Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 01-02-2013, 09:33 AM
  #12736
jmackani's Avatar
Trader Rating: 14 (100%+)
Originally Posted by My ST-RR EVO
Brett, thanks for that update. What was the tempurature where you were testing? These winter temps are messing my set up up. I haven't heard of anyone using 8/8/3 before. Did you like that better than the 5/5/3? Good info on the 1.3x8's. If Amain ever ships my stuff... What's your shock mount center to shock mount center droop setting? I reduced mine to 99mm front / 118mm rear and it was slipping and sliding.
Did you redo your ride height after reducing the droop. If not, then that is the reason for the sliding.
jmackani is offline
Old 01-02-2013, 09:41 AM
  #12737
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Originally Posted by Akhor
Are there any rumors of a TKI4 yet? I'm considering buying a new buggy and don't want to drop the hammer if a new version is just around the corner...
I didn't really notice any huge changes from the stock tki3 in the cars that were run at the Worlds. Maybe a few tuning options here and there to get the car working on a tack that is do different from most other tracks, but that's about it. Unless someone has some other insights...
So even if a tki4 comes out soon, I can't imagine it being that different from the tki2 or tki3. So drop the hammer already and take your driving to a whole new level. Trust me, I know, I came from a Losi 8ight 2.0 to a Mugen mbx6R, and now Kyosho, and I love driving this thing.
SEF is offline
Old 01-02-2013, 09:56 AM
  #12738
Akhor's Avatar
Thanks for this information!
Akhor is offline
Old 01-02-2013, 01:45 PM
  #12739
Akhor's Avatar
Does the 34mm Buku clutch fit the TKI3?
Akhor is offline
Old 01-02-2013, 01:49 PM
  #12740
McD44's Avatar
Trader Rating: 16 (100%+)
I can't say for sure if the BUKU fits (I think it does) but I'm running a 34mm Losi 8ight setup without issue.
McD44 is offline
Old 01-02-2013, 01:52 PM
  #12741
CoryD's Avatar
Yes It will fit -- you will just flame out when you land.
MP9 needs a 32mm clutch. I suppose you could lift your motor up 1mm with some shims...
Later,
CoryD is offline
Old 01-02-2013, 01:56 PM
  #12742
Later,
Kane-o is offline
Old 01-02-2013, 02:07 PM
  #12743
savageboy69's Avatar
Trader Rating: 93 (100%+)
i just ordered the 32mm buku, should be here the end of the week
savageboy69 is offline
Old 01-02-2013, 04:04 PM
  #12744
CaptainHowdyt13's Avatar
Trader Rating: 33 (97%+)
Werks Pro Clutch.
CaptainHowdyt13 is offline
Old 01-02-2013, 11:01 PM
  #12745
AZRC4Me's Avatar
Simply put no. More complicated answer - no. In all honesty, I haven't heard anything about it. If it was me, I wouldn't put off buying a TKI3 for fear of having an "out of date" car in 3 months. It's what I'll be running at DNC 2013.
Cody's MP9 was exactly the same component-wise to the buggy he normally runs here. Same car everyone can buy and add titanium screws and HA balls to.
AZRC4Me is offline
Old 01-02-2013, 11:56 PM
  #12746
oghobavo's Avatar
I think the stripped spring look is pretty cool . The process took more effort than expected but worth it for the added visual aesthetic. They were orange springs if inquiring minds wanted to know.
oghobavo is offline
Old 01-03-2013, 04:28 AM
  #12747
Trader Rating: 25 (100%+)
Happy new year Sean! So Cody didn't try the 16 deg carriers or the unsprung weights? Any news about the upgrade parts and how they performed? I'm thinking of only getting the hard rear arms and not much else at this point. I'm curious about the weights and 16deg carriers though.
smelly62 is offline
Old 01-03-2013, 05:08 AM
  #12748
sialek's Avatar
Guys could someone tell me, are the MP9 shocks (with no regulation - no thread? - sory for my language), the same as tki3 shocks? (lenght, etc?)
or at least measure the shock lenght for me ? (i own mp9 one's, need a lenght of tki3)
sialek is offline
Old 01-03-2013, 07:37 AM
  #12749
CoryD's Avatar
For those of you looking to replace worn out drive-pins instead of buying new universals, I put together a quick little tech-tip video on how to do this:
https://vimeo.com/55870937
Later,
CoryD is offline
Old 01-03-2013, 07:44 AM
  #12750
McD44's Avatar
Later,
Thanks man, that's helpful! Now here's a link to my video of my TKI3 using a 34mm clutch without flaming out on landings...http://youtu.be/oHg5SJYRHA0
Just messing with you man. Seriously though, great video.
McD44 is offline
