Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 12-24-2012, 05:26 PM
  #12586
thebizz's Avatar
Trader Rating: 52 (100%+)
Can somebody tell me if the rear outer hinge pin is 3mm or 3.5mm in diameter?
thanks
thebizz is offline
Old 12-24-2012, 05:37 PM
  #12587
Trader Rating: 6 (88%+)
Question about the setting bushings.....
on the setting guide it displays a H bushing and L bushing.
is this referrig to the bushings in the front shock tower and that reflects the way you install the rear toe bushings???
Drip is offline
Old 12-24-2012, 06:16 PM
  #12588
sodi's Avatar
The bushing works as follows
H = high roll chassis in the lowest position arms in the high position
L= low roll chassis in the highest position arms in the lowest position
Follow the book and look each bush has a dot on it check the manual to see we're the dot is positioned and it will help you through.
Front front top H bush dot on top
Front back top centre dot
Front front bottom centre dot
Front bottom back dot to the out side
So front top is running high roll chassis low
Rear of the car
Bottom rear toe plate no3 dots opposite bottom left on right rear bottom right on left rear.
Front bottom centre holes
Just the way I have set it up as per manual
Brett
sodi is offline
Old 12-24-2012, 06:24 PM
  #12589
Default outer hinge pins
thanks
The rear outer hinge pins are 3.5 mm diameter...
Walid
walidelagamy is offline
Old 12-24-2012, 06:59 PM
  #12590
Trader Rating: 25 (100%+)
Originally Posted by sugelle
Ok...sounds like I need to put the shim back in and let gears wear in after running a bit.
I have had all the MP9's and nothing has changed right up to now. Just put together another TKI3 and if anything the diffs we're a little less tight with the one shim in but still slightly tight. After 5 mins on the track the diffs are as free as. Any good grease will do but I have found the Eureka lube to be a fantastic product and you only need just enough to wet the gear teeth. I have never had to replace a pinion or ring gear ever.
smelly62 is offline
Old 12-24-2012, 07:04 PM
  #12591
rfleck's Avatar
Trader Rating: 58 (100%+)
Raced this weekend and continue to be impressed with this car. Second race with the tki3. Driving this car is actually fun (after dialing it in for a different track than last week which was easy BTW) because I was not changing the car in between rounds based on track conditions. Not used to that. Spent more time trying to get a buddy of mine tuned in to my old car then focusing on mine.
Glad I joined the Red Army, Merry Christmas!!!
rfleck is offline
Old 12-24-2012, 07:16 PM
  #12592
jpz_67's Avatar
Trader Rating: 56 (100%+)
I told ya brutha. Merry Christmas to all.
jpz_67 is offline
Old 12-24-2012, 07:22 PM
  #12593
Trader Rating: 16 (100%+)
Rear toe bushing and/or setting has absoutely zero effect or bearing on what setting is chosen for front roll centre (the H and L bushings you mention).
Rear of the car
Brett
I'm not sure what you're trying to say when you mention "chassis in the highest/lowest position" as the front upper arm bushing (H and L) have zero effect on the height of the chassis. There is only one single thing which can change the chassis height and that is the shock spring collars, for setting ride height. Other than that, there's nothing else which can change the height of the chassis from the ground.
Check or measure for yourself, if you have the H or L upper arm bushing, the height of the chassis will remain unchanged. It's not possible for the chassis to move just by changing the height of the (front or rear) camber links.
Also, not every bushing has a dot on it, probably only about half of them do. The rest, one just has to look carefully and judge where/how high the hole is.
aaron125 is offline
Old 12-24-2012, 07:49 PM
  #12594
eper's Avatar
Trader Rating: 14 (100%+)
merry christmas everyone
eper is offline
Old 12-25-2012, 02:36 AM
  #12595
setanborneo's Avatar
Merry Christmas Red Army
setanborneo is offline
Old 12-25-2012, 03:55 AM
  #12596
sodi's Avatar
Merry Xmas to all
Kyosho today kyosho forever.
sodi is offline
Old 12-25-2012, 07:19 AM
  #12597
Merry Christmas.
C. Nutz is offline
Old 12-25-2012, 09:06 AM
  #12598
Merry Christmas
smelly62 is offline
Old 12-25-2012, 09:07 AM
  #12599
Trader Rating: 128 (100%+)
Originally Posted by Retired09
Anybody know the total caster angle on the front of the TKI3 with the alum c-hubs and the zero insert.
With a protractor, I'm measuring about 22-23 degrees. Does this make any sense?
Did I miss the answer or was it posted somewhere?
I'd like to know as well compared to the new 16 degree ones coming out.
BTW, Merry Christmas everyone!
Neesh is offline
Old 12-25-2012, 09:13 AM
  #12600
RC-BATT's Avatar
Merry Christmas all
RC-BATT is offline
