Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 12-26-2012, 02:43 PM
  #12631
savageboy69's Avatar
Trader Rating: 93 (100%+)
just got my mp9 yesterday, just finished the battery mod today, have to get some light blue springs all around, pipe and clutch, then its time to do motor break in, this will be my first time running nitro 1/8, i use to run ebuggy with a mp9 and i loved that thing
savageboy69 is offline
Old 12-26-2012, 04:15 PM
  #12632
eper's Avatar
Trader Rating: 14 (100%+)
looks really good.. your going to love nitro. i also started with electric for my 8th scaler and sold that as soon as i drove my nitro. so much fun but a little more maintenance. good luck with it
eper is offline
Old 12-26-2012, 04:52 PM
  #12633
305M3's Avatar
Trader Rating: 43 (100%+)
Congrats... I love it when everything is new and shiny...
305M3 is offline
Old 12-26-2012, 04:54 PM
  #12634
this one was a used mp9, but well taken care of, i dont have hv servos yet but im looking to run a life pack, will this be ok? also what mah packs are you guys running and what kind of run time are you getting?
Old 12-26-2012, 05:31 PM
  #12635
houston's Avatar
Trader Rating: 96 (100%+)
only a flashlight racer would ask "what Mah pack and what kinda runtime ?" in the nitro offroad , you silly focker!!!
1800-2700Mah 2s lipo should be fine Joe
lmk what servos those are before you run unregulated , kinda hard to see in pic , i have a regulator you can use if necessary
houston is offline
Old 12-26-2012, 09:30 PM
  #12636
I run a 1700 Life as well as a 2100 Lipo. A 15 minute main, 3 qualifiers, and a little practice only takes about 500mah out of my Rx packs.
-Kane
Kane-o is offline
Old 12-27-2012, 07:32 AM
  #12637
sodi's Avatar
Hi guys
Today I went out again to my local track with the tki3
The car is really good hooked up and planted.
The more I drive this car the more I realise that every cent spent is well spent.
Once again thanks to kyosho for a great product.
sodi is offline
Old 12-27-2012, 08:50 AM
  #12638
eper's Avatar
Thumbs up
+ 1,000,000
eper is offline
Old 12-27-2012, 11:50 AM
  #12639
mjealey's Avatar
Hey guys, in general most setups I look at the arms are using 11 degree bushings and in the lower position both upper and lower arms. What would change if you run the arms in the upper positions instead? It looks like most of the K-car drivers had the arms in the upper position for World's and what just curious of how that would feel?
mjealey is offline
Old 12-27-2012, 12:19 PM
  #12640
AZRC4Me's Avatar
Default Suspension Bushings
Ok, just so we can all get on the same page here - typically, you refer to the 4 lower hinge pin holders as A, B, C, D, starting from the front of the car. So Front-Front is A, Front-Rear is B, Rear-Front is C, and Rear-Rear is D.
So, you're referring to the A pill setting, running the dot in the highest location, which gives the most kickup (11 degrees). When you run the dots in the lowest location on the A pill, you get less kickup (9 degrees). The upper arm pills are independent of the lower A pills - sort of.
The Kyosho Setting Guide is a good read - pay particular attention to when you run less kickup on the A pill - you run the 9 bushings in the correct orientation on the upper hinge pin front locations (instead of the normal L and H pills). That is the only time you need to adjust the upper hinge pin location when you adjust the lower hinge pin location.
The reason you do this is because you want to keep the upper and lower hinge pins parallel on a c-block suspension so nothing binds up.
When you run the H pill versus the L pill, you install the H pill but must also flip the rear pills so the holes are on the top now. Running H versus L lowers the front roll center, giving the front end more freedom to roll - it typically is felt getting into corners, and helps the front end get into the corner a little better.
Hope this all makes a little sense...
AZRC4Me is offline
Old 12-27-2012, 12:27 PM
  #12641
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
If you change the front upper arms in the upper position, as opposed to the lower position, you are changing front roll center. Rasing the upper arms lowers the roll center. A lower roll center increases the distance (or moment arm) between the roll center and the center of gravity. Lower roll center makes that end roll more.
The lower position gives you a higher roll center, or less distance between the roll center and the COG, causing less overall roll.
SEF is offline
Old 12-27-2012, 12:38 PM
  #12642
SEF
SEF's Avatar
Interestingly, the Hudy setup guide
www.teamxray.com/teamxray/showfile.php?file_id=4461
The The Guide by JQ
http://jq-products.com/the-news/43-t.../160-the-guide
have two contradictory statements about front roll center and the front upper link. I believe in this case, the Hudy setup guide is actually incorrect and The Guide by JQ is correct.
Higher roll center causes more initial steering and faster steering response, but less traction later in the turn all because the chasses rolls less.
Lower roll center causes more chassis roll. It may feel lazy especially when you have several quick turns because the chassis rolls more, but you will tend to get more traction from mid to exit steering.
SEF is offline
Old 12-27-2012, 04:49 PM
  #12643
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
Does anyone run the DE rear skids? Any feedback? Thanks
GMS_Racing is offline
Old 12-27-2012, 05:05 PM
  #12644
jmackani's Avatar
The The Guide by JQ
Yeah, the offroad guide by Hudy has it backwards. They have it right in the touring car guide though.
jmackani is offline
Old 12-27-2012, 05:50 PM
  #12645
I am looking at picking up a TKI3 buggy come January.
Does anyone think I should hold off incase they release a worlds version?
RiPPeN302 is offline
