Inferno MP9 thread >
Inferno MP9 thread
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 04-12-2013, 08:25 AM
  #13996
Speaking of ball ends ProTek R/C makes a nice little tool for poping the ball ends in and out with little effort and also it is a complete shock tool as well. Check it out it works great.
http://www.amainhobbies.com/product_...k-Shaft-Pliers
donrod is offline
Old 04-12-2013, 08:29 AM
  #13997
Trader Rating: 6 (88%+)
Works perfect got mine a coupe months ago.
Drip is offline
Old 04-12-2013, 08:32 AM
  #13998
slow coach's Avatar
Originally Posted by slow coach View Post
+1 was difficult to put shims in side when building from new, after break in though its possible after a few meetings to get a shim in, as for the pinion shaft I also use a clutch shim .010 then push the centre Universal on tight no gap and as you say spins nice and free but with no movement
should also mention inside and outside the gearbox casing
slow coach is offline
Old 04-12-2013, 09:22 AM
  #13999
Suspended
Trader Rating: 440 (99%+)
Originally Posted by dooug1960 View Post
ive read all 930+ pages and i dont recall anyone doing anything to the fuel tank. I could be wrong as ive read most all of the major cars threads but if your worried about it cracking a little foam couldnt hurt
Last time I heard of fuel tank issues was when the str first came out. People were busting those tanks like crazy. But that was a long time ago.
MattP is offline
Old 04-12-2013, 09:36 AM
  #14000
Trader Rating: 16 (100%+)
Well, at least they know an awesome product when they see it. Product you linked is actually a rebranded set of Arrowmax Shock Shaft Clamping Pliers. I've had the original Arrowmax product for about 2 years or a bit less and it's by far the best set of shock shaft pliers currently available from any brand, at any price, IMHO. And the Arrowmax part is even cheaper and looks SO MUCH better, all anodized purple.
Anyhoo, can't go wrong if purchasing the Arrowmax or ProTek version of this absolutely 100% necessary tool for everyone who does any form of shock maintenance.
aaron125 is offline
Old 04-12-2013, 12:15 PM
  #14001
eper's Avatar
Trader Rating: 14 (100%+)
i like to chuck up the ball end in a vice and use a wrench on the turnbuckle. really makes it a piece of cake.. if you dont have access to a vice vicegrips will do the job.. just dont over tighten the plastic in either of them. if its still hard to get the threads started heat up the plastic a little bit
eper is offline
Old 04-12-2013, 01:42 PM
  #14002
freefallmarine's Avatar
Hey Guy's if you, or anyone you know is intrested in a NIB World's Car,Please look at the For Sale thread.
freefallmarine is offline
Old 04-12-2013, 02:56 PM
  #14003
Bert Vega's Avatar
How come every store is out ok new TKI3's. Finally save the money to buy a new kit and every where is sold out. I was told end of May before stores recieve more.
Bert Vega is offline
Old 04-13-2013, 02:17 AM
  #14004
Thanks for the advice on tightening the rod ends etc. Heating and then using the vice grip with a wrench made that a lot easier. Next question relating to the doffs. Rear and Middle seem silky smooth, but the front seems a little tight, and a little clunky when I am spinning it manually. Do I need to rebuild it, or should I just continue building and run the buggy in and then assess then situation from there?
trr061984 is offline
Old 04-13-2013, 02:38 AM
  #14005
Suspended
If its just slightly hanging then it would probably be smooth after break in. But if it is real notchy, clunky or hard to turn you need to reshim the diff until it is tight with no binding.
MattP is offline
Old 04-13-2013, 04:01 AM
  #14006
eper's Avatar
personally i would run it in with a drill before i went through the trouble of bolting it all up. then u still have a easy option of the reshim.. besides if it runs in this way you can clean up any debris that are left over. clean parts last longer
eper is offline
Old 04-13-2013, 06:00 AM
  #14007
Energyzer's Avatar
Guys, in Eliott Boots's setup sheet from 2012 Worlds what are the units he uses on the silicone oils? And what are the units used by Kyosho on their own oils?
Cheers
Energyzer is offline
Old 04-13-2013, 07:27 AM
  #14008
1evo RRR Driver's Avatar
Cheers
Good luck with that, if he didn't put it on the setup that's prob the secret
1evo RRR Driver is offline
Old 04-13-2013, 09:13 AM
  #14009
slow coach's Avatar
Cheers
worlds set up sheet and most other sheets he's using losi oils for the worlds 45FR 35RR Losi oil is measured in wgt where as Kyosho oil is in CST or CPS depending on where you come from, generally speaking over here in the UK when Elliott is running 40/30 losi oils those running Kyosho oils are on 600/400, hope that helps
Old 04-13-2013, 10:04 AM
  #14010
nitroxr's Avatar
Anybody have any dates on when the Tki3 Spec A will be in stores?
nitroxr is offline
