Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 02-13-2013, 07:12 PM
  #13381
Guest
Originally Posted by THE PHILLY JYNX
INFERNO MP9 TKI3 Spec A
That's the change and the reason for the price decrease in the TKI3 kits at some shops I would think.
i belive this too!!!!
bottom line no new tki3 buggy!!!!!!
kyoshoracer77 is offline
Old 02-13-2013, 07:16 PM
  #13382
Guest
Default tki3
i would gladley trade my sealed tki3 kit for a roller.
Old 02-13-2013, 07:53 PM
  #13383
well to me thats great news i just got mine Monday tki2wc/upgraded to a tki3 except i still have the wc front tower for now
dooug1960 is offline
Old 02-13-2013, 10:28 PM
  #13384
Foosmatrix's Avatar
Originally Posted by juninho_foz
which is better? KYOIF346-09 or IF346-03
I prefer IF346-03. They have a higher curve, not as flat as the 09's and they have a baffle on the underside. Both of these things make them less likely to collapse under load.
Foosmatrix is offline
Old 02-14-2013, 04:00 AM
  #13385
setanborneo's Avatar
elliott boots setup at montpellier 2013
http://www.kyoshoeurope.com/reports/...pSheet2013.pdf
setanborneo is offline
Old 02-14-2013, 06:04 AM
  #13386
Foosmatrix's Avatar
Correct me if I'm wrong, but I'm pretty sure that the TKI2 WC and TKI3 have the same front shock tower
Old 02-14-2013, 08:09 AM
  #13387
oghobavo's Avatar
Has anyone ever tried Elliot Boots setups? If so, how was it?
oghobavo is offline
Old 02-14-2013, 08:37 AM
  #13388
Nitronut3's Avatar
No, they are different. The Tki2 has the pockets milled into the tower all over. The Tki3 tower has no pockets milled into it thus it being stronger.
Nitronut3 is offline
Old 02-14-2013, 08:50 AM
  #13389
Jammin57's Avatar
Trader Rating: 120 (100%+)
The tki2 and the tki2 wc are different towers, the tki2 wc and the tki3 are the same towers
Jammin57 is offline
Old 02-14-2013, 08:52 AM
  #13390
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Devil's in the details on this one. TKI2 WC and TKI3 share the same front shock tower. TKI2 and TKI2 WC have different front shock towers.
SEF is offline
Old 02-14-2013, 09:34 AM
  #13391
freefallmarine's Avatar
Sorry guy's but the shock tower on the WC is diffrent from the TKI3. The WC does not have any milling on top of the left and right screw mount's. It's solid there. And on the WC the center screw mount is solid (it takes a button head screw). No counter sunk hole there like the 3.
freefallmarine is offline
Old 02-14-2013, 09:44 AM
  #13392
WC tower.
Old 02-14-2013, 10:19 AM
  #13393
johnatpc's Avatar
Where do you buy Kanai parts and tools at?Thanks JB.
johnatpc is offline
Old 02-14-2013, 10:53 AM
  #13394
the tki2wc had a thicker front tower and the screws arent counter sunk into the tower and i just compared it to a tki3 on amain and mine is different. its not milled out under the upper a arm bushing for added strength. So yeah its different not much but it should be stronger
edit: i guess i should of read the whole page before i posted thanks for the picture though thats what i have
Old 02-14-2013, 04:08 PM
  #13395
HI all,
What was the name of the shop in Europe that was doing K cars cheap?
Cheers
Mark
Wild Thing is offline
