Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 01-09-2013, 08:51 PM
  #12871
Guest
Originally Posted by AZRC4Me
Here's a cool new piece:
No p/n yet, but I'm sure it'll be out shortly.
I like that piece!!!!!!
kyoshoracer77 is offline
Old 01-09-2013, 09:30 PM
  #12872
AZRC4Me's Avatar
Originally Posted by evolution03
are you running metal chassis braces ? i thought everyone had basically come to the consensus they took out to much flex ?
No, I run the plastic brace, that's not my car lol. Pretty sure it's Kanai's.
AZRC4Me is offline
Old 01-09-2013, 09:53 PM
  #12873
Guest
I agree with u on that.
Old 01-09-2013, 11:16 PM
  #12874
Guest
Default facebook
Check out facebook under Kanai and watch them write inferno on the new piece!!!!!! Its cool
Old 01-10-2013, 12:09 AM
  #12875
Trader Rating: 127 (100%+)
To anyone thinking about buying a used MP9, please search through this thread and check out the differences between each of the TKI versions! I have see a couple recently that people were trying to pass off as newer versions when in fact they were older buggies with some updated parts. I recently bought what I thought was a TKI2 when in fact it was a mostly converted TKI. I'm stoked to wheel an MP9 now but don't make the same mistake I did!
Ei8ht is offline
Old 01-10-2013, 12:16 AM
  #12876
sodi's Avatar
Default Steering plate
Hi guys
Quick question I see on the setup sheet posted the option of the Ackerman plate facing forward or backward. Does this increase the Ackerman option even more facing it forward is as per kit instruction. Reversing it gives even more Ackerman for more steering is the correct? When its turned the whole location seems to be more rearward.
sodi is offline
Old 01-10-2013, 11:59 AM
  #12877
Default wheel hexes
SEAN, do you use the std or narrow wheel hexes on your buggy?? do you ever change between them? if so what conditions? THANKS
motorhead68 is offline
Old 01-10-2013, 02:58 PM
  #12878
CALVIN THINMAN's Avatar
To:
Sean, and all the other advanced racers beside race equipment will i be required too do anything else before entering in races?
CALVIN THINMAN is offline
Old 01-10-2013, 04:59 PM
  #12879
Hello friends,
The new hub with 16 degrees, 16 degrees this is positive or negative?
ajceara is offline
Old 01-10-2013, 05:16 PM
  #12880
Afun's Avatar
Trader Rating: 19 (95%+)
I just installed the Kyosho TKI3 Titanium Screw It. I have figured out where to install all the screws except the ones pictured. I think these screws were placed in the bag in error. They are too short for wing stay or connector. Any thoughts? The only place I see screws that look like this are the front bulkhead and rear wing stay connected to shock tower.
Kyosho Screws by Afun2011, on Flickr
Afun is offline
Old 01-10-2013, 05:30 PM
  #12881
maybe the lil exhaust stinger guard thing?
RePeTe is offline
Old 01-10-2013, 05:53 PM
  #12882
houston's Avatar
Trader Rating: 96 (100%+)
There really hasnt been a huge amount of updates between all "different" versions
Rear hub carriers +2 aluminum , threaded shocks , rear tower shorter
houston is offline
Old 01-10-2013, 06:16 PM
  #12883
Afun's Avatar
Way too big....these thing are the same thickness as the front bulkhead screws
Afun is offline
Old 01-10-2013, 06:35 PM
  #12884
ad12i's Avatar
[QUOTE=Afun;11660357]I just installed the Kyosho TKI3 Titanium Screw It. I have figured out where to install all the screws except the ones pictured. I think these screws were placed in the bag in error. They are too short for wing stay or connector. Any thoughts? The only place I see screws that look like this are the front bulkhead and rear wing stay connected to shock tower.
is that the 3*6 screws? it's used under the center diff mount, to screw the plastic where the brake rotor sits.
ad12i is offline
Old 01-10-2013, 07:55 PM
  #12885
Guest
[QUOTE=ad12i;11660745]
i think that screw is a flat head not a button head?? what about the rear wing mount stay. bolts on top of the rear diff???? that new piece that kanai just made out of alumiumn???
