Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 04-21-2013, 08:04 PM
  #14086
Guest
Originally Posted by Mark McCoy
Thats the same thing I thought when I read that post lol!
Hell sid I am right at five gallon on mine...[/QUOTE]
well hell i was close, 5 or 6 gallons. i guess our engines have the same on them too.
kyoshoracer77 is offline
Old 04-22-2013, 03:40 AM
  #14087
killabud's Avatar
I've been keeping an Ofna shim kit in my pit box for years. Every nitro guy should! I've never had to use the crank extender but its good to hear they work well. VZB vspecs don't seem to need it.
killabud is offline
Old 04-22-2013, 06:09 AM
  #14088
Cool
ive only had to use it on my kyosho flywheel clutch setup. i run alphas and all alphas that i have have the same crank in them so its not the crank. its like 1mm to short with the kyosho setup. but the shim kit is very handy to have in bag of options
dooug1960 is offline
Old 04-22-2013, 07:40 PM
  #14089
Trader Rating: 25 (100%+)
I just use the clutch shoe shims if the crank is too short
smelly62 is offline
Old 04-22-2013, 10:05 PM
  #14090
bigBoyBigToy's Avatar
Trader Rating: 23 (100%+)
well looks like the 1.3x8 pistons are nowhere to be found does anyone know what pistons came in the orignal mp9 the very first mp9?
bigBoyBigToy is offline
Old 04-22-2013, 11:03 PM
  #14091
1.2 x 8 black
smelly62 is offline
Old 04-23-2013, 05:03 AM
  #14092
Trader Rating: 53 (100%+)
you could try the ghea or AE 8x1.3 taper pistons instead.
nv529 is offline
Old 04-23-2013, 06:10 AM
  #14093
eper's Avatar
Trader Rating: 14 (100%+)
the ae 1.3x8 will work as a temp replacement..
eper is offline
Old 04-23-2013, 08:35 AM
  #14094
rcmike's Avatar
Trader Rating: 40 (100%+)
Originally Posted by jpz_67
And while I am at it. Here's my tki3 cleaned and ready for battle.
Do battle to fall apart and finish in 8th place, love ya buddy My name is lance!!!
rcmike is offline
Old 04-23-2013, 08:55 AM
  #14095
eper's Avatar
nice whip
eper is offline
Old 04-23-2013, 09:02 AM
  #14096
Just been trying to assemble the steering rack and finding that the top metal brace is a tight fit. Is it meant to be this tight, or am I getting this wrong somehow? Once this is done, I need to do is fit the engine and electrics and we should be ready to run!
trr061984 is offline
Old 04-23-2013, 09:58 AM
  #14097
jpz_67's Avatar
Trader Rating: 57 (100%+)
Let me know the Moto X track and Ill be there with a wheel chair to roll you away!!
jpz_67 is offline
Old 04-23-2013, 11:49 AM
  #14098
likeaboss's Avatar
Default Looking for an original TKI3 box
I had a new TKI3 kit that got wet. Does anyone want to sell the original boxes to me? I know, random! Plz pm me if you do. Thanks!
likeaboss is offline
Old 04-23-2013, 07:43 PM
  #14099
rfleck's Avatar
Trader Rating: 58 (100%+)
AE 8-1.3's work well. The are a little tight to fit on the shock shaft, but work if no Kyosho pistons are available. I ran them for about 3 months
rfleck is offline
Old 04-24-2013, 12:34 AM
  #14100
AZRC4Me's Avatar
Why not just get the 1.2x8 hole Kyosho pistons and drill them to 1.3? IF347-128
AZRC4Me is offline
