Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 02-11-2013, 03:59 PM
  #13336
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
Originally Posted by h2old
Same here, I take it you are using the white 1.3x8 pistons?
Lol Of course
GMS_Racing is offline
Old 02-11-2013, 04:18 PM
  #13337
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Definitely 1.3x8 white pistons.
SEF is offline
  #13338
McD44's Avatar
Trader Rating: 16 (100%+)
I am curious as to why the orange springs with the front light blues? Better in bumps? I've use all orange and all lt. blues but not the LB/Orange combo. Help me understand this setup better?
McD44 is offline
Old 02-11-2013, 04:26 PM
  #13339
AZRC4Me's Avatar
It helps lock the rear end down. That's why you see grey front springs but no grey rear springs - I've definitely found I like a little stiffer spring up front than in the rear in most situations.
AZRC4Me is offline
Old 02-11-2013, 04:33 PM
  #13340
rfleck's Avatar
Trader Rating: 58 (100%+)
o
It is fast, stable and forgiving. The car is battery forward so a slightly stiffer front is good for me. I've tried all orange and it is good, but front end would bottom out and even dig in occasionally on landings. I am just comfortable with this combo so it allows me to drive harder.
rfleck is offline
Old 02-11-2013, 05:45 PM
  #13341
McD44's Avatar
No problems with creating increased push with that setup then?
I'll give it a shot. Will I be okay with 45F/30R Losi oils with the 1.3x8s?
McD44 is offline
Old 02-11-2013, 05:51 PM
  #13342
CaptainHowdyt13's Avatar
Trader Rating: 33 (97%+)
Originally Posted by silvalis
Ahhh
So replace the center diff case with this one, put on the plastic spur, and that's it? Doesn't leak?
CaptainHowdyt13 is offline
Old 02-11-2013, 06:00 PM
  #13343
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Any idea when the Spec A TKI3 hits the shelves? Wonder if it will include any of the new aluminum bits.....
Those new Kani tools look sweet. The ride height gauge is genius!
hookem34 is offline
Old 02-11-2013, 06:07 PM
  #13344
what is this spec a your talking about
bkuff-losi is offline
Old 02-11-2013, 06:10 PM
  #13345
hookem34's Avatar
A roller assembled bynKyosho employee's and final inspection done by Kani.
They released a Spec A version of the TKI2 in 2011..very limited run and only $50 bucks more than the kit.
hookem34 is offline
Old 02-11-2013, 06:12 PM
  #13346
AZRC4Me's Avatar
It's a pre-built kit that comes fully assembled and ready to race, just need to drop your running gear in it. They did it back with the TKI2 kits, in fact, my first MP9 was a TKI2 Spec A. Kanai checks them too at the end of assembly - pretty dialed way to go.
With regards to the springs, keep in mind, most of the older setups were done with the battery in the rear - moving the battery forward wasn't done until the 2010 worlds. The springs were designed for the MP9 with the battery in the rear, so after moving the battery forward, a slightly stiffer spring is needed to maintain the balance, hence the gray front spring. Not saying you should always run a stiffer spring up front, but if you haven't tried it, give it a shot.
AZRC4Me is offline
Old 02-11-2013, 06:42 PM
  #13347
rfleck's Avatar
Yep, I run 42.5/30 Losi oils. I like it alot I did not think it took steeing way but it made the car more forgiving, less edgy, and encouraged me to push it harder. Worth a shot, since you should have them with the kit already
rfleck is offline
Old 02-12-2013, 02:34 AM
  #13348
So when will the spec a be available
Old 02-12-2013, 03:03 AM
  #13349
McD44's Avatar
Yep, I have both the orange and lt blue springs. The reason I asked about the oils is because I just rebuilt the shocks yesterday and I don't feel like doing it over LOL.
I like more forgiving
McD44 is offline
Old 02-12-2013, 10:20 AM
  #13350
SEF
SEF's Avatar
Elliott Boots running light blue up front and orange in the rear with a TQ and win in a big Euro race (equivalent to DNC in the US). Must be the hot setup
And remember all the talk about stripped plastic servo horn vs. broken servo at Worlds?... well, Mr. Boots is still running a plastic servo horn... must have been a broken servo like everyone said.
http://www.neobuggy.net/2013/02/12/u...elliott-boots/
SEF is offline
