Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 05-26-2013, 11:16 AM
  #14341
Have any of you guys ran the reds clutch with your mp9 ? I Like the feel of the kyosho clutch but i dont like dealing with the springs when i want to pull the clutch off. If you have ran the Reds clutch what setup did you use ?
evolution03 is offline
Old 05-26-2013, 11:51 AM
  #14342
Trader Rating: 61 (100%+)
The reds clutch is super high quality I have been running it on the R5t engine I run 1.0 springs on lose tracks 1.1 on high bite tracks service on the clutch is great shoes last a long time there clutch bells are awesome as well
zixxer is offline
Old 05-26-2013, 12:26 PM
  #14343
What you need is the Reckward Tuning Speed 2.5
The entire clutch unit comes off in one unit, like a nut if you understand.
They cost a lot, but if you buy separate units for the front (separate from flywheel) you could have three clutches in your toolbox, and swap them out in 30 seconds.. you'd have for example one with aluminum installed, one extra with carbon shoes, one with some soft springs, and one with for example 1-2 carbon and 1-2 aluminum split, and just swap them out real quick.
That's what I do makes life a whole lot easier.
Eivind E is offline
Old 05-27-2013, 10:13 AM
  #14344
i dont really think that clutch is an option for me im in the us
Old 05-27-2013, 11:53 AM
  #14345
killabud's Avatar
Tried the CsI blue pistons this weekend. Results were great. I had more steering than I knew what to do with and it soaked up landings like no other.
Just some info if anyone was thinking about trying them.
killabud is offline
Old 05-27-2013, 06:54 PM
  #14346
Mel
Mel's Avatar
Trader Rating: 35 (100%+)
Originally Posted by killabud
Tried the CsI blue pistons this weekend. Results were great. I had more steering than I new what to do with and it soaked up landings like no other.
Not even a k-car owner but yes your car looked great ..super planted
Mel is offline
Old 05-27-2013, 07:27 PM
  #14347
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Did you use the new V Port pistons?
hookem34 is offline
Old 05-27-2013, 08:59 PM
  #14348
OnRDPassion's Avatar
Trader Rating: 59 (100%+)
Is this kit pretty good right out of the box or does it require quite a bit more parts to get it where it needs to be?
OnRDPassion is offline
Old 05-27-2013, 09:26 PM
  #14349
Guest
I never tried the kit pistons but the 1.3 x 8 hole piston is what a lot of guys are running. and that is the only thing major to change other than the alum front spindle carries, that give alittle more steering. you don't have to buy them. for the buggy to turn.
.http://www.infernosonly.com/Kyosho_1...oif347-138.htm
http://www.infernosonly.com/Kyosho_I.../kyoifw412.htm
kyoshoracer77 is offline
Old 05-28-2013, 03:52 AM
  #14350
killabud's Avatar
Thanks Mel! Just get a K car and be done with it.
Then I'll never catch you. Hahaha
killabud is offline
Old 05-28-2013, 03:53 AM
  #14351
killabud's Avatar
V2 Blue.
killabud is offline
Old 05-28-2013, 05:29 AM
  #14352
bill marchant's Avatar
Trader Rating: 274 (100%+)
Just picked up the specA buggy the last time I bought a mp9 Tki3 I had problems with the front drives and cups I hope that bug was fixed haven't been on this thread in a bit but glad to be running the K car again!
bill marchant is offline
Old 05-28-2013, 05:55 AM
  #14353
McD44's Avatar
Trader Rating: 16 (100%+)
Just ordered a set of the V2 blues. What fluids and springs are you using with them?
McD44 is offline
Old 05-28-2013, 05:57 AM
  #14354
Trader Rating: 56 (100%+)
I've run my buggy hard for about 4 gallons and not had any issue with front drive cups or dogbones popping out. Buggy has been golden. I did encounter the flex. That caused the clutchbell to rub the chassis and wear and a bent rear stiffener. Drilled the chassis and all is well again.
underway is offline
Old 05-28-2013, 06:08 AM
  #14355
killabud's Avatar
Mugen 550F/500R
Ended up with the usual light blue front orange rear for spring.
I think it could have been a hair stiffer for the track I was on but I wasnt feeling up to changing out the fluid at the track.
The track I was on is super smooth, technical, and traction was WAY up.
killabud is offline
