Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 03-07-2013, 03:50 PM
  #13666
Suspended
Trader Rating: 440 (99%+)
Guys I just picked up a MP9 TKI 3 with a kyosho e conversion already installed on it along with a BCE chassis. Just wondering if I should stock up on any certain parts? It looks pretty tough. It has all light blue springs on it now. Is that a good starting point for a 4s/e conversion setup buggy? If so what oils should I start with?
Thanks guys!
MattP is offline
Old 03-07-2013, 04:17 PM
  #13667
sodi's Avatar
Originally Posted by bkuff-losi
what are the differences between the 13' & 16' aluminum front hub caddiers
Hey mate
The 13 and 16 is the degree of caster
One is 13degree and the other is 16degree
sodi is offline
Old 03-07-2013, 05:27 PM
  #13668
so what would the 12 deg do
More off power steering suited for tighter tracks, but can be edgy on high speed sections.
Kane-o is offline
Old 03-07-2013, 10:27 PM
  #13669
Suspended
Tebo's and Boots' setups
http://www.kyoshoamerica.com/assets/...13_Ver1011.pdf
K Racing is offline
Old 03-08-2013, 12:23 AM
  #13670
Originally Posted by MCSEDanny
Very nice. Looks similar to my setup. Make sure you oil the filter before taking it out.
Inner filter is oiled, I never oil the outer with the PSM filters.
Originally Posted by Foosmatrix
I suggest putting some heat shield tape on your fuel tank, at least on the pipe side. Also Im running my fuel line the same way and I wrapped the line with heat shield tape as well
Tank has been taped, something I have always done. Have never taped the fuel pipe though.
Chris-s is offline
Old 03-08-2013, 02:47 AM
  #13671
Tyson72's Avatar
Can anyone tell me where u get those nice looking washers that help hold the servos in the radio tray. Can't seem to find them on amain
Tyson72 is offline
Old 03-08-2013, 08:45 AM
  #13672
here is blue just put the color your looking for in amains search and you should find them
http://www.amainhobbies.com/advanced...ds=blue+washer
dooug1960 is offline
Old 03-08-2013, 10:45 AM
  #13673
Curious how long it took you guys to build your buggies? Hopefully I'll get some progress on mine this weekend.
JJ
JJRC is offline
Old 03-08-2013, 10:51 AM
  #13674
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Originally Posted by sodi
Hey mate
Are the 16 degree hubs available for purchase anywhere?
rallyebmx is offline
Old 03-08-2013, 10:58 AM
  #13675
Motorman007's Avatar
Trader Rating: 89 (100%+)
http://rc-sharaku.shop-pro.jp/?pid=53229538
Motorman007 is offline
Old 03-08-2013, 12:05 PM
  #13676
in stock...
http://www.absolutehobbyz.com/produc...ducts_id=13549
Chad Phillips is offline
Old 03-08-2013, 12:11 PM
  #13677
AZRC4Me's Avatar
If you've never found yourself running the +1 caster insert in the front c-hubs we already have, the 16 hubs aren't going to do much for you. None of us ran em at DNC either.
AZRC4Me is offline
Old 03-08-2013, 02:20 PM
  #13678
Wer'e not part of us but we ran them at the DNC in our Kyosho at full caster and they were good for our setup.
donrod is offline
Old 03-08-2013, 03:04 PM
  #13679
RickyBobby619's Avatar
Post 48t Spur
Hey Pitpop,
Question for you since you seem to always have great insight and answers. I was noticing Tebo and Boots were running a 48t spur at the DNC. Boots with a 14t clutch bell and Tebo a 13t. Was wondering what the advantages/disadvantages would be vs a 46/13 set-up? Also do you know if they shimmed the center diff for that setup? Any help and ideas would be appreciated... Thanks
RickyBobby619 is offline
Old 03-08-2013, 03:26 PM
  #13680
AZRC4Me's Avatar
Dang, maybe we should have ran em the way Dylan looked - he was crankin' out there. Just goes to show though, you can run this car in almost any configuration and it's still dialed.
Originally Posted by RickyBobby619
Hey Pitpop,
I'm not PK, but I can answer this for you. It's really has a lot to do with feel and what engine you're running. Here's a breakdown of the gear ratios, listed in order from most bottom end to most top end:
13/48 - 3.692
13/46 - 3.538
14/48 - 3.429
14/46 - 3.286
You can see that 14/48 is a very similar ratio to 13/46. In fact, it's about the same as if you went to the theoretical ratio of 13.5/46 (3.407). So if you wanted a tad more top end from the 13/46 ratio, you could go to 14/48 instead of going to 14/46, like adding half a tooth to the clutch bell.
I'm not sure what everyone else does, but I always shim my center diff so the spur gear is above the bottom of the chassis. It's usually the middle thickness gray shim if I'm not mistaken, but I think you can use the thinnest shim for the 46 spur and be ok.
AZRC4Me is offline
