Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 03-06-2013, 07:45 PM
  #13651
Originally Posted by sodi
Does any body know if boots and tebos setup fron DNC is available yet anywhere.
boots setup is on page 909
dooug1960 is offline
Old 03-06-2013, 08:23 PM
  #13652
Electrolabs's Avatar
Hi everyone, thought I would post a few pictures of my MP9 she's almost ready for the season here in Canada
Electrolabs is offline
Old 03-06-2013, 09:31 PM
  #13653
Trader Rating: 128 (100%+)
That's some sick paint!
Neesh is offline
Old 03-06-2013, 09:37 PM
  #13654
krash'um's Avatar
Hope this works... Tebos 2013 DNC set up
http://www.kyoshoamerica.com/assets/...13_Ver1011.pdf
krash'um is offline
Old 03-07-2013, 12:26 AM
  #13655
Dude that looks awesome!
Who did the paint job?
JJ
JJRC is offline
Old 03-07-2013, 12:31 AM
  #13656
Trader Rating: 21 (100%+)
Chassis question. Are all the chassis the same from the first mp9 to the last?If not,when did it change?
rcmoe is offline
Old 03-07-2013, 12:55 AM
  #13657
Trader Rating: 16 (100%+)
Most definitely not - the original TKI had more of an angle in the side bends, hence not allowing the chassis to flex as much.
Everything from the TKI2 onwards has the same chassis, obviously disregarding the surface finish, whether it be HA or brown (kit) anodized.
Just something I've noticed is that no one was really winning any major races or titles with the original TKI car - wonder if the chassis was the problem the whole time coz as soon as the TKI2 chassis was released, Tebo, King, et al all started winning big time.
Just my $0.02.
aaron125 is offline
Old 03-07-2013, 06:24 AM
  #13658
JJ
Thanks! I certainly didn't LOL
I bought it as a used TKI2 roller and it came with that body
It's pretty much a TKI3 apart from the center HD drive shafts.
Old 03-07-2013, 10:39 AM
  #13659
MP9 is ready for the start of the season in the UK.
Chris-s is offline
Old 03-07-2013, 10:45 AM
  #13660
MCSEDanny's Avatar
Very nice. Looks similar to my setup. Make sure you oil the filter before taking it out.
MCSEDanny is offline
Old 03-07-2013, 02:13 PM
  #13661
sodi's Avatar
Default The RC depot
Hey guys
Just had the pleasure of dealing with Corey at the rc depot.
Great service highly recommend
Thanks Corey
sodi is offline
Old 03-07-2013, 02:22 PM
  #13662
Trader Rating: 17 (100%+)
what are the differences between the 13' & 16' aluminum front hub caddiers
bkuff-losi is offline
Old 03-07-2013, 02:34 PM
  #13663
Foosmatrix's Avatar
I suggest putting some heat shield tape on your fuel tank, at least on the pipe side. Also Im running my fuel line the same way and I wrapped the line with heat shield tape as well
Foosmatrix is offline
Old 03-07-2013, 03:35 PM
  #13664
ben73's Avatar
Trader Rating: 40 (100%+)
12 deg and 16 deg - 4 deg between them.
16 deg smooths out the steering in high speed and bumpy conditions. Change depending on driving style and track conditions.
ben73 is offline
Old 03-07-2013, 03:47 PM
  #13665
so what would the 12 deg do
