Inferno MP9 thread >
Inferno MP9 thread
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 06-01-2013, 02:49 AM
  #14416
eper's Avatar
Trader Rating: 14 (100%+)
i believe the older stuff is bigger
eper is offline
Old 06-01-2013, 02:51 AM
  #14417
eper's Avatar
ALU servo saver. Only the top part. Same size as stock one. Makes it feel more solid and turn better. Hole for oil and you can also plug it with an o-ring for better maintenance.
If the saver is not smooth, oil them up.
Hard anodized, available soon. This month is the release アルミサーボセイバー, only the top. Normal compared and no longer twist, will be easily bent even at the corner (^-^) seamstresses for prevention of oil supply hole is available, let you make the move once in a while, I was bitterly injected spray oils such as this hole. O-rings seal the hole with flipping through the O-rings of oil up: and keep working. It is hard chrome finish (Translated by Bing)
New alu servo horn. Longer by 2 mm will make it easier to drive and goes over bumps better.
It improves neutral feel as well. Picture is still prototype. Production will be gun metal color with lazer etched Kyosho logo.
Available soon... Is aluminum servo Horn released this month. Normal in direct and more plastic products, snap also compared to normal in pitch 2 mm longer and easier to maneuver in the gap. Photos prototypes and real products a little bigger, color Tokyo kyosho character laser engraving the quotient gunmetal (Translated by Bing)
there are two new parts freind him on fb and you will see what hes working on
eper is offline
Old 06-01-2013, 03:01 AM
  #14418
eper's Avatar
http://www.buggy-sport.info/index.ph...-mp9-is-coming
link with pics
eper is offline
Old 06-01-2013, 01:46 PM
  #14419
H0LESH0T's Avatar
New alu servo horn. Longer by 2mm will make it easier to drive and goes over bumps better. It improves neutral feel as well.
Picture is still prototype. Production will be gun metal color with lazer etched Kyosho logo. Available soon.
H0LESH0T is offline
Old 06-01-2013, 04:36 PM
  #14420
What improvements do the 2 degree rear hubs make.
ronallen is offline
Old 06-01-2013, 06:35 PM
  #14421
305M3's Avatar
Trader Rating: 40 (100%+)
Originally Posted by RCRacerkid View Post
I myself have been having problems with my driveshafts popping out no matter what I did. I took it upon myself to try and get a temporary solution to fix the problem till Kyosho can. I have put Agama outdrives on the rear of my car and after 2 gallons they show zero wear and zero leaks from the diff. They fit right in for me and they are 1 mm longer so there is more to flex before they fall out. I havent had any issues so far. I would recommend this to anyone that is having issues. I have not tried them in the front but they should fit with no issues. Besides that the k car is awsome!!!!!!!
+1. I put the Agama outdrives in the front 6 months ago and they still look BRAND NEW. Also, no issues w/ driveshafts popping out...
Now I wonder if the Agama truggy outdrives will fit the STRR... Hmmmmm....
305M3 is offline
Old 06-01-2013, 06:40 PM
  #14422
THE PHILLY JYNX's Avatar
Front and Rear no issues on the buggy nor the truggy with agama buggy outdrives
THE PHILLY JYNX is offline
Old 06-01-2013, 06:45 PM
  #14423
305M3's Avatar
Whoa. The buggy outdrives fit both the STRR? That's awesome... Thanks brother...
305M3 is offline
Old 06-01-2013, 08:55 PM
  #14424
But these Agama outdrives appear to not have a hole in them.. did you drill them?
(Just saying, cause most outdrives have a big hole drilled in them)
Eivind E is offline
Old 06-02-2013, 01:15 AM
  #14425
hello,
someone have the partnumber from the agama outdrives?
greets Michael
iwillresist2008 is offline
Old 06-02-2013, 03:31 AM
  #14426
Stardust's Avatar
Improves rear traction on dry dusty tracks .. but the trade off is you lose some steering response.
Stardust is offline
Old 06-02-2013, 09:40 AM
  #14427
Gixer Jay's Avatar
Originally Posted by donrod View Post
You can drill the hole or run the Agama motor mount which raises the motor a little, we run the Agama mount no more rub. And if you don't do anything you will have a problem eventually.
Originally Posted by rcmoe View Post
Is any other modding required when using the agama mounts?
There's nothing hard about drilling the hole..But if I can fix the problem by using the Agama mounts then I prefer that method. If this mod fails then you best beleive I will be drilling a hole.
If you guys prefer to NOT drill the hole and don't want the clutch bell to rub on the chassis run these engine mounts. There is no need to run Agama parts. The KYOIFW102 will raise the engine slightly higher and prevent chassis to clutchbell contact during chassis flex.
http://www.kyoshoamerica.com/SP-Engi...nt_p_3174.html
Looks like Amain has them in stock. http://www.amainhobbies.com/product_...d-Engine-Mount
Hope that helps guys.
Gixer Jay is offline
Old 06-02-2013, 10:03 AM
  #14428
jzemaxx's Avatar
Which ones are they?
jzemaxx is offline
Old 06-02-2013, 01:29 PM
  #14429
Trader Rating: 61 (100%+)
http://www.amainhobbies.com/product_...r-Set-Gunmetal
zixxer is offline
Old 06-02-2013, 02:44 PM
  #14430
HH
HH's Avatar
Default Engine Mounts / Chassis Flex
I've been running the King Headz MP9 EZ Change Motor Mount -Extended version for several months now with good results.
It allows me to keep the engine as low as possible while providing a little extra support for that area which tends to have a bit more flex than the rest of the chassis due to the absence of structural material from the flywheel and spur gear slots. IMO, this helps to maintain a more uniform flex for the right and left sides of the chassis.
Although, just like the alternative Kyosho Mount listed above, the KHZ Mount cost about 4 times as much as the stock Agama engine mount which can make them both a hard sell to some .
It's always a good thing when we have options... the more, the better.
HH is offline
