Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 01-05-2013, 02:47 PM
  #12781
Foosmatrix's Avatar
For the pipe side Velcro, I put a couple drops of thick CA glue on the back and it solves that problem
Foosmatrix is offline
Old 01-05-2013, 03:04 PM
  #12782
freefallmarine's Avatar
Does the velcro stick to the body and plastic mudguards real good? Is de-natured alchohol cleaning good enough for adhesion, or is there something else i should do?
freefallmarine is offline
Old 01-05-2013, 03:08 PM
  #12783
Foosmatrix's Avatar
The Velcro generally sticks well to the guards and the body, except for the pipe side due to the heat. Honestly, I've never bothered to clean anything before applying the Velcro, but it won't hurt. As far as the effects of using the Velcro or not, I don't run without it for a couple reasons. First, it does keep the dust and dirt down as well as keeping large rocks and pebbles out. Second, I believe it can improve handling both on the track and in the air by keeping the body tight to the buggy and minimizing air entering the body from below causing a parachute type effect....just my theory on this one
Old 01-05-2013, 03:25 PM
  #12784
Sweet, Thank's for the replies guy's!
Old 01-05-2013, 04:08 PM
  #12785
Fletch7276's Avatar
I've never ran the velcro, but will give it a try based on the feedback. Would love to cut down on the dirt inside the car...
Fletch7276 is offline
Old 01-05-2013, 05:36 PM
  #12786
Fletch, How are the Hobby Shops in China?
Old 01-05-2013, 11:16 PM
  #12787
sodi's Avatar
Hey guys
Just thought I would give some feed back from the race meeting today
Did not have a great qualifying I started 10th in the amain and ended up 4th overall. It is my first race with the KCar it was really solid the tack was very loose off line and bumpy in certain areas.
My nova was really economical helping me get so far up in the main
Proud to be part of the Red Army
sodi is offline
Old 01-06-2013, 02:08 AM
  #12788
Originally Posted by SEF
I've been looking for more steering from mid to exit. I run primarily at Revelation Raceway. Guys like Sean and Cody run here all the time. Definitely NOT even close to that level, but I have fun and try to compete in the lower levels.
I run Cody's Worlds setup on my tki3, but with orange springs all around and 42.5/27.5 Losi oils since the track is a little rough and bumpy. Seems to be a popular setup for this track. Car feels really planted, and easy to drive, but just looking for more corner speed and trying to get out of corners faster.
Here is a video when a friend of mine let me borrow his Ninja B02. I usually run Nova engines. This was the first tank I ran, so in the first few minutes I am trying to get used to the completely different power band. Any advice, driving or setup wise would be appreciated.
+ YouTube Video
Your driving looks pretty good in the video. The camera man's shooting ability needs some work! Your front shock oil seems too thick... especially in temps nearing 55 degrees and with orange springs. I don't even know how it rebounds! From my cold weather experimenting this time of year (granted not at Rev) I think you may want to try 37.5 (TLR). I think your diffs are too thick as well. Try 5/5/3. Also, bias your brakes for more rear braking and less front braking. Not so much that your rear tires lock as soon as you touch the trigger. The idea is to have less front braking so the front tires can roll sorta freely thereby keeping their traction and keeping your turn radius tight. Too much front brake can make the car go wider. Adding in more brake to the rear makes the car have a tendancy to start to spin. If you get it right, it won't spin. It'll only start to spin and then stay kicked out to the side. Jumping on the gas after it starts to spin, but before it gets stuck kicked out to the side, will keep the rotation going. The front tires will be hooked and the rear tires will be pivoting around them and you can drive out of it on power.
My ST-RR EVO is offline
Old 01-06-2013, 02:18 AM
  #12789
Has anyone noticed that the stock TKI3 brake disks are warped and that makes the car not stop smoothly at all? I say this because I noticed my car was pulsating to a stop. The brakes seemed grabby. I put in new Kyosho brake disks and pads and the problem was still there. The vented rotors as well. I resurfaced the second set of stock brake disks by hand on a flat grinding stone and the problem finally went away. A fellow racer at my track told me he had the same issue with his Kyosho. Anyone? And what is the remedy beside having to grind them by hand for a half hour on each side?
Old 01-06-2013, 03:24 AM
  #12790
rfleck's Avatar
Trader Rating: 58 (100%+)
Well stated! I agree!
rfleck is offline
Old 01-06-2013, 06:37 AM
  #12791
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Yes, same here. We had traveled to a kbrl race in Tucson and I was going over my car in the hotel the night before race day. Couldn't figure out why my brakes were sticking. It wound up being warped stock discs. Went with the vented and haven't had the issue arise yet
rallyebmx is offline
Old 01-06-2013, 06:42 AM
  #12792
McD44's Avatar
Trader Rating: 16 (100%+)
I finally had the chance to get my MP9 out to a nice indoor track. Moist smooth clay and fairly technical. My current setup can be viewed here Baseline TKI3 Setup. I had very little steering off power and on power which leads me to believe it was a tire problem. Hard throttle would spin the back end around on command but coasting into a corner at any normal entry speed left me with almost no steering. My first step will be to try different tires, does anyone have any other suggestions? I'm more concerned with off power steering at this point. I will also make some geometry changes to get closer to CWS (Cody's Worlds Setup) namely raising the front roll center and shortening my rear camber links.
Thanks in advance for your suggestions.
McD44 is offline
Old 01-06-2013, 07:36 AM
  #12793
i see your from kazoo where have you found to run your car indoors? just curious for other options
dooug1960 is offline
Old 01-06-2013, 08:10 AM
  #12794
McD44's Avatar
This was at AMS Raceway in Grand Blanc.
McD44 is offline
Old 01-06-2013, 08:17 AM
  #12795
houston's Avatar
Trader Rating: 96 (100%+)
You make sure your ride heighth is set right ?
houston is offline
