Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 05-30-2013, 07:59 PM
  #14386
Tyson72's Avatar
Would putting 1mm shims on the K mounts also be a way around it? Has anyone tried that before?
Tyson72 is offline
Old 05-30-2013, 08:05 PM
  #14387
Trader Rating: 25 (100%+)
Hi Tyson,
I personally have never had problems with the bell rubbing the chassis, I mean it does rub but it doesn't cause any problems that I have seen.
smelly62 is offline
Old 05-30-2013, 09:28 PM
  #14388
Tyson72's Avatar
Originally Posted by smelly62
Hi Tyson,
Ok thanks for that feedback mate. I might just leave it for now and keep an eye on it. It doesnt seem to effect the performance at all. well not enough for me to feel it anyway.
thanks for everyones help with this.
Tyson72 is offline
Old 05-30-2013, 09:52 PM
  #14389
Guest
I just cut my chassis this passed weekend, I didn't want to cut it either but my home track put some big triples in, and the clutch bell was hitting more. I wouldn't cut a new chassis.
but sometimes I wonder if the king headz long engine mount would help it??
kyoshoracer77 is offline
Old 05-30-2013, 11:56 PM
  #14390
I see the MP9 tki3 kit and A Spec are now both in stock at Amain guys.
Also how big of a hole is everyone drilling in the chassis under the clutch bell?
And is this really necessary? I'm not too keen on drilling my chassis but the wear mark is getting bigger.
Wow someone is selling TKI3's again. Nice.
3/8" bit. I drilled my TKI3 chassis a few months ago. No problems. The clutch bearings are so fragile, I'm sure the bell hitting the chassis and tweeking it can only shorten their life span more.
My ST-RR EVO is offline
Old 05-31-2013, 01:04 AM
  #14391
rallyebmx's Avatar
Trader Rating: 21 (100%+)
I've run the king headz mount from day one. I haven't had any rubbing except recently. I have 6 gallons on my car with a new chassis around the 4.5 gallon mark and run at fear farm which has some big jumps
rallyebmx is offline
Old 05-31-2013, 03:21 AM
  #14392
ben73's Avatar
Trader Rating: 40 (100%+)
Hi Tyson,
+1
I ran for 8 months without drilling a hole. Plenty of rub marks but never a flameout. I use a 12mm stepped drill bit to drill a hole now. But it's more of a backup than anything else
ben73 is offline
Old 05-31-2013, 04:10 AM
  #14393
Winner's Circle's Avatar
Default clutch bell hitting the chassis if211
I run a ST-RR and don't have the problem of the clutch bell hitting the chassis but I do monitor the MP9 thread just to keep up with what is going on with the Kyosho buggy.
Has anyone tried using the spacer that Kyosho makes to slightly raise the engine height. The part # is if211 (in stock) and it is suppose to fit between the motor mount and the engine. I can't imagine that the very slight raising of the engine would have any significant negative effect on handling.
This spacer may be a quick and easy solution to the clutch bell hitting the chassis problem.
http://siteground235.com/~winners4/a...=if211&x=0&y=0
Lee
Winner's Circle is offline
Old 05-31-2013, 05:02 AM
  #14394
Trader Rating: 6 (88%+)
Just last week kanai posted a picture on Facebook with a hole drilled in his chassis. I would think if the man that designed the car is doing it we should follow suit.
Drip is offline
Old 05-31-2013, 05:36 AM
  #14395
Maximo's Avatar
I have had several customers bend their crankshafts from their CB hitting the chassis in a Kyosho........... SO if your hitting its best not to leave it IMO.......
Maximo is offline
Old 05-31-2013, 06:31 AM
  #14396
Default Drilled chassis
Hi Tyson,
...not until you are leading a big race...
dirtn is offline
Old 05-31-2013, 07:19 AM
  #14397
I'm having the clutch bell issue rubbing the chassis myself. Ive blown up 2 clutches and 1 spur gear so far. Ive heard the new alluminum transponder holder reduces flex and therefore solves this problem. Im sceptable about this. Does anyone have some insight on this?
rcmoe is offline
Old 05-31-2013, 07:42 AM
  #14398
McD44's Avatar
Trader Rating: 16 (100%+)
It's unlikely that would reduce flex. The options seem to be raise the engine or drill the chassis.
McD44 is offline
Old 05-31-2013, 08:14 AM
  #14399
305M3's Avatar
Trader Rating: 43 (100%+)
+1.
Last weekend I smoked a spur/clutch bell combo on both my TKI2 and STRR. I'll be drilling holes this weekend. Additionally, I installed some king headz braces (front and rear) and see how I like them. If the braces take away from the cars' overall drive quality, I'll take them off and hope the drilled hole will be enough to prevent blown spurs, clutch bells, and engine shut offs...
305M3 is offline
Old 05-31-2013, 09:41 AM
  #14400
You can drill the hole or run the Agama motor mount which raises the motor a little, we run the Agama mount no more rub. And if you don't do anything you will have a problem eventually.
donrod is offline
