Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 12-23-2012, 05:12 PM
  #12556
eper's Avatar
Trader Rating: 14 (100%+)
Originally Posted by silvalis
outer pins too?
i havent bent an outer but i do keep a set on hand. but i am also running plastic blocks and hubs.
eper is offline
Old 12-23-2012, 05:26 PM
  #12557
mjealey's Avatar
Originally Posted by mjealey
Hey guys, I just want to double chaeck something. It looks like Cody King's 2010 Worlds setup he is running a long wheelbase. In other words their is a 4mm spacer in the front and 1 mm in the back so the hub in toward the rear of the a-arm correct?
http://www.infernosonly.com/v/vspfil...MAR_Worlds.jpg
So just to ask again, most are running the hubs to the rear for a longer wheelbase?
mjealey is offline
Old 12-23-2012, 06:29 PM
  #12558
yes
RePeTe is offline
Old 12-23-2012, 06:35 PM
  #12559
jose valadao's Avatar
Check this deal on the tki3 kits plus motor
http://toprcsupply.com/combo-kyosho-...-ori80678.html
jose valadao is offline
Old 12-23-2012, 07:19 PM
  #12560
sugelle's Avatar
Trader Rating: 63 (100%+)
Default TKI3-shimming diffs?
Need some advice. I'm presently building a TKI3 kit and working on rear diff. The instructions call for 1 shim to be placed over the outdrive on the ring side of rear diff. When I assemble the case, the diff feels really notchy and tight. Is this shim required? I removed it and diff spins really smoothly but not sure if this would cause issues without shim?
sugelle is offline
Old 12-23-2012, 07:27 PM
  #12561
mjealey's Avatar
I did not use one when I built the kit both front and rear and have had no problems. They are not needed in my opinion and mine are perfectly smooth with not too much play without it!
mjealey is offline
Old 12-23-2012, 07:34 PM
  #12562
gameholic2's Avatar
Yeah... that price is in euros 858euros = 1000+ dollars lol
gameholic2 is offline
Old 12-23-2012, 08:21 PM
  #12563
sodi's Avatar
Guys kyosho Europe are the kings on deals tki3 with nova 4btt and matching pipe it came to my door for $960 aus dollars can't be beaten.
sodi is offline
Old 12-23-2012, 08:36 PM
  #12564
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Default Elliot Boot WC step
How did he get 110m of front droop? Had to be running the medium front shocks, right?
hookem34 is offline
Old 12-23-2012, 09:00 PM
  #12565
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Didn't need to shim front or rear initially. After some running, I needed to shim the rear diff. So check your mesh for excessive play and shim accordingly.
SEF is offline
Old 12-23-2012, 09:02 PM
  #12566
Coach Townsend's Avatar
call me tomorrow or bring it to smac Thursday
Coach Townsend is offline
Old 12-23-2012, 09:17 PM
  #12567
sugelle's Avatar
Thanks. Coach! I'll call you in morning
sugelle is offline
Old 12-23-2012, 10:03 PM
  #12568
Jammin57's Avatar
Trader Rating: 120 (100%+)
No... It is US dollars $858 with FedEx free shipping
Jammin57 is offline
Old 12-23-2012, 10:11 PM
  #12569
Trader Rating: 21 (100%+)
Is this place legit??
EastTxRacer is offline
Old 12-23-2012, 10:55 PM
  #12570
Hey guys, last time on track car felt a bit nervous rear was planted. I have been trying to think of a way to help prevent this. Is this some thing that would be best addressed with radio settings. I am running kings setup but with 6k in the center. Any advice would be greatly appreciated!
Speedracer1600 is offline
