Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 12-08-2012, 08:01 AM
  #12271
AZRC4Me's Avatar
There was someone a few pages back asking about shimming the ackerman plate. I tried looking for the post, but there's a whole bunch of junk the last handful of pages...
Anyway, if the ackerman plate is old, it might need to be replaced. The steel bushings will oval out the aluminum ackerman plate over time - it's just the nature of the components (steel on aluminum). It would be a long time though, like a season's worth of racing. But, if it's relatively new, you want to add some shims onto those pins that bolt the ackerman plate to the servo saver and steering link. The way it's designed, there's a step in the pin that keeps you from overtightening it and binding the steering. Just add a few shims on the top side, and it should allow you to snug it up. I hope that makes sense, kind of hard to explain.
AZRC4Me is offline
Old 12-08-2012, 08:03 AM
  #12272
AZRC4Me's Avatar
Originally Posted by kurtblastoff
I drive all AE products. there 1/10 scale cars are dialed and dominate. The 1/8 is another story I had a 8.2 and sold it because no matter how hard I tried I could not get the ass end to hook up. The 8.2 needs some serious R&D. Until they get it figured out I will not run 1/8 or go to a different brand.
I'd welcome you to try an MP9 - grab a buddy's and wheel it for a few laps, see what you think of it. If you're in the SoCal area, I'd be happy to hand you my transmitter and let you run a few tanks on mine.
AZRC4Me is offline
Old 12-08-2012, 08:27 AM
  #12273
Originally Posted by ratjayfala
Anyone got any suggestions on what to use to hold the exhaust to the car? I've tried using an old wire coat hanger but it aint strong enough and I don't have the wire that came with the kit.
I use an old L-shaped hex wrench...
jackinabox is offline
Old 12-08-2012, 08:54 AM
  #12274
McD44's Avatar
Trader Rating: 16 (100%+)
I'll ask against since it probably got lost in all the Scheiße reden.
What is the purpose of the set screw plugs in the f&r diff housings?
McD44 is offline
Old 12-08-2012, 09:00 AM
  #12275
Trader Rating: 128 (100%+)
its so yo can install the cross pin through the outdrive, then plug the hole with the set screw
Neesh is offline
Old 12-08-2012, 09:09 AM
  #12276
McD44's Avatar
No kidding. I never needed it. They should put one on the other side and offer a syringe attachment for fast fluid changes. It wouldn't be as effective as taking it apart and cleaning it but you could freshen it up without taking it apart.
McD44 is offline
Old 12-08-2012, 10:33 AM
  #12277
drstrangelove's Avatar
Sad day for Kyosho
drstrangelove is offline
Old 12-08-2012, 11:00 AM
  #12278
freefallmarine's Avatar
What Happened???? Do they not have a car in the Main?
freefallmarine is offline
Old 12-08-2012, 11:06 AM
  #12279
WOW, Boots, Aigoin AND Tebo dropped due to non chassis failures! Tebo with a broken arm but probably because he was pushing hard after his flameout.
Neesh is offline
Old 12-08-2012, 11:26 AM
  #12280
simon0721's Avatar
Only King (P6) and Ronnefalk (P10) in the final for Kyosho. Tessman on pole, followed by Batlle and Hara.
simon0721 is offline
Old 12-08-2012, 11:41 AM
  #12281
Man, would've been a dogfight with Tebo, Boots, Aigoin, Savoya and Cav in there.
Neesh is offline
Old 12-08-2012, 12:00 PM
  #12282
Please keep me posted guy's i see that live rc is having issues there.
Old 12-08-2012, 12:03 PM
  #12283
Oh, and Go Cody and David!!!!!
Old 12-08-2012, 12:07 PM
  #12284
juninho_foz's Avatar
Place first regional championship ....Paraná , Brazil
Uploaded with ImageShack.us
juninho_foz is offline
Old 12-08-2012, 12:09 PM
  #12285
Durocken's Avatar
Im thinking they should have put associated parts on them buggies, prolly wouldnt have broke.
Durocken is offline
