Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 01-08-2013, 01:33 PM
  #12841
Sean Dickinson's Avatar
Hey guys, I'm about to get a tki3 for DNC this year, and I like to keep track of my setups for every race. So I went ahead and made an editable PDF for this purpose, just thought I'd post a link here to anyone that wants to do this as well. Just go ahead and download youself a copy and it should be good to go.
https://docs.google.com/file/d/0ByDf...xTakVvUlE/edit
I haven't done the google docs link before, so if it doesnt work let me know.
Sean Dickinson is offline
Old 01-08-2013, 01:44 PM
  #12842
CoryD's Avatar
http://rcdepot.ca/TEAMGUYs/Setup%20S...(Editable).pdf
This one has a few more options.
CoryD is offline
Old 01-08-2013, 01:50 PM
  #12843
Originally Posted by CoryD
Oh wow, didn't know there was already one. Thanks though, mines not quite as good as the one you posted.
Old 01-08-2013, 01:51 PM
  #12844
AZRC4Me's Avatar
oh no, dueling setup sheets...for some reason, and I don't know why, I'm partial to Sean's...
thanks for the links guys.
AZRC4Me is offline
Old 01-08-2013, 01:53 PM
  #12845
CoryD's Avatar
I was bored one day -- well -- for 3 hours LOL -- and put it together. I have to add the option for the HD body so I will be publishing an updated one soon.
Later,
CoryD is offline
Old 01-08-2013, 01:56 PM
  #12846
Later,
Same thing here man. It does take quite a while to do right! I was not expecting it, but didn't want to just give up.
Old 01-08-2013, 02:01 PM
  #12847
CoryD's Avatar
Speaking of DNC...got any good setups for the track? Will be my first time and don't know what to expect the track to be like.
Later,
CoryD is offline
Old 01-08-2013, 02:23 PM
  #12848
Later,
Well the problem with that is, other than a pipe change, the track is still the same as the 2012 DNC. Currently horrible track conditions. But the setup should still be good.
https://docs.google.com/file/d/0ByDf...pvTkZya00/edit
Also has 20g bolted to each rear hub.
Old 01-08-2013, 11:49 PM
  #12849
AZRC4Me's Avatar
Later,
This is what I ran there last year:
https://docs.google.com/open?id=0B-c...DJtOGFhZVFyaVk
If I had it to do over again, I may try grey springs up front and 7k in the front diff, and might change rear shock oil depending on temps. But I remember my car being super dialed there, especially in the main.
AZRC4Me is offline
Old 01-09-2013, 12:23 PM
  #12850
krash'um's Avatar
hey guys I'm fairly new to the MP9, please pardon the newbie questions. I am looking to order shock pistons 1.3/8, while searching on amain I ran across KYO1F347-138 (white) and KYOIFW405-138 (black) what is the difference between them? I also noticed there are black and white for each set of pistons, what is the general difference black and white?
thanks,
krash'um is offline
Old 01-09-2013, 12:26 PM
  #12851
pitpop's Avatar
Here is Cody's from last year, fast lap in the main, 39.2..
http://www.infernosonly.com/v/vspfil..._Challenge.jpg
we will go in here with the same set-up, tires, etc..
pitpop is offline
Old 01-09-2013, 12:58 PM
  #12852
houston's Avatar
Trader Rating: 96 (100%+)
Thumbs up
houston is offline
Old 01-09-2013, 02:25 PM
  #12853
johnatpc's Avatar
Default PNB
Hey I`m a new owner of a TKI3,and I`m going to the Physco Nitro Blast.
This track is notorious for blowing out can anyone help with starting setup thanks in advance JB.
johnatpc is offline
Old 01-09-2013, 02:37 PM
  #12854
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
thanks,
White is tapered with straight holes.
Black is tapered with holes drilled at a 45 degree angle.
Get the whites. Black slow down the shock compression and rebound since the holes are drilled at an angle. I have a set of both and I didn't like the black pistons when I tried them. They would probably work better for fast smooth tracks.
SEF is offline
Old 01-09-2013, 03:02 PM
  #12855
pitpop's Avatar
this one works well for blown out:
http://www.codykingrc.com/category/m...loose_surface/
In addition you might try 4k in the center if it's really rough..
pitpop is offline
