Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 02-01-2013, 06:16 AM
  #13171
oghobavo's Avatar
Originally Posted by aaron125
WOW!!! That is an absolute rip-off for the Pro-Tek LiPo pack with the specs it has, considering an Intellect 2700mAh 2s LiPo can be bought from ebay for just $22 +$6 for worldwide postage. IMHO there's nothing that can come close to it for performance per $$.
ebAY Item number: 181063164839
Actually got mine in the mail yesterday. It definitely looks the part. Going to hook her up to the charger tonight and see how she does. If everything checks out, this will definitely be the best bang for buck lipo on the market IMO. Paid for on 1/17, delivered on 1/31, exactly 2 weeks.
oghobavo is offline
Old 02-01-2013, 07:37 AM
  #13172
AZRC4Me's Avatar
Originally Posted by houston
non black unvented brake discs
got a part# for those? just curious...
AZRC4Me is offline
Old 02-01-2013, 08:32 AM
  #13173
THE PHILLY JYNX's Avatar
ran one in st rr evo all last season zero issues.
THE PHILLY JYNX is offline
Old 02-01-2013, 09:18 AM
  #13174
rfleck's Avatar
Trader Rating: 58 (100%+)
Had a tire come unglued and tore the stock body to shreds, so replacing it with a Bitty Body. These can be had for pretty cheap on Ebay. Had a bitty back in the day when I ran Mugen so hope it holds up a bit better. Really like the lines though
Had a local paint up a few of them, so no longer sporting the sprint white racing lid.
rfleck is offline
Old 02-01-2013, 09:31 AM
  #13175
houston's Avatar
Trader Rating: 96 (100%+)
Lol , i pulled them off one of my old kits Sean , they're dialed
I wasnt feelin the coated brake disc thing personally
I have seen guys do some lapping on them and they look like they turned out dialed
I am going to ask yuichi if he knows why they coated the brake discs , kinda interesting
houston is offline
Old 02-01-2013, 09:54 AM
  #13176
AZRC4Me's Avatar
Haha, ok cool. They most likely add the coating to prevent corrosion while it's going from point-of-origin to point-of-sale. It looks like it's just a black oxide coating, nothing too fancy or thick, just something to prevent surface rusting.
AZRC4Me is offline
Old 02-01-2013, 11:01 AM
  #13177
houston's Avatar
hmmm not sure Sean
the other rotors never rusted but they greased them before packing
the coating does take a while to wear off and in the meantime builds up on tge pads
houston is offline
Old 02-01-2013, 12:24 PM
  #13178
AZRC4Me's Avatar
hmmm not sure Sean
Yeah, I'm not sure either, just taking a guess. That's true, the slotted and slotted/drilled rotors don't have the black finish on them. Let us know if you find anything out Monty.
Changing gears, I put together a list of part #s and descriptions of all the stuff I like to use to "upgrade" my MP9s. This is just a collection of hard anodized stuff, Ti screws (I use Lunsford Ti turnbuckles), and stuff that doesn't come in the kit. Do I think all of this is absolutely necessary? No way. Is it all on my DNC car? You betcha - the TKI3 Ultimate...
IF347-138 - 1.3 x 8 pistons Qty-2
IFB006H - TKI3 Hard Body Qty-1
IFW425 - 93mm HD Shafts Qty-1
IFW427 - TKI3 Titanium Screw Kit Qty-1
IFW431 - MP9 HD Rear Center Universal Qty-1
IFW406 - Hard Front Upper Arm Holder Qty-1
92653H - 5.8mm Sway Bar balls hard Qty-1
IFW416 - 6.8mm Steering Link balls outer hard Qty-1
IFW417 - 6.8mm Steering Link balls inner hard Qty-1
IF462H - 5.8mm Servo link balls hard Qty-1
IF463H - 7.8mm Rear Inner link balls hard Qty-1
IF464H - 6.8mm Front upper arm balls hard Qty-1
IF465H - 7.8mm Rear Outer link balls hard Qty-1
W0201H - 5.8mm Lower sway bar link balls hard Qty-1
W0204 - 6.8mm Lower Shock end balls hard Qty-1
IFW412 - MP9 Front Al. C-Hubs Qty-1
IF470 - MP9 Rear Shock set Qty-1
IF471 - MP9 Front Shock set Qty-1
IF473 - MP9 TKI2/3 Chassis Qty-1
IF477 - MP9 TKI3 Front Shock Tower Qty-1
IF437 - MP9 TKI3 Rear Shock Tower Qty-1
AZRC4Me is offline
Old 02-01-2013, 12:49 PM
  #13179
For any of you guys who run the kyosho clutch bells,flywheels and shoes. I posted a bunch of them in the for sale thread along with the kyosho motor mounts. I don't run any of this stuff on my buggy nor truggy. Here is the link
http://www.rctech.net/forum/r-c-item...s-springs.html
Old 02-01-2013, 01:04 PM
  #13180
Ron, when i cut the body out I dont follow the body line at the back were it makes the left hand turn in your pic. I let some extra at the bend. just enough so the mud guards do not hit under full compression. Thats the weak point in the body and they will break/ split there. I would suggest a piece of sheetrock tape and a little shoe goo in that area since yours is already cut.
On a side note. I get my bitty bodys painted and then shoe goo another new body inside the painted one since there cheap.It also make for easy clean up after a race day protects the paint job and is super durable.
Old 02-01-2013, 01:30 PM
  #13181
rfleck's Avatar
That's good to know. Yeah, I reinforce mine with sheetrock tape and shoe glue as well. Just haven't done so in this area. Thanks for tip.
rfleck is offline
Old 02-01-2013, 01:49 PM
  #13182
houston's Avatar
like Sean said , none of this is actually necessary but when you like to do things a certain way and build things to "be your own" its just how you do it
see ya in a few weeks Sean
houston is offline
Old 02-01-2013, 02:18 PM
  #13183
dwkenn1's Avatar
Default Kit
Hey question I am ordering a kit next week but I am ordering a body now and some different shock pistons and csi shock bladders. Hope to have my body painted by time I get my buggy kit. But whay I was wanting to know does the buggy come with the gunmetal hubs or is that a upgrade and if its a upgrade whats the benefit. Also does the buggy come with orange rear shock springs or is that something I will need to order.
dwkenn1 is offline
Old 02-01-2013, 02:47 PM
  #13184
AZRC4Me's Avatar
super pumped, can't wait!! have a safe trip down
You'll want the IFB006H cab forward body I listed, as well as the IF347-138 shock pistons. Not sure what the advantage of the CSI shock bladders is going to be over the stock "normal" Kyosho bladders, since they look almost identical. I'd gravitate towards the Kyosho bladders, they were designed for the Kyosho shocks. Gun metal hubs - you referring to wheel hexes or the rear aluminum hub carriers? Either way, it comes with both. It also comes with Lt. Blue springs all the way around.
AZRC4Me is offline
Old 02-01-2013, 03:26 PM
  #13185
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
Which are the "normal" bladders? The nes that come with the TKI3 kit?
GMS_Racing is offline
