Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 05-31-2013, 09:43 AM
  #14401
Here is the part
http://www.amainhobbies.com/product_...C-Engine-Mount
donrod is offline
Old 05-31-2013, 12:48 PM
  #14402
Trader Rating: 21 (100%+)
Originally Posted by donrod
Is any other modding required when using the agama mounts?
rcmoe is offline
Old 05-31-2013, 01:24 PM
  #14403
corky_rc's Avatar
Just drill the hole, how hard can it be.
Its a simple mod,thats going to get rid of all the worry.
corky_rc is offline
Old 05-31-2013, 01:37 PM
  #14404
mjealey's Avatar
Nope it is a direct bolt on and fixes the problem. Been running the Agama mount for 5 months. It also gives you enough clearance to be able to put a nut on the 4 screws that hold the bottom engine plates to the chassis. I think it is a win win and you will never have a rub, or an engine come loose and lose its mesh!
mjealey is offline
Old 05-31-2013, 01:55 PM
  #14405
There's nothing hard about drilling the hole..But if I can fix the problem by using the Agama mounts then I prefer that method. If this mod fails then you best beleive I will be drilling a hole.
rcmoe is offline
Old 05-31-2013, 01:59 PM
  #14406
Trader Rating: 6 (88%+)
Cheaper drilling the hole
Drip is offline
Old 05-31-2013, 02:25 PM
  #14407
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
You can drill the hole or run the Agama motor mount which raises the motor a little, we run the Agama mount no more rub. And if you don't do anything you will have a problem eventually.
Donny does the BCE chassis flex like the stock chassis? I didn't think you needed to drill the BCE.
hookem34 is offline
Old 05-31-2013, 02:52 PM
  #14408
Not if you have buddies that run Agama cars
rcmoe is offline
Old 05-31-2013, 02:59 PM
  #14409
Trader Rating: 68 (100%+)
At the current price, the hole should be pre-drilled.
Greg B is offline
Old 05-31-2013, 04:06 PM
  #14410
Quite possibly been part of what kanai was up to? Just have to wait and see.
Drip is offline
Old 05-31-2013, 05:11 PM
  #14411
H0LESH0T's Avatar
New alu servo horn. Longer by 2mm will make it easier to drive and goes over bumps better. It improves neutral feel as well.
Picture is still prototype. Production will be gun metal color with lazer etched Kyosho logo. Available soon.
H0LESH0T is offline
Old 05-31-2013, 06:10 PM
  #14412
Trader Rating: 25 (100%+)
Any goss on the new hard rear arms? I see the pro's haven't used them lately.
smelly62 is offline
Old 05-31-2013, 06:35 PM
  #14413
Jamison R's Avatar
Trader Rating: 66 (100%+)
What size hole do you drill?
Jamison R is offline
Old 05-31-2013, 10:23 PM
  #14414
JEFFRO503's Avatar
Hey guys.....do you happen to know if the older Kyosho Kanai / MP 7.5 style buggies ran the same diffs as these later models? I'm extremely out of the "kyosho loop" per say , but raced the the Kanai's back in the day. Basically.....going through all my RC stuff tonight I stumbled across "the mother load" of diffs , shocks and other stuff for my old Kanai's.
Just wanted to ask because I found out ( even though they have different part #'s....my new Mugen MBX6 Eco runs the exact same diffs my old MBX4 runs if you can believe that.
In fact.....I think the diff's are least likely to change out of anything else on these things. Which is the reason I'm asking.
JEFFRO503 is offline
Old 05-31-2013, 11:54 PM
  #14415
corky_rc's Avatar
12mm
corky_rc is offline
