Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 12-17-2012, 11:32 AM
  #12451
Default REAR WIEGHTS FOR MP9/TKI SERIES BUGGIES
M2C RACING is pleased to announce the release of our brass weight kit for the
PMP9/TKI SERIES buggies. these weights are made of brass and come in
5 and 10 gram weight. they can be combined to add up to 15 grams to the rear end per side. They bolt to the existing mud guard holes. these weights add unsprung weight to the rear end for added traction and help with foward bite.
part no. m2c2960
http://m2cracing.com/searchquick-sub...ywords=m2c2960
m2cracing is offline
Old 12-17-2012, 12:53 PM
  #12452
adrictan's Avatar
part no. m2c2960
Order placed for a set to try.
adrictan is offline
Old 12-17-2012, 06:00 PM
  #12453
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
Was Elliot Boots running the KYOSHO cab forward body?
GMS_Racing is offline
Old 12-17-2012, 07:03 PM
  #12454
Originally Posted by eddie10
Any word on a tki3 e buggy coming. Mp9e near impossible to find anywhere now.
most guys are converting tki3's to electric. No one has really said that they are going to come out with another ebuggy
evolution03 is offline
Old 12-17-2012, 07:36 PM
  #12455
AZRC4Me's Avatar
I believe so...
AZRC4Me is offline
Old 12-17-2012, 08:08 PM
  #12456
Trader Rating: 26 (100%+)
I was just going to convert but the conversion kits are out of stock everywhere as well
eddie10 is offline
Old 12-17-2012, 08:20 PM
  #12457
THE PHILLY JYNX's Avatar
http://www.absolutehobbyz.com/produc...oducts_id=1115
THE PHILLY JYNX is offline
Old 12-17-2012, 08:23 PM
  #12458
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Anyone got a spare TKI2/3 chassis they want to sell? If so, PM please. Thanks!
hookem34 is offline
Old 12-17-2012, 08:31 PM
  #12459
I DO...
Old 12-17-2012, 09:11 PM
  #12460
HH
HH's Avatar
Default TKI3 Chassis
The chassis that came in my TKI3 kit has kind of a dark bronze color to the anodizing and is 3mm thick exactly (which is typical for aluminum manufactured outside of the USA). The anodizing was almost completely worn off the bottom of this chassis after the first race day and it seems to have an abundance of flex to it. In fact whenever I race at night you can see sparks shooting out the bottom in those sections of the track that cause the chassis to flex severely (yes.. my mesh is proper and I have the chassis drilled below the clutch bell ). Sometimes the sparks are so large that if my pit guy was to get a little sloppy when refueling me, it could easily ignite the spilled fuel.
However.. with this chassis my buggy is totally hooooked-effin-up!
I had heard the replacement chassis KYOIF473 was more durable than the kit chassis with better quality anodizing etc... so I picked one up. The anodizing is kind of a light golden/tan color on this chassis and it measures 3.18mm thick (which equals .125" or 1/8" and is typical for aluminum manufactured in the USA ). After one practice session and a full race day with this newer chassis the anodizing on the bottom is barely even scratched and there haven't been any sparks shooting out the bottom from grinding the clutchbell either.
However.. with this chassis my buggy just doesn't feel hooked-up like it did with the kit chassis . I've found myself searching for setup changes to compensate for the lack of traction. That never even came into consideration with the original chassis.
My question is... Has anyone else had this problem? and if so, have you found a remedy for it??
HH is offline
Old 12-18-2012, 01:06 AM
  #12461
Trader Rating: 25 (100%+)
I always thought the replacement chassis was stiffer. Never thought to measure the thickness, always put it down to the hard anno making it stiffer.
I bet everyone has run off to measure their chassis now LOL.
Tebo used to run the TKI chassis which is even stiffer, not sure if he still does??
smelly62 is offline
Old 12-18-2012, 02:28 AM
  #12462
malcnz's Avatar
This is the main reason i wouldnt go back to kyosho as they off load the crappy brown anodizing in the kit and charge you the earth for doing so and then try to tell you the aftermarket kyosho alloy parts with the lighter golden anodizing is the same..yeah right
malcnz is offline
Old 12-18-2012, 03:03 AM
  #12463
Trader Rating: 16 (100%+)
It's physically impossible for the anodic layer applied to the chassis to have any effect on the overall torsional stiffness or stiffness in any direction. It is only a absolutely incredibly thin layer on the very outside of the chassis or any anodized item, therefore it is not at all possible for the anodic layer itself to have even the slightest increase or benefit when it comes to the stiffness of the chassis. Absolutely same thing goes for the shock towers and any other MP9 part which is available in the kit brown
anodizing or the spare parts gold anodizing.
The easiest way to think of what anodizing is, would be to think of it as a 'kind of' rust. Of course, it's not an oxidization layer but apart from that, they're conceptually similar, to a degree.
And the only difference between hard anodizing and regular anodizing is the temperature and the voltage applied to the acid bath while performing the actual anodizing process and sometimes the degree of acidity/pH level.
One might notice slightly improved scratch resistance from hard anodizing, but as has been stated many times before today, the anodic layer itself isn't physically able to increase the stiffness or strength of the item being anodized.
Even Mr King elobarated on this very topic some months ago in this forum. No idea what page number though.
Believe what you want but it is such a tiny amount of money involved to make a chassis or other alloy part anodized versus hard anodizing it. Finances are almost never a determining factor as to whether something is anodized or HA. Surface scratch resistance, electrical insulation, sometimes chemical insulation, but I've never heard of a company saying "we'll just regular anodize this batch of parts because we'll save about 1/100th of a cent per anodized chassis and perhaps we might save 1/1000th of a cent if we regular anodize something like the suspension braces, rather than HA them".
I've never understood why most people seem to think than HA is a more expensive process to perform than regular anodizing because the differences are so tiny it's for all intents and purposes irrelevant.
aaron125 is offline
Old 12-18-2012, 03:12 AM
  #12464
malcnz's Avatar
If that is true then and there is really no cost difference why dont kyosho include the golden HA anodizing in their kits as std? i see tebo, king etc seem to run it std so why cant it be included std?
malcnz is offline
Old 12-18-2012, 04:19 AM
  #12465
juninho_foz's Avatar
Uploaded with ImageShack.us
juninho_foz is offline
