Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 12-03-2012, 08:12 PM
  #12151
AZRC4Me's Avatar
Originally Posted by BIGTIME
Sean we actually have pitted next to each other a few times, you were suppose to drill my front hub carriers for me but I think you got busy at work. Maybe you remember my car.
Hmmm...it looks familiar, and I do remember saying I'd do that for someone. In all honesty, I didn't really like how that ended up feeling, too much rotation.
What BigTime is referring to, is a time last year I was running a drilled plastic c-hub in the front. The hole I drilled is in the middle of the two holes, but lower. It allows you to run the L bushing, but still lower your front roll center to get the car to rotate harder into the corners. I went back to the standard inner hole and liked it better. I'll still drill em for you if you want though , sorry about that!
Here's some Kyosho porn:
http://youtu.be/ByRjQn6aD6E
If that's not a dialed looking car, I don't know what is. ZOMG!
Yep, still at work...ugggh, 5:45am till now...super hurting.
AZRC4Me is offline
Old 12-03-2012, 08:26 PM
  #12152
BIGTIME's Avatar
Trader Rating: 116 (99%+)
That car looks planted...Geez!
BIGTIME is offline
Old 12-03-2012, 08:40 PM
  #12153
houston's Avatar
Trader Rating: 96 (100%+)
looks like a kyosho to me
houston is offline
Old 12-03-2012, 08:56 PM
  #12154
Trader Rating: 51 (100%+)
When did Cody Smith jump to a K car?
Cyberacer is offline
Old 12-03-2012, 09:00 PM
  #12155
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Wow, Boots running the fastest laps, along with several other fast guys (Ronnefalk and others not running Kyohso), with AKA Moto tires Either this is a big joke, or the World's track is insanely different from anything any pro has run.
It does look like the Moto is a solid tire at the World's after seeing the Lutz and Pavidis interviews on neobuggy. Even if that tire does win the worlds, I don't see myself buying them for my tki3 for my local track
SEF is offline
Old 12-03-2012, 09:11 PM
  #12156
AZRC4Me's Avatar
Just after the Kyosho race at Rev. Came back home lol.
Who knows what tire will work after the track possibly gets drenched tonight. Could be anyones guess. But the end of the week/weekend is supposed to be dry, so I'm not sure that tire will be the fastest. Boots also was quicker on other tires later. Phend and Ty look solid on the Pro-Line rubber, I'm guessing the track is going to change and favor smaller pins (than that other tire, like Blockades, Big Blox) towards the end of the week/weekend. Just a hunch.
AZRC4Me is offline
Old 12-03-2012, 09:22 PM
  #12157
oghobavo's Avatar
7k in the front, what are you all using for the center and rear? My base is nearly always 7k front, and 5k in the rear. The center diff is the wildcard ranging from 7-12k....
oghobavo is offline
Old 12-03-2012, 09:28 PM
  #12158
AZRC4Me's Avatar
I've run 7/5/4 before, but didn't like it that much. I have also run 6/4/4 before, but that was only marginally better than 5/5/3. Right now, I'm on 7/5/3, and might try 7/7/3, but only on higher speed smoother tracks. I like the 7/5/3, it has very nice balance to it, and great pull out of the corners. Stuff like Revelation that gets blown out, 5/5/3 is pretty solid. But I'm experimenting so we'll see.
I usually default to something that's easy to drive over ballistic fast, as over the course of a long main it's easier to be consistent with an easy to drive car. Which is why I haven't gone higher in the center diff, but I'll try it out soon just to see how I like it.
AZRC4Me is offline
Old 12-03-2012, 11:34 PM
  #12159
ben73's Avatar
Trader Rating: 40 (100%+)
boots with 2 wheels to rail slide on the concrete sweeper.... awesome footage
ben73 is offline
Old 12-04-2012, 11:37 AM
  #12160
savageboy69's Avatar
Trader Rating: 93 (100%+)
u look like a kyosho
savageboy69 is offline
Old 12-05-2012, 12:43 AM
  #12161
drstrangelove's Avatar
Jared interview...
+ YouTube Video
drstrangelove is offline
Old 12-05-2012, 04:37 PM
  #12162
McD44's Avatar
Trader Rating: 16 (100%+)
I'm surprised no one has mentioned Boots' insane TQ time in RD5. 13 second ahead of second place!!! Amazing!
McD44 is offline
Old 12-05-2012, 05:31 PM
  #12163
setanborneo's Avatar
he is very fast
setanborneo is offline
Old 12-05-2012, 05:42 PM
  #12164
Anyone has any updates on Cody? He's having a rough time there and looking so disappointed with himself yesterday.
Old 12-05-2012, 05:45 PM
  #12165
I miss that one man, was piss off with losing the coverage again and having bad migraine so end up falling asleep. If anyone have access to the video, do share.
