Inferno MP9 thread >
Inferno MP9 thread
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 05-02-2013, 07:30 AM
  #14146
Trader Rating: 61 (100%+)
could anyone confirm good service and delivery to the united states from this site ?
http://www.the-kyosho-store.com/dhtml/home.php
thanks guys in advance
zixxer is offline
Old 05-02-2013, 08:23 AM
  #14147
cdc
I ordered my kyosho from there. It took five days and came usps once in the us.
cdc is offline
Old 05-02-2013, 08:29 AM
  #14148
I bought one from there a couple of months ago. Took about 2 weeks to arrive and came UPS once in USA. Shipped initially from France by Colissimo. I would by from there again.
RCMD is offline
Old 05-02-2013, 08:47 AM
  #14149
thanks a ton i just got one ordered ....
zixxer is offline
Old 05-02-2013, 10:23 AM
  #14150
I have ordered a kit from them also, I had no problems
evolution03 is offline
Old 05-02-2013, 10:54 AM
  #14151
underway's Avatar
Trader Rating: 51 (100%+)
me too... great source for kits
underway is offline
Old 05-02-2013, 11:02 AM
  #14152
Have any of you guys tried 7-5-3 or 5-4-2 diff oils ? Im wondering how good it would work in this buggy. I have 7-5-3 in my tekno sct410 and it works good.
Old 05-02-2013, 01:37 PM
  #14153
Trader Rating: 16 (100%+)
7-5-3 worked ok for me, but I also tried 10-7-4 and 7-7-4 because I don't like too much corner entry steering, for me, the MP9 has too much off-power front grip for my driving style.
I noticed very little loss of steering when going to a thicker front diff but it all depends on one's driving style. If you use a 'slow-in, fast-out' style, then off-power grip/steering at corner entry isn't all that important. And in all seriousness, slow-in, fast-out is the only way an off-road vehicle should be driven, as shown by the past 40 years of rallying, motocross racing, ice-racing, etc. Try to keep up some mid-corner speed when racing on ice and you'll know what I mean.
But it all comes down to each person's personal preference, so what may work for me or you won't necessarily be any faster for someone who's not used to driving a limited-traction or an over-powered vehicle, which is exactly what our RC cars are.
Everyone has their own theories and preferences.
Just my $0.02.
aaron125 is offline
Old 05-02-2013, 02:19 PM
  #14154
AZRC4Me's Avatar
I've run a lot of different combos - 7/5/3, 7/5/4, 6/5/3, 6/6/3, 5/6/3, 5/4/3, etc. I always end up back at 5/5/3. For me, 5/5/3 is completely balanced and the car feels like one piece. When I started increasing my front diff, I did get a lot of pull out of the corners with almost no reduction in initial off-power turn in like aaron125 stated above. However, this increase in on-power pull came at a price - it almost felt like the rear end was detached from the car. If anyone has seen a very high-powered front wheel drive car before, you know what I mean - the rear end sort of wags around and is just along for the ride. I know this is greatly exaggerated, but hopefully you get the idea. This is also just what I felt, your experience may vary.
In my testing, I found the diffs on this car to be very sensitive to 1k changes in oil viscosity, so I never felt the need to go up to say 10 in the front or center. Diffs are very subjective too - track conditions, driving style, ability, all play a factor in how they behave and what you feel as a driver. What you feel might not be what someone else feels also. I'd suggest buying a couple spare diffs and have them ready to drop in so you can test different combos fairly quickly at the track. Start with 5/5/3 and tune from there.
AZRC4Me is offline
Old 05-02-2013, 02:43 PM
  #14155
Whats your thoughts on the MP9 TCD diff when used in the front, Elliot Boots over here in the UK seems to be quite a fan.
kennyrc is offline
Old 05-02-2013, 02:49 PM
  #14156
I have used 5-5-3 and i went to 5-7-3 and i like it. I was just thinking about trying something like 5-4-2 or 7-5-3 What brand oils are you using Sean ?
Old 05-02-2013, 03:27 PM
  #14157
Charles Godwin's Avatar
Charles Godwin is offline
Old 05-02-2013, 04:21 PM
  #14158
jzemaxx's Avatar
My boy Cookie joining the Red Army....
jzemaxx is offline
Old 05-02-2013, 04:23 PM
  #14159
AZRC4Me's Avatar
I haven't really had the time to try it to be honest. Also, our tracks over here don't tend to lend themselves to a TCD diff - they're so rough during the mains that the diff would constantly be in a state of flux. Some tracks I've seen in Europe are as smooth as glass comparatively. All that said, I'd still like to try one...
I run Kyosho oils in my diffs. I used to run another oil when I first switched to Kyosho because that's what I had left over. I did notice a difference between another oil's 5k and the Kyosho 5k for instance, so I'd suggest sticking with one brand for all your diffs. For my money, the Kyosho oils are right on par with the rest of their products - top notch. The only time I drop lower than 5 in the center diff is if the track was incredibly blown out. Otherwise, I'm at 5 almost exclusively in the center.
AZRC4Me is offline
Old 05-02-2013, 04:44 PM
  #14160
Trader Rating: 6 (88%+)
Sean,
What about extremely high bite and hot outside temps? Do you think going up to 7,7,5 could be beneficial?
Drip is offline
