Inferno MP9 thread >
Inferno MP9 thread
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-06-2013, 06:41 AM
  #14476
setanborneo's Avatar
Originally Posted by underway View Post
PK is somewhere losing his mind.... AGAMA outdrives!!!!! lolol I've been running my MP9 for about 4 gallons and the outdrives still look great. I believe they got the problem fixed a while ago. Only issue I had was the chassis flex, drill hole for clutchbell clearance, replace rear stiffener and keep racing. Do not put Agama outdrives on your MP9, thats like putting hyundai brakepads on your Ferrari.
+100000
setanborneo is offline
Old 06-06-2013, 06:51 AM
  #14477
jzemaxx's Avatar
PK loves Agama parts and he loves BCE chassis too.
jzemaxx is offline
Old 06-06-2013, 06:55 AM
  #14478
Do you make a hole on a Ferrari???? No you dont... I have the king Headz extended mount and never had any problem with the clutch bell.. What happen to the people that make that hole and race on muddy conditions... Answer me that
segreda is offline
Old 06-06-2013, 07:19 AM
  #14479
underway's Avatar
Trader Rating: 51 (100%+)
they are stuck with a Muddy Hole???? Probably go along with the rear stiffener??
I like the flex of the chassis, just dont like killing clutches. So easy and FREE fix is a nice hole(muddy or clean).
underway is offline
Old 06-06-2013, 07:47 AM
  #14480
Default Drilled chassis
This is a picture of Yuichi Kanais car straight off his FaceBook page. If he thinks the best method for solving the problem is to drill a hole in the chassis than ill go with that as well. Im not going to put other brand parts on my car but, i will slightly modify it to cure what is really a minor issue. All that flex is one of the reasons the car is so good.
RCNUTZ79 is offline
Old 06-06-2013, 07:54 AM
  #14481
underway's Avatar
BINGO!
Look Up.... Thats a hole in a Ferrari!
underway is offline
Old 06-06-2013, 08:00 AM
  #14482
Thumbs up
BINGO!
LOL!
RCNUTZ79 is offline
Old 06-06-2013, 08:40 AM
  #14483
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
I think I'll put Associated outdrives, motor mount, and chassis brace on mine Might throw some of their shocks on as well
In all honesty, I've gone through several chassis both drilled and not drilled. I've been lucky and the rubbing hasn't caused any clutch or flameout issues. Never noticed and difference in longevity of clutch shoes, clutch bell, or bearings. I did the drilling just for piece of mind.
Just keep the hole as minimal as possible. I saw one person remove the entire milled section underneath the clutch bell and the chassis flex was considerable. Enough to ruin gear mesh and start chipping teeth.
SEF is offline
Old 06-06-2013, 09:26 AM
  #14484
Trader Rating: 50 (100%+)
TKI 2 Spec A for sale
http://www.rctech.net/forum/r-c-item...tki2-spec.html
ForwardBite is offline
Old 06-06-2013, 11:27 AM
  #14485
BIGTIME's Avatar
Trader Rating: 82 (99%+)
Feels good to be home....
BIGTIME is offline
Old 06-06-2013, 11:38 AM
  #14486
BINGO!
Glad you have the time to pick fights in forums... The person who came with the term "Ferrari" was you... I only ask some feedback about the Persons who do the chassis hole and race at muddy conditions ( not muddy holes) , mud can enter the hole and start a mes there... Not only kanai do it , almost any factory drive does it ( i have Facebook too) , any way those team drivers have many chasis but not the average racers... Many people play safe like i do...
segreda is offline
Old 06-06-2013, 11:48 AM
  #14487
SEF
SEF's Avatar
If you are talking about muddy as in they kept the water on for a little too long, then not a problem with the drilled hole.
If you are talking about raining all day kind of muddy, then I can't comment living in sunny Cali.
But hey, there's already a much larger rectangular opening for the flywheel, I can't imagine the extra mud entering the drilled hole would cause any more problems. If it were me, I probably wouldn't have any additional worries running in muddy conditions if I had the drilled hole in my chassis.
SEF is offline
Old 06-06-2013, 11:57 AM
  #14488
underway's Avatar
Easy there killer( i know you are not killer, its an American saying)... I'm not picking a fight. I've done the hole and raced on a wet track. its no different than the big rectangle that allows you access to the flywheel. Yes a little mud/dirt will get in there but it wont hurt anything. Make cleanup a little more time consuming but thats about it. The point was. If its good enough for Kanai(the designer and GODFATHER of Kyosho) its good enough for little ole me. Mud never hurt a chassis, just made the clean up a little more tedious. Relative terms, the Kyosho is an RC Ferrari... meaning a finely designed and built piece of excellence. No need for aftermarket this or that. Just a small hole is all that is needed. My bad if I offended you. Why Argue??? We drive Kyosho's!!!!!!!
underway is offline
Old 06-06-2013, 11:59 AM
  #14489
underway's Avatar
you replied while I was typing.... but my thoughts exactly
underway is offline
Old 06-06-2013, 12:38 PM
  #14490
No offence... Thanks for the help
segreda is offline
