Inferno MP9 thread >
Inferno MP9 thread
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 02-05-2013, 03:16 PM
  #13261
nacho_gas's Avatar
New tools for MP9
http://buggysrc.blogspot.com.es/2013...as-nuevas.html
nacho_gas is offline
Old 02-05-2013, 09:26 PM
  #13262
Originally Posted by My ST-RR EVO View Post
I've had problems with my brakes not stopping smoothly. I tried everything and nothing fixed it. Now I'm using fiberglass and it stops smoothly. I'm interested to know what you didn't like about the black disks? thx
what brand of fiberglass discs and pads are you using?
Norbert50p is offline
Old 02-05-2013, 10:48 PM
  #13263
Happy Meal's Avatar
Originally Posted by nacho_gas View Post
Anyone know where I can get these, or at least the part number so that I can have a friend purchase it overseas?
Happy Meal is offline
Old 02-05-2013, 11:01 PM
  #13264
Guest
kanai just put that stuff on facebook yesterday. i dont think there is a part number for them yet?????
i even asked inferons only for the part numbers yesterday also.
kyoshoracer77 is offline
Old 02-06-2013, 08:05 AM
  #13265
Originally Posted by Eivind E View Post
Is there any way to tell if you get a kit with the fragile outdrives or not?
I notice some pages say 31788B and other pages just say 31788, any difference?
Are there any other bits that are over-tempered/fragile like the outdrives if you get one of the kits from that production run, or is it only the outdrives?
Would also like to know the difference between 31788 and 31788B
Tks!
Nelio is offline
Old 02-06-2013, 10:57 AM
  #13266
I think the part numbers are on the parts...
IFW446 for the Ride Height Gauge
YKW011 5.5/7.0 Wrench
Ykw012 6.5/8.0 Wrench
Speedracer1600 is offline
Old 02-06-2013, 11:04 AM
  #13267
Has anybody got the spring chart the one that shows the grey springs!
av4625 is offline
Old 02-06-2013, 12:38 PM
  #13268
t8rtot's Avatar
Trader Rating: 14 (94%+)
anything new in the works for you nitro kyosho guys or is Amain finally lowering their prices to compete with the other non-money grabbing shops out there?
http://www.amainhobbies.com/product_...Road-Buggy-Kit
t8rtot is offline
Old 02-06-2013, 02:10 PM
  #13269
Winner's Circle's Avatar
Default spring chart
This is the latest spring info from Steve Pond at Kyosho.
File Type: doc
Winner's Circle is offline
Old 02-06-2013, 02:53 PM
  #13270
hookem34's Avatar
Trader Rating: 17 (100%+)
Orange front springs should read 7.5 turns on 1.4 mm wire. Amain also has updated spring charts for kyosho springs that also have the spring rates.
hookem34 is offline
Old 02-06-2013, 05:33 PM
  #13271
Sean Dickinson's Avatar
I'm having trouble understanding all these charts. The old one on amain nearly matched the one direct from steve pond, but now there are actual spring rates on amain and doesn't match the Pond list at all.
Help please?
Thought it was:
-Red
-Blue
-Light Green
-Gray
-Light Blue
-Purple
-Orange
-Green
-Yellow
-White
Sean Dickinson is offline
Old 02-06-2013, 05:56 PM
  #13272
[QUOTE=Sean Dickinson;11783355]I'm having trouble understanding all these charts. The old one on amain nearly matched the one direct from steve pond, but now there are actual spring rates on amain and doesn't match the Pond list at all.
Help please?
where are you finding this list on amains site ive looked and searched and dont seem to find it.
dooug1960 is offline
Old 02-06-2013, 06:18 PM
  #13273
Trader Rating: 16 (100%+)
Help please?
Thought it was:
-Red
-Blue
-Light Green
-Gray
-Light Blue
-Purple
-Orange
-Green
-Yellow
-White
Well, there's definitely something screwy going on with the list from that Pond fella because the grey front springs are obviously harder than the light blue front springs, as greys have 6.5 turns, whereas light blues have 7 turns, both using 1.4mm wire. But on the Pond chart, the grey front springs are purported to be softer than the light blue, which we (should) all know is completely untrue.
For anyone who doesn't get it, the greater the number of turns, the softer the spring rate will be. Easiest way to understand how this works is to simply think of the spring wire completely straightened out - obviously the longer the piece of wire, the softer the spring will be. Think of a tight-rope walker at the circus; if the ends of the tight-rope are attached to the same position, if one uses a longer wire/tight-rope, it will sag in the middle, hence being softer than a short wire/rope attached to the same position.
aaron125 is offline
Old 02-06-2013, 07:22 PM
  #13274
hookem34's Avatar
[QUOTE=dooug1960;11783452]
Help please?
http://www.amainhobbies.com/product_...g-Light-Blue-2
hookem34 is offline
Old 02-06-2013, 07:42 PM
  #13275
thank you of course i didnt search the springs themselves i was looking in all places but where it was.
