Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 02-12-2013, 11:33 AM
  #13351
Originally Posted by SEF
Elliott Boots running light blue up front and orange in the rear with a TQ and win in a big Euro race (equivalent to DNC in the US). Must be the hot setup
And remember all the talk about stripped plastic servo horn vs. broken servo at Worlds?... well, Mr. Boots is still running a plastic servo horn... must have been a broken servo like everyone said.
http://www.neobuggy.net/2013/02/12/u...elliott-boots/
Or he has been lucky since and not stripped another one.....
It has been said before. Get that guy an aluminum servo horn! There is no reason not to run one!
-Kane
Kane-o is offline
Old 02-12-2013, 11:45 AM
  #13352
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Here's what I also love about top level pro drivers. Elliott Boots is driving like a bat out of hell in practice and qualifiers. Probably has a setup that is too fast for 99.9% of the drivers out there, but he is still fast as seen here:
+ YouTube Video
But then by the time the semi hits, he's figured out his setup, has the buggy dialed, smooths out his driving taking less risks, being more consistent, and just as fast. Insane
+ YouTube Video
SEF is offline
Old 02-12-2013, 12:04 PM
  #13353
Mark McCoy's Avatar
Trader Rating: 11 (92%+)
Yea!!!! Boots Was Flying!!!!!
Mark McCoy is offline
Old 02-12-2013, 12:11 PM
  #13354
CaptainHowdyt13's Avatar
Trader Rating: 33 (97%+)
Originally Posted by CaptainHowdyt13
Ahhh
So replace the center diff case with this one, put on the plastic spur, and that's it? Doesn't leak?
eh?
CaptainHowdyt13 is offline
Old 02-12-2013, 12:44 PM
  #13355
Boots running light blue up front and orange TQ'd the world's, won the nats its the only spring combo he uses
he also runs higher wt oils in the front because he hits the jumps hard and track pipes alot(uses them to get round corners)
hipster is offline
Old 02-12-2013, 03:12 PM
  #13356
bucket2772's Avatar
Trader Rating: 15 (100%+)
Default TKI 3 Spec A
Some info
Kyosho Inferno MP9 TKI 3 SpecA Factory Assembled
http://kyoshosan.blogspot.com/2013/0...a-factory.html
bucket2772 is offline
Old 02-12-2013, 03:23 PM
  #13357
silvalis's Avatar
Trader Rating: 29 (100%+)
eh?
eh!
Probably don't need to replace the diff case/seal, unless yours is gone. Pretty sure it's the same part, but someone else might have a better idea. Just get a couple of plastic spurs. I heard they are pretty easy to strip if you slap it.
silvalis is offline
Old 02-12-2013, 05:52 PM
  #13358
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Looks like a new versions gonna be out soon. Amain has been reducing their price for a few days now, yesterday was 850 now its 25 less!
aloksatoor is offline
Old 02-12-2013, 07:21 PM
  #13359
t8rtot's Avatar
Trader Rating: 14 (94%+)
Is this just because the a-spec or new goodies coming?
t8rtot is offline
Old 02-12-2013, 08:36 PM
  #13360
Foosmatrix's Avatar
I was thinking it was because of the a-spec, but anythings possible
Foosmatrix is offline
Old 02-13-2013, 07:22 AM
  #13361
killabud's Avatar
Driving me nuts. Im ready to make the change to Kyosho but if I go buy a kit now and new one comes out right after Ill flip the F out. Any rumors of a new kit? Seems odd that Amain keeps dropping the price.
killabud is offline
Old 02-13-2013, 07:40 AM
  #13362
jpz_67's Avatar
Trader Rating: 56 (100%+)
I am still new to Kyosho so I dont know how they go about the unveiling of a new buggy. I very highly doubt a new car is coming. I just bought a new tki3 and even if a new car were to be released it would not bother me one bit. With all the new kits that are out there tki3 is still a major force to be reckoned with. The car just flat out works.
jpz_67 is offline
Old 02-13-2013, 08:35 AM
  #13363
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
If there were a new kit coming you would see the pro guys with prototype parts and with cars that don't look like what you and I have. Boots just won with a buggy that looks just like mine except for the 2 new aluminum parts Kanai just made. Price drop is just because of the RTR on the way.
GMS_Racing is offline
Old 02-13-2013, 09:36 AM
  #13364
Foosmatrix's Avatar
When Kanai posted pics of the new parts on his facebook, he posted a message with the pics that said basically No new car, just some new parts
Old 02-13-2013, 10:20 AM
  #13365
rfleck's Avatar
Trader Rating: 58 (100%+)
There was a black Friday special back in November where the price was $799, so just shows you they can sell it for under $800.
The car is awesome, absolutely no regrets here. Pull the trigger. Best car on the planet!
rfleck is offline
