at Kustom RC Graphics for the amazing paint job!
lewis4x4 is offline
Old 06-12-2013, 08:05 AM
  #14542
pekow91's Avatar
Trader Rating: 45 (100%+)
Any of you guys try the Fioroni chassis? I bought a used MP9 with a Fioroni chassis from one of the members here. I have been running it for a while now and it's time to replaced. A new Fioroni is pricey and I wasn't sure if its worth it or if I should just try a stock one. Or try some other brand.
pekow91 is offline
Old 06-12-2013, 08:27 AM
  #14543
jzemaxx's Avatar
Go back to stock....
jzemaxx is offline
Old 06-12-2013, 08:39 AM
  #14544
Thanks big time..
Old 06-12-2013, 01:39 PM
  #14545
H0LESH0T's Avatar
Nice
H0LESH0T is offline
Old 06-12-2013, 01:40 PM
  #14546
H0LESH0T's Avatar
Is this due to the small price difference or performance?
H0LESH0T is offline
Old 06-12-2013, 03:28 PM
  #14547
Jamison R's Avatar
Trader Rating: 60 (100%+)
Does anybody have a set of orange rear springs for TKI3 they would be willing to sell? I cannot find them in stock anywhere.
Jamison R is offline
Old 06-12-2013, 04:03 PM
  #14548
If you are OK to wait 5 to 15 days for delivery you can check in Europe stores.
grigorbg is offline
Old 06-13-2013, 01:54 AM
  #14549
Originally Posted by Eivind E View Post
Also, notice in the background, Ronnefalk seems to have a set of Mugen serrated wheel nuts that he's using I do this too..
It's AKA wheel nuts, not Mugen
/PiRo
PiRo is offline
Old 06-13-2013, 08:03 AM
  #14550
Motorman007's Avatar
Trader Rating: 87 (100%+)
Motorman007 is offline
