Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 02-23-2013, 12:30 AM
  #13471
Trader Rating: 32 (100%+)
Hi guys could someone tell me the length of the tki3 front arms from inner centre hinge pin hole to outer centre hinge pin hole ?
Cheers
dr devious is offline
Old 02-23-2013, 07:32 AM
  #13472
Trader Rating: 16 (100%+)
Cheers
That would depend entirely on what camber setting was on the car before the measurement was taken - coz if running less camber, the length will be longer and more camber obviously means the total length would be shorter.
If you just want to know the length of the front upper arm itself, from one end to the other (not including the turnbuckle or rod-end which is screwed onto the turnbuckle), I measured it as being about 59mm.
aaron125 is offline
Old 02-23-2013, 07:37 AM
  #13473
I just thought about it, and now I'm thinking you meant that you wanted to know the length of the lower front arm, right? Not the upper? If so, it's about 114mm from end to end, not from the hingepins as there's a kind of guard on the end of the arm which sticks out at least 3-5mm past the hingepin.
aaron125 is offline
Old 02-23-2013, 09:04 AM
  #13474
Tebo is looking fast and smooth at the DNC. Boots is also fast but making a few more mistakes than Tebo. Looks like finals should be awesome racing.
dewdog13 is offline
Old 02-23-2013, 02:49 PM
  #13475
Yeah mate lower arm length is what im after Really need an accurate measurement hole to hole if someone can help
Old 02-23-2013, 05:01 PM
  #13476
Default tebo interview
anyone seen tebo interview on neo? does anyone know what the two pipes are his switching between?? said he switched for more torque?
motorhead68 is offline
Old 02-23-2013, 05:04 PM
  #13477
Trader Rating: 56 (100%+)
probably 2058 and 2013
underway is offline
Old 02-24-2013, 04:47 PM
  #13478
Does anyone know where I can get the same sweatshirt Tebo wears? His black sweatshirt. Enquiring fan wants to know! :-p
Kopanas is offline
Old 02-24-2013, 05:12 PM
  #13479
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
Or anyone seen any of the old big K tshirts left anywhere?
GMS_Racing is offline
Old 02-24-2013, 05:54 PM
  #13480
mjealey's Avatar
Go Kyosho!!!!! Has anyone tried 7-7-3 in the diffs? I am looking for a little more on-power steering. We have a long sweeper leading in to our straight and I feel the buggy is sort of pushing while hard on the gas coming around the sweeper. I am running Cody King 2010 worlds setup exactly..... Any help would be much appreciated for a little more on-power steering?
mjealey is offline
Old 02-24-2013, 05:59 PM
  #13481
mjealey's Avatar
Also, while coming around the sweeper you are about full throttle and the front inside tire is really unloading and coming off the ground. It will unload and tire will expand and hit the body!!!! Just to give you an idea what is going on..... We have another sweeper on the track and track is a lot of on power steering....
mjealey is offline
Old 02-24-2013, 06:47 PM
  #13482
305M3's Avatar
Trader Rating: 43 (100%+)
Big ups to Jared, Cody, and Sean for their great work at DNC. Fun watching those guys!!!
Also, don't want to forget Elliot, Dylan, and Drew for representing the Red Army in the Show...
(ps - Jared might need to look for a new engine. He commented on their unreliable performance for both the buggy and truck during the finals.)
305M3 is offline
Old 02-24-2013, 07:46 PM
  #13483
Guest
what engine was he using 305m3????( so i wont get one)
kyoshoracer77 is offline
Old 02-24-2013, 08:00 PM
  #13484
305M3's Avatar
Orion power...
305M3 is offline
Old 02-24-2013, 08:05 PM
  #13485
Guest
Orion power...
ewwwwwwwwwwwww!!!!!!!! yuck!!!!!!!!! thank u 305m3
