Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 12-14-2012, 01:42 PM
  #12421
AZRC4Me's Avatar
Originally Posted by Neesh
I was just about to pull the trigger on a front and rear tki2 silver set from amain, but gotta wonder now. will the new shorter shock caps come with them or are they still the older long ones? I assume it will be the longer ones since these came out before the tki3? Whats the performance difference between the two?
The only shock sets that came with the taller shock caps are the older smooth body velvet shocks. The new threaded bodies all use the short caps. Honestly, unless you're running the outer holes in your arms, they really aren't necessary, and you'd be hard pressed to notice any tangible difference in lap times on track with them. More droop = longer shock shafts required = more up-travel = need room for piston to go at full compression.
I don't mean to imply you'd need to purchase longer shock shafts to achieve more droop, just that you'd need to unscrew the shock end some to lengthen the shock stroke.
AZRC4Me is offline
Old 12-14-2012, 05:39 PM
  #12422
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Default 80460 Kyosho Ultimate Pit Box DX
Anybody own or use this? Thoughts?
hookem34 is offline
Old 12-14-2012, 06:00 PM
  #12423
Trader Rating: 128 (100%+)
Thanks Sean
Neesh is offline
Old 12-14-2012, 06:01 PM
  #12424
SteveP's Avatar
My guess is the short caps were included on the threaded shocks to compensate for the extra thickness of the threaded adjuster, so the spring pressures and handling characteristics remain the same. Basically so the pre-load and ride height is the same with the threaded adjusters all the way at the top as the non-threaded shocks without any pre-load spacers.
SteveP is offline
Old 12-14-2012, 06:22 PM
  #12425
HH
HH's Avatar
You can always browse the parts lists at Kyosho.com and it shows exactly which models come with the KYOIF470-02 (short cap) or the KYOIF346-02 (taller cap).
As Sean mentioned ... the TKI2 and TKI3 definitely included the KYOIF470-02 shock caps.
HH is offline
Old 12-14-2012, 06:26 PM
  #12426
McD44's Avatar
Trader Rating: 16 (100%+)
Seems like an insane waste of money for something that I could get at a local hardware store for 1/4 of the price.
McD44 is offline
Old 12-14-2012, 06:44 PM
  #12427
hookem34's Avatar
Very true, but the compartments are exactly as rc specific as Kyosho. I wonder who private labels this for Kyosho?
hookem34 is offline
Old 12-14-2012, 07:23 PM
  #12428
Guest
plano???? they make the fishing tackle boxs.
LOSIRACER77 is offline
Old 12-14-2012, 10:49 PM
  #12429
I am about to purchase the TKI3...I am wondering what alum parts come with the kit? And which parts will I need to buy? I want to build this car with all of the option parts. thanks.
rcnewb123 is offline
Old 12-15-2012, 01:45 AM
  #12430
AZRC4Me's Avatar
Yeah, that makes perfect sense Steve.
Dude, that's the same thing people use as an argument to not buy an MP9...c'mon, it's Kyosho, you know it's going to be super sick and of the highest quality. I've actually been eyeing it for some time and might get it just because I've never seen anyone with one.
Kyosho boxes put Plano to shame, they definitely are not Plano. I've done a lot of digging because some were out of stock at Kyosho America for a while and I was impatient, but I couldn't find the same ones anywhere.
The only thing I would buy outside of the kit is 1.3x8 straight hole pistons. You need two packs (2 pistons in each pack, IF347-138). And maybe some additional springs like orange f/r, grey fronts, green and/or yellow rears - you want the 84mm rear springs, the Medium length, 1.4 diameter wire. Other than that, you don't need any aluminum "option parts" because they all come in the box as standard. The only parts that aren't aluminum and have aluminum options, are the upper front hinge pin holder, and the front caster blocks, but both are not needed from the get-go whatsoever. (IFW406 is the hinge pin holder, and IFW412 are the caster blocks). I would suggest building the car box-stock except for the shock pistons, then put Cody's 2010 worlds setup on the car as a base and tune from there.
AZRC4Me is offline
Old 12-15-2012, 11:07 AM
  #12431
Dusttt's Avatar
Trader Rating: 144 (100%+)
can some one point me to a list of parts needed to convert a tki2 to a tki3 please
Dusttt is offline
Old 12-15-2012, 01:51 PM
  #12432
adrictan's Avatar
http://redarmyandme.wordpress.com/2012/04/11/new-parts-for-mp9-tki-2-or-should-i-call-it-tki-3/
adrictan is offline
Old 12-15-2012, 03:26 PM
  #12433
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
Looking at a lot of the setup sheets it seems everyone always runs the 8 hole for the camber link on the rear tower, what would going up achieve or change...thanks.
GMS_Racing is offline
Old 12-15-2012, 03:37 PM
  #12434
Dusttt's Avatar
Gracias
Dusttt is offline
Old 12-15-2012, 05:10 PM
  #12435
Originally Posted by freefallmarine
Oh, while im still here in "Wish Kyosho Would" land. How about Re release some of the early K cars from the good ole day's.? I would love to have a Vanning, Turbo Burn's, Optima MKII Scorpion!!! You know Tamiya is making a killing re releasing there older kits. Man im really showing my age...
I say AMEN to that!!! Kyosho doing remakes would be awesome!!!
Though collectors will be ticked when the values of their vintage cars plummets...
did you see the "new scorpion" Its 1/7th scale i think...
turbo scorpion is offline
