Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 02-14-2013, 04:27 PM
  #13396
Originally Posted by Wild Thing
HI all,
What was the name of the shop in Europe that was doing K cars cheap?
Cheers
Mark
the kyosho-store heres a link
http://www.the-kyosho-store.com/page-home-144.html
dooug1960 is offline
Old 02-14-2013, 04:47 PM
  #13397
Originally Posted by dooug1960
Wild Thing is offline
Old 02-14-2013, 05:39 PM
  #13398
CaptainHowdyt13's Avatar
Trader Rating: 33 (97%+)
I'm sure it's been asked but where can I get an A Spec roller, and when?
CaptainHowdyt13 is offline
Old 02-14-2013, 06:22 PM
  #13399
Trader Rating: 25 (100%+)
Originally Posted by oghobavo
Has anyone ever tried Elliot Boots setups? If so, how was it?
I tried the rear upper rear link on the outer holes and yes the car is much better, it feels more planted yet still rotates on the tight corners.
Going for a couple of hours track time on Sunday and I'll try the whole setup there and see how it feels. The grip level at Montpellier looks to be similar to our track.
smelly62 is offline
Old 02-14-2013, 06:50 PM
  #13400
savageboy69's Avatar
Trader Rating: 93 (100%+)
what was the downside? usually when you make a change something is gained but something is also lost elsewhere
savageboy69 is offline
Old 02-14-2013, 06:51 PM
  #13401
McD44's Avatar
Trader Rating: 16 (100%+)
So did you run the outer holes on the hubs and tower or outer on hub inner on tower?
McD44 is offline
Old 02-14-2013, 06:53 PM
  #13402
Anyone got a spare set of front and rear shocks they would like to sell?
thorns is offline
Old 02-14-2013, 09:16 PM
  #13403
Foosmatrix's Avatar
Check this place out. They've got some cheap parts
http://www.dollarhobbyz.com/servlet/...KI3/Categories
Foosmatrix is offline
Old 02-15-2013, 02:06 AM
  #13404
Hi all,
what are the advantages by the new 16 front hubs?
Michael
iwillresist2008 is offline
Old 02-15-2013, 02:53 AM
  #13405
McD44's Avatar
I've purchased a good number of MP9 parts from dollar hobbyz. Prices are great and shipping is super quick. They are a "chop shop", they take full kits and break them down to sell the parts. Your parts won't come in Kyosho retail packaging but you usually get better prices and exactly what you're looking for.
McD44 is offline
Old 02-15-2013, 06:54 AM
  #13406
Happy Meal's Avatar
the tki2wc had a thicker front tower and the screws arent counter sunk into the tower and i just compared it to a tki3 on amain and mine is different. its not milled out under the upper a arm bushing for added strength. So yeah its different not much but it should be stronger
edit: i guess i should of read the whole page before i posted thanks for the picture though thats what i have
I was told that the mounting positions are the same, though. I am not sure if this is correct, as I have not measured my different models.....perhaps azrc4me has the definitive answer.
Happy Meal is offline
Old 02-15-2013, 06:58 AM
  #13407
Originally Posted by iwillresist2008
Hi all,
Michael
More over all caster good on those high speed high bite tracks, takes away some steering calms the car down.
donrod is offline
  #13408
Happy Meal's Avatar
Originally Posted by jpz_67
I am still new to Kyosho so I dont know how they go about the unveiling of a new buggy. I very highly doubt a new car is coming. I just bought a new tki3 and even if a new car were to be released it would not bother me one bit. With all the new kits that are out there tki3 is still a major force to be reckoned with. The car just flat out works.
They are probably referring to the spec, which has some changes
http://www.neobuggy.net/2013/02/15/k...9-tki3-spec-a/
Old 02-15-2013, 06:59 AM
  #13409
dito
donrod is offline
Old 02-15-2013, 07:06 AM
  #13410
Happy Meal's Avatar
Originally Posted by johnatpc
Where do you buy Kanai parts and tools at?Thanks JB.
anyone? I have been looking for tools too
