Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 12-15-2012, 05:21 PM
  #12436
Pete Martinez's Avatar
Trader Rating: 17 (100%+)
Originally Posted by turbo scorpion
I say AMEN to that!!! Kyosho doing remakes would be awesome!!!
Though collectors will be ticked when the values of their vintage cars plummets...
did you see the "new scorpion" Its 1/7th scale i think...
and dont forget the first ultima, first lazer, and USA-1
Pete Martinez is offline
Old 12-15-2012, 06:24 PM
  #12437
jmackani's Avatar
Trader Rating: 14 (100%+)
What spare hardware likes screws,spacers, etc. and such are good to keep on hand?
jmackani is offline
Old 12-15-2012, 06:28 PM
  #12438
Guest
i got 1 pack of all the shims for the clutch. and 1 pack of extra shims for the alxes.
LOSIRACER77 is offline
Old 12-15-2012, 06:33 PM
  #12439
Ya i love old kyoshos. my first was a TS (like duh if u didnt see my SN) I have an old OPTIMA turbo (need to redo some stuff but think its all there). a Turbo Ultima, and an Ultima II.
Iv wanted a USA 1 since I was a kid but worry about parts availability... (it took 2 years to land shocks for my TS!!!)
a Blizzard or Heavy Metal is at the top of my list too.
Kyosho had the innovative designs and the build quality was just fantastic.
Had a certain beauty in form and function...
turbo scorpion is offline
Old 12-15-2012, 07:05 PM
  #12440
the good old days
Old 12-15-2012, 08:19 PM
  #12441
the good old days
are the new Kyosho still as good as in the old days? i was thinking to get a ultima sc truck...not so much to race as to run for fun...
Old 12-15-2012, 09:43 PM
  #12442
Originally Posted by AZRC4Me
The only thing I would buy outside of the kit is 1.3x8 straight hole pistons. You need two packs (2 pistons in each pack, IF347-138). And maybe some additional springs like orange f/r, grey fronts, green and/or yellow rears - you want the 84mm rear springs, the Medium length, 1.4 diameter wire. Other than that, you don't need any aluminum "option parts" because they all come in the box as standard. The only parts that aren't aluminum and have aluminum options, are the upper front hinge pin holder, and the front caster blocks, but both are not needed from the get-go whatsoever. (IFW406 is the hinge pin holder, and IFW412 are the caster blocks). I would suggest building the car box-stock except for the shock pistons, then put Cody's 2010 worlds setup on the car as a base and tune from there.
Thanks for the quick reply. Would you recommend Orion motors or OS? Also, Your profile says you live in fullerton? Is 1/8th scale racing popular there? I guess Cody's setup is the go to huh? Seems like what most people are running here.
rcnewb123 is offline
Old 12-16-2012, 07:09 AM
  #12443
yes anything of the kits out know are ever better than ever u cant go wrong with the ultima sc or any other of the kits that r out now like the 22CT or SC10 i have ran them all and they r all great SC trucks.
Old 12-16-2012, 07:35 AM
  #12444
Os motors are overpriced and they aren't lasting very long for some guys. The Orion motors are very finicky but they run great if you can get tune right. I wouldnt buy either one. I would buy a novarossi or a alpha
evolution03 is offline
Old 12-16-2012, 09:13 AM
  #12445
Its very hard to tune the orion right!!! OS ist easy.
Michael
iwillresist2008 is offline
Old 12-16-2012, 09:38 AM
  #12446
Michael
os is the easies and orion is harder but if u finder the sweet spot your good with both. or the nova the smoothes motor out of all the motors
Old 12-16-2012, 10:44 AM
  #12447
Imcaracer20's Avatar
ive been running os for awhile now, gotta say great power and super reliable... my current speed has 12 gallons on it and going strong
Imcaracer20 is offline
Old 12-16-2012, 03:38 PM
  #12448
Trader Rating: 26 (100%+)
Any word on a tki3 e buggy coming. Mp9e near impossible to find anywhere now.
eddie10 is offline
Old 12-16-2012, 09:40 PM
  #12449
Trader Rating: 21 (100%+)
Does anyone run the rear aluminum chassis brace? Is it worth the money?
EastTxRacer is offline
Old 12-17-2012, 12:27 AM
  #12450
Trader Rating: 16 (100%+)
No and no. Those are the quick and easy answers.
If you're really keen to try one, I have an almost new King Headz rear alloy chassis brace which I'd sell you for next to nothing, I've had it for at least 18months and used it perhaps 3 times, maybe just 4, can't remember.
But if you're really keen on the idea, let me know and I'll give you a great price on it.
aaron125 is offline
