Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 01-16-2013, 09:52 PM
  #13021
jmtrogers's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Afun
I was worried that the 32mm stock flywheel old not reach the start box, but no problem. The 34mm flywheel will make the buggy less punchy. Good if you need that.
I bought a back up CNC Agama motor mount. I have the black one right now made out of some other material. I have chewed up several bells because of those little screws. I was also using red thread locker.
This is the only piece from another car that I have on. Agama outdrives were also on my car when the TKI3 kits came with the bad ones. I happen to have all these parts and got lucky they fit nice because that was the car I used prior to the Kyosho.
We had problems with KH mount on rough tracks. It would loosen up and move. Try to locate some older mounts they are much shorter allowing to use a back up nut. These came from a Team Edition Kit
TKI2
TKI3
jmtrogers is offline
Old 01-16-2013, 11:11 PM
  #13022
1evo RRR Driver's Avatar
Default Differences between tki2 and 3??
Fellas without reading a couple hundred pages can you give me a quick rundown on the main differences between tki2 and 3 besides upperdeck, are there any reasons why you wouldn't buy a tki2?
1evo RRR Driver is offline
Old 01-16-2013, 11:30 PM
  #13023
oghobavo's Avatar
Thicker 'HD' drive shafts, battery/servo tray, side guards, and subtely different front tower(honestly can't tell a difference though). Everything else is literally the same. You will be very happy with the TKI2 as it performs no differently than the TKI3. And if you want to upgrade those few parts, eBay chop usually offer a good bargains on those items.
oghobavo is offline
Old 01-16-2013, 11:47 PM
  #13024
Thanks for the info, the tki2 I'm interested in has the 3 radiotray and sideguards......but stock shafts......we're the 2's and early version 3 shafts breaking?
Old 01-17-2013, 12:24 AM
  #13025
sodi's Avatar
Hi mate
The tki 2 had the thinner out drives
The shock towers are thicker and stronger on the tki3
As you mentioned the radio tray and side pods.
But the out drives were popping out the rear needs the thicker 93mm if you would like to run a wide rear track.
The fronts need the thicker 91mm shafts and all is good
Also the new type front arms with the bumps under the roll bar attachment
That's my experience with the tki2 And tki3
Good luck if you can get a good deal its worth every cent
sodi is offline
Old 01-17-2013, 03:22 AM
  #13026
Dark0ne's Avatar
Originally Posted by sodi
Hi mate
do the 93mm shafts fit in the front and rear or just the rear.
can you post a good setup on here for me Sodi
my local track is a small and technical track
thanks heaps
Dark0ne is offline
Old 01-17-2013, 06:06 AM
  #13027
Afun's Avatar
Trader Rating: 19 (95%+)
[QUOTE=jmtrogers;11687706]We had problems with KH mount on rough tracks. It would loosen up and move. Try to locate some older mounts they are much shorter allowing to use a back up nut. These came from a Team Edition Kit
I could not find the older mounts anywhere. Looks good! How is the BCE chassis working for you?
Afun is offline
Old 01-17-2013, 06:44 AM
  #13028
Trader Rating: 16 (100%+)
Originally Posted by hookem34
I see lots of folks taking about using shock oils measured in WT. I run PT oils and my oils are generally 600/400 with Orange springs all around. I tried 675/375 (almost exactly what 45/30 equals) and my car pushed in corners and was ass slapping all over my home track
With the conversion graphs I have, I found Losi's 45/30 WT oils were about equivalent to Kyosho and Mugen 600/400 oils (and that's what I generally use, in Mugen oils). And those 2 brands are known to have the most accurate cSt ratings and also the most linear progression/equal steps between different oil viscosities of most of the commonly available brands and certainly the best/most accurate of the 'big name' brands.
aaron125 is offline
Old 01-17-2013, 07:10 AM
  #13029
jmtrogers's Avatar
Don't see any advantage r disadvantage with the BCE car. Wear rate is about the same.
Old 01-17-2013, 07:39 AM
  #13030
Trader Rating: 128 (100%+)
Shock towers front and rear are a little beefier on the tki3. Also the rear has an additional set of camber holes on the lower portion. Tki2 still solid tho
Neesh is offline
Old 01-17-2013, 08:38 AM
  #13031
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Aaron if you haven't already, check these guys out:
PT Racing Oils
IMO, even better than Mugen and Kyosho oils
hookem34 is offline
Old 01-17-2013, 09:47 AM
  #13032
+1000 on the PT oils, there are the most consistent and cst certified oils we have ever run and we have ran them all. Also they can make custom oil weights for you.
donrod is offline
Old 01-17-2013, 12:17 PM
  #13033
sodi's Avatar
thanks heaps
Good morning Darkone
Unfortunately the kyosho setup won't work on the very good sworkz setup you have on your car.
sodi is offline
Old 01-17-2013, 02:41 PM
  #13034
THE PHILLY JYNX's Avatar
I'm looking for worn out sets of kyosho break pads. if anyone has sets laying around they don't need shoot me a PM. I want to do a little R and D and need used pads...
THE PHILLY JYNX is offline
Old 01-17-2013, 04:24 PM
  #13035
[QUOTE=Afun;11688523]
I use these with locknuts.
http://www.amainhobbies.com/product_...d-Engine-Mount
stwallac2007 is offline
