Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 02-25-2013, 09:57 AM
  #13501
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Originally Posted by THE PHILLY JYNX
How long has Tebo been running Orion? Unless they have made changes at the factory I would be looking at the only other thing that changed in his motor program this season.
That's precisely what I was thinking....
hookem34 is offline
Old 02-25-2013, 10:04 AM
  #13502
hookem34's Avatar
Originally Posted by RAlmeida
Ryan was on his game, not one mistake, he deserved the win, Tebosho got trashed at the start and an AMAZING job by finishing 2nd after a bad marshal safety caused. He would had most likely won it wasn't it for the bad start. Boots.......well........he's just not lucky. But Ryan is fast. He's just driving the wrong car.
Amen to Tebo's performance. Best drive of the event IMO. Boots sure does seem unlucky, but no one has been more snake bitten then Lutz the last year or so. Seems like he is always breaking in the Main's.
hookem34 is offline
Old 02-25-2013, 10:07 AM
  #13503
likeaboss's Avatar
Originally Posted by Maximo
IMO the instability they are seeing is from the carb...back in 2010 that factory delivered an awesome carb, however for god only knows what reason they decided to changed the internal design of their carbs for 2011 and they have never worked the same afterwards..The new carb design is more thermally sensitive and the LSN is nearly impossible to set correctly...... I believe the factory was aiming to try to squeeze more runtime, but in doing so they made the carbs a nightmare to tune......They had a great thing going, but couldn't leave it alone..........The new carbs have a much more restricted fuel passage which greatly increases the heat transfer from carb into the fuel..which cause a gas bubble to develop which causes the engines to start running erratic when pushed............. I tried telling the powers to be about this several years ago, but what does I know !
Thanks for the insight!
likeaboss is offline
Old 02-25-2013, 10:24 AM
  #13504
mjealey's Avatar
Welcome to Durango! Went down that route over a year ago when the DNX408 first came out. Does no surprise me at all. He is so fast, just imagine what he would do with a solid platform like the Kyosho.....
mjealey is offline
Old 02-25-2013, 02:29 PM
  #13505
Foosmatrix's Avatar
Big ups to Tebo. From 15th to second. Big ups
Foosmatrix is offline
Old 02-25-2013, 02:46 PM
  #13506
silvalis's Avatar
Trader Rating: 29 (100%+)
Originally Posted by 305M3
Camera man zoomed in after the fact and it LOOKED like the pin snapped out the right rear holder for the suspension arm. The arm was just dangling there. However, that is TOTAL SPECULATION on my part as they did not elaborate.
RedRC is reporting this. Just bad luck I guess.
Unfortunately on lap 9 the Kyosho team driver would retire with a broken MP9, unearthing a large rock in the front single double double section it damaged the buggy causing it to go straight on into the straw bails at the end of the back straight later in the lap pulling a rear kingpin from its insert. Afterwards the 19-year-old said when he hit and uprooted the rock, sending his buggy up into the air, it didnít feel right and the contact with the bail just finished off the damage that had been already done.
silvalis is offline
Old 02-25-2013, 02:58 PM
  #13507
wildwillydriver's Avatar
Originally Posted by Motorman007
Sir did the Orion Alpha Discovery 5 posts engine have that carb?
I have an Orion Discovery 3Ports and it's very hard if not impossible to tune perfectly, it runs good but never perfect. It's always or rich or on the lean side but never dialed. At the moment the best solution i found is to run it rich.
If the problem is the carb i can stop trying to find the perfect tune.
Bye.
WWD
wildwillydriver is offline
Old 02-25-2013, 03:06 PM
  #13508
Lutz started with the mp9. Nothing happened
maxflo777 is offline
Old 02-25-2013, 03:23 PM
  #13509
My TKI3+parts are for sale.
http://www.rctech.net/forum/r-c-item...r-w-parts.html
RePeTe is offline
  #13510
Trader Rating: 16 (100%+)
Yeah true, but that was with the original TKI, when just about no MP9 driver was winning anything much at all. Almost 100% of the big-name race wins have come since the TKI2/TKI2 chassis and parts updates were added to the car.
Just my $0.02.
aaron125 is offline
Old 02-25-2013, 03:26 PM
  #13511
My take on Tebo's engine problem is rather simple. He has a rather slow trigger pull, requires him to tune a lil more on the edge to achieve his desired performance. New Fuel+first nitro big nitro race of year+dropping temps, probably just caught him out and was a lil lean on bottom.
Cav's ran good, Savoya's ran good. I have seen every engine have problems at major races, Orion is no different.
RePeTe is offline
Old 02-25-2013, 03:28 PM
  #13512
in Lutz's durango defense, the first 3 vehicles off track in the amain were, these uber bullet proof unbeatable MP9's, Boots out, Dylan out, and King came in for some problem.
RePeTe is offline
Old 02-25-2013, 04:53 PM
  #13513
Gixer Jay's Avatar
It would be awesome to see Tebo run an OS Speed or Novarossi.
Gixer Jay is offline
Old 02-25-2013, 04:58 PM
  #13514
i have a 3 port and a 5 port and i agree they are a nightmare to tune. Its either pinging at idle or 1 hour rich its flaming out on both of them. It isnt the fuel line tank or anything else it is purely the motor. I have several other motors and none of them do this on same lines car everything the same
evolution03 is offline
Old 02-25-2013, 05:25 PM
  #13515
Trader Rating: 25 (100%+)
Originally Posted by shanef
After the buggy race he said the motor was running on. Pretty good sign that it was too lean.
You guys are pretty quick to rubbish something that was 'playing up' in just one race, when you don't know the circumstances behind the issue.
It has been a ongoing problem, at the 2010 Worlds Jared would have easily won had it not been for the flame out he suffered. And there have been at least a few other times the engine has let him down. Maybe he should have dropped the engine instead of the fuel. I hear you cant give Orions away due to their difficult nature. A couple of guys here in Aus were running them and soon changed brands.
smelly62 is offline
