Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 03-17-2013, 03:01 PM
  #13771
Hey all from those of you running PT racing oils in your mp9's, I feel like they are a little thicker that what the oil conversion chart mentions on there website. Thoughts?
Speedracer1600 is offline
Old 03-17-2013, 03:17 PM
  #13772
Pete Martinez's Avatar
Trader Rating: 17 (100%+)
[QUOTE=killabud;11939560]Did up a practice body and tried this E6000 stuff someone on here mentioned. Pretty sure this will last me all season for practice now.
[/QUOTE where did u buy it. thanks
Pete Martinez is offline
Old 03-17-2013, 03:26 PM
  #13773
e6000 at craft shops maybe hobby lobby. i found mine at our local craft store like ben franklins
dooug1960 is offline
Old 03-17-2013, 03:31 PM
  #13774
oghobavo's Avatar
I purchased E-6000 at Walmart in the arts and craft section.
oghobavo is offline
Old 03-17-2013, 03:45 PM
  #13775
killabud's Avatar
Michaels is where I got it. The mesh is fiberglass drywall tape from lowes.
Man I can't wait to run this thing!!!!!
killabud is offline
Old 03-17-2013, 08:31 PM
  #13776
Hey Tom, I know you from the hut. I also got a new K buggy and truggy. I can't wait till the 24th. You going ?
bkuff-losi is offline
Old 03-18-2013, 12:05 AM
  #13777
Originally Posted by Kane-o
That will be plenty. I run a low profile savox for throttle/brake with about 125oz and it is enough. The servos in my truggy on the other hand are overkill lol.
Thanks bro. With all the servos that are making 300+ oz of torque its hard to know if a wimpy mid 100's oz of torque can do the job.
My ST-RR EVO is offline
Old 03-18-2013, 03:26 AM
  #13778
killabud's Avatar
Thumbs up
Yeah I think I might. As long as it isn't a mud fest.
killabud is offline
Old 03-18-2013, 08:09 AM
  #13779
Not at all, they seem spot on with what there labeled and the most consentient oils we have ever run. Plus you can get them in any weight for fine tuning. example 375,400,425,450 etc.
donrod is offline
Old 03-18-2013, 09:03 AM
  #13780
Yeah I had to wrap my head around it too. My friend ran 10+ gallons last year with a Savox 1251MG low profile (125oz) and 1258TG (167oz) in his MP9 with no issues. This setup saves at least 30 grams over my higher torque steel gear servos in my E buggy and truggy.
I remember 4-5 years ago when we ran 175oz servos for steering in truggy and we got by just fine!
-Kane
Kane-o is offline
Old 03-18-2013, 09:53 AM
  #13781
likeaboss's Avatar
Default Springs
I see most people are using all light blues or an orange/light blue combination as far as springs are concerned. I want to be prepared for pretty much anything I may run into as far as spring rates are concerned. I do indoor clay, and a full season of outdoor at 6 different tracks. Would it be a waste to buy a set of every rate Kyosho makes, or just stick with the most popular, and if that then which ones?
likeaboss is offline
Old 03-18-2013, 10:04 AM
  #13782
McD44's Avatar
Trader Rating: 16 (100%+)
That would be a waste IMO. Orange and lt blue for the rear and orange, lt blue and gray for the front should be sufficient for just about any situation.
edit* I'm liking the lt blue front, orange rear combo for most situations right now. Seems balanced.
McD44 is offline
Old 03-18-2013, 10:08 AM
  #13783
McD44's Avatar
I have a quick question. All other adjustments being the same, which would give more off power steering, front upper arm inserts in the H or L position? I'm thinking the H position but I'm questioning myself.
McD44 is offline
Old 03-18-2013, 11:38 AM
  #13784
likeaboss's Avatar
According to this chart, there should be white between grey and lt blue. Why aren't you suggesting white, or why isn't anyone using this spring rate?
Short Length 70mm Shock Spring Specifications:
Softer
IF350-814: Green - 8 turns/1.4 wire (3.68lb-in / 659.38 n/m)
IF350-7514: Orange - 7.5 turns/1.4 wire (4.02lb-in / 719 n/m)
IF350-714: Light Blue - 7 turns/1.4 wire (4.42lb-in / 6.09 n/m)
IF350-1016: White - 10 turns/1.6 wire (4.62lb-in / 820 n/m)
IF350-6514: Gray - 6.5 Turns/1.4 wire (4.91lb-in / 879.17 n/m)
IF350-916: Purple - 9 turns/1.6 wire (5.28lb-in / 937.39 n/m)
IF350-816: Light Green - 8 turns/1.6 wire (6.16lb-in / 1093.62 n/m)
IF350-716: Blue - 7 turns/1.6 wire (7.40lb-in / 1312.35 n/m)
Harder
(Taken from A-Main's site)
Old 03-18-2013, 02:11 PM
  #13785
Hey does anybody know somebody selling a mp9 for under 600$?
Thanks!
george919 is offline
