Inferno MP9 thread >
Inferno MP9 thread
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 04-13-2013, 10:30 AM
  #14011
CaLaBeR's Avatar
Originally Posted by nitroxr View Post
Anybody have any dates on when the Tki3 Spec A will be in stores?
I have been hearing May.
CaLaBeR is offline
Old 04-13-2013, 11:38 AM
  #14012
krash'um's Avatar
Hey guys I have a question regarding the tapered shock pistons. How does the tapered holes affect compression and rebound, does it compress softer and rebound slower or vice versa?
krash'um is offline
Old 04-13-2013, 12:21 PM
  #14013
toyoter91's Avatar
Trader Rating: 47 (100%+)
I believe when used correctly (tapered side facing down) they are to allow for a faster rebounding shock.
toyoter91 is offline
Old 04-13-2013, 01:43 PM
  #14014
Energyzer's Avatar
Originally Posted by slow coach View Post
worlds set up sheet and most other sheets he's using losi oils for the worlds 45FR 35RR Losi oil is measured in wgt where as Kyosho oil is in CST or CPS depending on where you come from, generally speaking over here in the UK when Elliott is running 40/30 losi oils those running Kyosho oils are on 600/400, hope that helps
Thanks for the help man, i guess i'll be able to guide myself from now on. (However I don't understand why would he use Losi oils if he is sponsored by Kyosho...).
So, as I am in Portugal shall is it CST or CPS units?
Another question: what's the part number of those super used shock pistons (the white ones)? Are they suitable for a bumpy and slippery track?
P.S.: Kyosho seems to have one of the best communities here! Everyone is helpful, and that's great.
Energyzer is offline
Old 04-13-2013, 03:37 PM
  #14015
krash'um's Avatar
Thanks!
krash'um is offline
Old 04-14-2013, 05:12 AM
  #14016
Trader Rating: 25 (100%+)
Originally Posted by Tyson72 View Post
Thanks a lot for that will hopefully have a play with that this wknd.
Getting myself a set of orange springs may also be a good idea for my home track as its very loose...
I hope to be over ur way next fortnight for the night meet. I will run the Cody king setup as a start, it will be the first time I've ran my mp9 on that track. A bit excited
You'll love it
smelly62 is offline
Old 04-14-2013, 08:10 AM
  #14017
E-Eddy's Avatar
Trader Rating: 28 (100%+)
Does anybody know the difference between the Black "SP" pistons and the white pistons? I've been looking for the 1.3 x 8 white pistons for a couple of weeks and they're out of stock everywhere. I was wondering if there was any difference to the black piston. Or if there is an alternative like the AE pistons.
Eddy
E-Eddy is offline
Old 04-14-2013, 08:32 AM
  #14018
pascalfd's Avatar
Eddy
There you go :
Originally Posted by SEF View Post
White is tapered with straight holes.
Black is tapered with holes drilled at a 45 degree angle.
Get the whites. Black slow down the shock compression and rebound since the holes are drilled at an angle. I have a set of both and I didn't like the black pistons when I tried them. They would probably work better for fast smooth tracks.
To find some of the white ones -locally !- have you tried Lee (Winner's circle) ?
pascalfd is offline
Old 04-14-2013, 08:33 AM
  #14019
Winner's Circle's Avatar
Eddy
Eddy,
I have the pistons. http://siteground235.com/~winners4/a...05-138&x=0&y=0
Lee
Winner's Circle is offline
Old 04-14-2013, 09:55 AM
  #14020
E-Eddy's Avatar
Originally Posted by pascalfd View Post
There you go :
Thank you Pascal! Makes a lot more sense now.
Lee - I'm looking for the white 1.3 x 8 straight hole pistons. Can't seem to find them anywhere.
Eddy
E-Eddy is offline
Old 04-14-2013, 10:38 AM
  #14021
Cool
Eddy
if winners circle doesnt have them this place does
http://www.activepowersports.com/kyo...k-kyoif347138/
dooug1960 is offline
Old 04-14-2013, 11:05 AM
  #14022
Eddy
Eddie,
I sent you the wrong link. I have them
http://siteground235.com/~winners4/a...47-138&x=0&y=0
Lee
Old 04-14-2013, 11:06 AM
  #14023
mjealey's Avatar
Eddy
There you go :
Great to see you GA boys down there running the K car! It sets the benchmark that others try to copy!!! J/k
mjealey is offline
Old 04-14-2013, 11:34 AM
  #14024
E-Eddy's Avatar
Originally Posted by Winner's Circle View Post
Eddie,
Lee
Lee, sent you an email.
Eddy
E-Eddy is offline
Old 04-14-2013, 12:52 PM
  #14025
HH
HH's Avatar
Eddie,
Lee
Lee,
On your website these 1.3 x 8 hole pistons are showing the correct part number IF347-138, however the description states "1.2 x 8 hole pistons" which may cause some confusion for potential customers.
HH is offline
