Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 11-27-2012, 04:43 PM
  #12046
Afun's Avatar
Trader Rating: 19 (95%+)
Originally Posted by LOSIRACER77
i got also most 2 gallons on the stock shoes and the 9.5 springs.
Changed my shoes at 5 gallons just the other day. I could still use those shoes by shaving down the burs. But I decided to go new. I am going to use those in a back up motor. Quality stuff.
Afun is offline
Old 11-28-2012, 05:14 AM
  #12047
Trader Rating: 16 (100%+)
i just ordered this one http://www.infernosonly.com/Racer_s_..._p/rce7074.htm
but befor this piece i used a small screw driver or needle nose pliers. i hope this works
Those clutch tools definitely make installation and removal of clutch shoes and springs a heap easier than using a screwdriver. And a million times faster, too.
Until about a year ago, when I managed to find one of these style clutch tools built entirely from alloy, rather than plastic, which most brands use, I think I went through maybe 1/2 dozen of the plastic tools of various brands, always cracking the tool at the point of highest load. Found the all alloy version on ebay and never looked back.
But even the plastic version is still a lot more convenient than using a screw driver or pliers.
aaron125 is offline
Old 11-28-2012, 04:12 PM
  #12048
oghobavo's Avatar
Anyone know where I can get a wrap for the new cab forward kyo body?
oghobavo is offline
Old 11-29-2012, 12:44 PM
  #12049
sugelle's Avatar
Trader Rating: 63 (100%+)
Anyone using this King Headz EZ Change motor mount on TKI2 or 3? Any issues?
http://www.amainhobbies.com/product_...Mount-Extended
sugelle is offline
Old 11-29-2012, 01:10 PM
  #12050
McD44's Avatar
+1 my stock mount's threads are getting sketchy...
McD44 is offline
Old 11-29-2012, 01:43 PM
  #12051
rallyebmx's Avatar
Trader Rating: 21 (100%+)
I've used that as the only mount since I've had my tki3. No issues. At the fear farm track the few locals with kyo biggies were having trouble with spur/bell. They solved this with extended mounts
rallyebmx is offline
Old 11-29-2012, 05:08 PM
  #12052
rfleck's Avatar
Trader Rating: 58 (100%+)
Given the maturity of the MP9 platform, any estimates on a new car since the world's is right around the corner? I have a TKI3 arriving tomorrow.
rfleck is offline
Old 11-29-2012, 06:17 PM
  #12053
jonw's Avatar
You haven't seen the pics? It's all new!!!! You better send it back and get the new one haha. Just messing with ya Ron.
jonw is offline
Old 11-29-2012, 09:06 PM
  #12054
J33
J33's Avatar
J33 is offline
Old 11-29-2012, 09:32 PM
  #12055
Guest
I can't say anything bad about the kyosho, its the best buggy that I have ever drove. I came from losi. And I will never look back. I am still on the kit bearings in the clutch, this buggy is amazing. On my home track with the losi, most of the time i was 3-4 laps down,I was never able to stay on the lead lap, with the tki3, I am able to stay on the lead lap with the book setup.
LOSIRACER77 is offline
Old 11-29-2012, 09:42 PM
  #12056
Guest
I would start look for a tki3 wc about a month after we win the worlds.
Old 11-30-2012, 02:44 PM
  #12057
erc55's Avatar
my TKI3 that I just finished building has a binding front suspension. Is this normal for this car?
erc55 is offline
Old 11-30-2012, 02:58 PM
  #12058
AZRC4Me's Avatar
Default binding suspension
No it's not. Make sure you didn't tighten the hinge pin holders too tight or they will bind the arms. Without shocks, your arms should freely move without any binding.
AZRC4Me is offline
Old 12-01-2012, 05:02 AM
  #12059
Gixer Jay's Avatar
Aaron, is the one you have made my ProTek? I too have gone through about half dozen of those plastic versions and I've actually been looking for almost a year for that alloy version. Amainhobbies use to carry it, but not any longer? May have had something to do with the patent?
Gixer Jay is offline
Old 12-01-2012, 05:19 AM
  #12060
I got one recently. Will report back once it's installed and I've had a chance to give it a try.
Nope, it's this one here: http://www.ebay.com.au/itm/Clutch-Sh...item2ec3ddd945
aaron125 is offline
