Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 02-24-2013, 09:29 PM
  #13486
Originally Posted by kyoshoracer77
ewwwwwwwwwwwww!!!!!!!! yuck!!!!!!!!! thank u 305m3
been there done that..... no orion for me
evolution03 is offline
Old 02-24-2013, 09:36 PM
  #13487
likeaboss's Avatar
Can someone tell me the purpose of running the thin wheel hex in the rear and the thick in the front? Why have two different thicknesses. I have a set of wheels that rub on the rear upright because the female hex on the wheel is too deep. Fits fine in the front. Page 900 owned! haha
Thanks!
likeaboss is offline
Old 02-24-2013, 09:55 PM
  #13488
Jammin57's Avatar
Trader Rating: 120 (100%+)
Originally Posted by 305M3
(ps - Jared might need to look for a new engine. He commented on their unreliable performance for both the buggy and truck during the finals.)
What did he say about the motors?
Jammin57 is offline
Old 02-24-2013, 09:59 PM
  #13489
shanef's Avatar
Trader Rating: 38 (100%+)
After the buggy race he said the motor was running on. Pretty good sign that it was too lean.
You guys are pretty quick to rubbish something that was 'playing up' in just one race, when you don't know the circumstances behind the issue.
shanef is offline
Old 02-24-2013, 10:38 PM
  #13490
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Thanks!
The only wheels that rubbed like that for me were the stock kyosho wheels that came with my kit
I've seen this asked on here. As I remember possibly to pass tech and more rear grip
rallyebmx is offline
Old 02-25-2013, 04:31 AM
  #13491
silvalis's Avatar
Trader Rating: 29 (100%+)
So what did Boots break?
silvalis is offline
Old 02-25-2013, 04:41 AM
  #13492
nitroexpress's Avatar
Actually, he complained about it in more than one race.
nitroexpress is offline
Old 02-25-2013, 07:11 AM
  #13493
305M3's Avatar
Trader Rating: 43 (100%+)
Camera man zoomed in after the fact and it LOOKED like the pin snapped out the right rear holder for the suspension arm. The arm was just dangling there. However, that is TOTAL SPECULATION on my part as they did not elaborate.
Also, nitro is correct in that Tebo mentioned multiple times that his engine was out to lunch - during both the warmup and the final. Also, during the Truck final, he said that after his first fuel stop the engine was not making good power.
Not saying anything bad about the engines, obiviously they are good considering the number of championships and races they assisted in winning.
305M3 is offline
Old 02-25-2013, 08:46 AM
  #13494
msconcepts's Avatar
I wanted to congratulate kyosho on the partial win at the DNC in pro buggy.............the sales of shocks and c-hubs will sky rocket im sure!!!!!!!!
msconcepts is offline
Old 02-25-2013, 08:54 AM
  #13495
THE PHILLY JYNX's Avatar
How long has Tebo been running Orion? Unless they have made changes at the factory I would be looking at the only other thing that changed in his motor program this season.
THE PHILLY JYNX is offline
Old 02-25-2013, 08:55 AM
  #13496
Ryan was on his game, not one mistake, he deserved the win, Tebosho got trashed at the start and an AMAZING job by finishing 2nd after a bad marshal safety caused. He would had most likely won it wasn't it for the bad start. Boots.......well........he's just not lucky. But Ryan is fast. He's just driving the wrong car.
RAlmeida is offline
Old 02-25-2013, 08:58 AM
  #13497
msconcepts's Avatar
well the car is at least 1/4 right.................
Old 02-25-2013, 09:18 AM
  #13498
Maximo's Avatar
IMO the instability they are seeing is from the carb...back in 2010 that factory delivered an awesome carb, however for god only knows what reason they decided to changed the internal design of their carbs for 2011 and they have never worked the same afterwards..The new carb design is more thermally sensitive and the LSN is nearly impossible to set correctly...... I believe the factory was aiming to try to squeeze more runtime, but in doing so they made the carbs a nightmare to tune......They had a great thing going, but couldn't leave it alone..........The new carbs have a much more restricted fuel passage which greatly increases the heat transfer from carb into the fuel..which cause a gas bubble to develop which causes the engines to start running erratic when pushed............. I tried telling the powers to be about this several years ago, but what does I know !
Maximo is offline
Old 02-25-2013, 09:43 AM
  #13499
Originally Posted by Stardust
Kyosho is Great!! love the message in this add.. AE guys must be Pissed off . Damnit it's true
AE guys must be laughing their nuts off now!
Seriously tho, Elliott seems to have more than his fair share of bad luck...hopefully will turn soon...
Jaf1977 is offline
Old 02-25-2013, 09:57 AM
  #13500
Motorman007's Avatar
Trader Rating: 89 (100%+)
Sir did the Orion Alpha Discovery 5 posts engine have that carb?
Motorman007 is offline
