Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 05-29-2013, 07:28 PM
  #14371
And they wouldn't just be out of stock?
Eivind E is offline
Old 05-29-2013, 08:13 PM
  #14372
Jammin57's Avatar
Trader Rating: 120 (100%+)
There is not a new buggy coming out, it's been out of stock everywhere because the spec a buggy that is prebuilt just came out and after most of those sell they will start making just the kits again, the same thing happened with the tki2
Jammin57 is offline
Old 05-29-2013, 08:41 PM
  #14373
OnRDPassion's Avatar
Trader Rating: 59 (100%+)
Excellent point! I was gonna say I haven't really seen a lot of updated parts for this car to think there was a new version coming out.
OnRDPassion is offline
Old 05-29-2013, 09:20 PM
  #14374
TKI3 is the update it hasnt been out that long
evolution03 is offline
Old 05-29-2013, 10:07 PM
  #14375
Trader Rating: 25 (100%+)
Originally Posted by H0LESH0T
Not to sure why.
For $1400 they can keep it, even stick it where the Sun dont shine.
I paid $1400 for my first Kyosho, the MP7.5 K1.
smelly62 is offline
Old 05-29-2013, 10:34 PM
  #14376
Guest
do what!!!!!!!!!!!!!!!!! u payed what??????
kyoshoracer77 is offline
Old 05-29-2013, 11:45 PM
  #14377
Yep but that was when I knew nothing about online ordering, needless to say the local shops stopped getting my business as soon as I found out.
smelly62 is offline
Old 05-30-2013, 01:53 AM
  #14378
H0LESH0T's Avatar
I notice a few days ago the TKI3 "Spec A" Pre-Built Competition was in the new product section on Amain's Website.
Yep, think it was about $1550 for the K3. That is how much they were in Australia stores. They have come down abit in price over the years.
Kyosho MP9 - Australia Store
H0LESH0T is offline
Old 05-30-2013, 01:40 PM
  #14379
H0LESH0T's Avatar
On the MP9E is says out of stock unlike the TKI3
H0LESH0T is offline
Old 05-30-2013, 05:35 PM
  #14380
LCRC77's Avatar
Does anyone know what size the flywheel is on the TKI3? Im ordering a Buku clutch and I'm to lazy to take my engine out to measure it. As far as I can tell it's a 32mm.
LCRC77 is offline
Old 05-30-2013, 05:36 PM
  #14381
THE PHILLY JYNX's Avatar
32mm is correct
THE PHILLY JYNX is offline
Old 05-30-2013, 05:39 PM
  #14382
LCRC77's Avatar
Thanks much.
LCRC77 is offline
Old 05-30-2013, 06:52 PM
  #14383
Tyson72's Avatar
I see the MP9 tki3 kit and A Spec are now both in stock at Amain guys.
Also how big of a hole is everyone drilling in the chassis under the clutch bell?
And is this really necessary? I'm not too keen on drilling my chassis but the wear mark is getting bigger.
Tyson72 is offline
Old 05-30-2013, 06:58 PM
  #14384
rfleck's Avatar
Trader Rating: 58 (100%+)
You can buy agama mounts and not drill the chassis. The mounts raise the engine exactly 1mm.
rfleck is offline
Old 05-30-2013, 06:59 PM
  #14385
Guest
I took my dremel and cut out a square hole, it just looks better to me, jut make the cut out the same size as the marks from the clutch bell.
