Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 11-24-2012, 10:37 AM
  #12001
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
Originally Posted by AZRC4Me
For sure, that's what I use as my default base setup.
I'm putting together a TKI3 kit right now and I looks like it came with the front hex's all the way around now.
GMS_Racing is offline
Old 11-24-2012, 10:50 AM
  #12002
needs no upgrades they say...
RePeTe is offline
Old 11-24-2012, 11:14 AM
  #12003
my tki3 came with with narrow for rear unless its a running change. Look at them closely
evolution03 is offline
Old 11-24-2012, 11:20 AM
  #12004
Trader Rating: 16 (100%+)
Really? Mine didn't. Are you sure all 4 of the hexes are the thicker ones?
Same here, I don't think anything's changed.
aaron125 is offline
Old 11-24-2012, 01:53 PM
  #12005
Trader Rating: 6 (88%+)
Talking
Alright boys I made the plunge today my car will be here in a couple of days!!! I'm stoked hope it lives up to what I have seen and been told.
Drip is offline
Old 11-24-2012, 03:15 PM
  #12006
AZRC4Me's Avatar
They are correct, it needs no upgrades out of the box. There are tuning options, which change handling of the car, but that's different than upgrades.
AZRC4Me is offline
Old 11-24-2012, 08:13 PM
  #12007
sugelle's Avatar
Trader Rating: 63 (100%+)
Just got a new TKI3 kit and excited to build it. I had a TKI2 WC and remember having to drill a hole in chassis so clutch bell wouldn't hit during chassis flex. Is this needed for the TKI3?
sugelle is offline
Old 11-24-2012, 09:02 PM
  #12008
AZRC4Me's Avatar
The TKI3 is for all intents and purposes the exact same car as the TKI2, with the exception of the radio tray/battery box, and the HD shafts. The handling of the two out of the box is identical (assuming the TKI2 has the battery forward mount). I drill my chassis, don't think it's a big deal but it's good added insurance.
AZRC4Me is offline
Old 11-24-2012, 09:08 PM
  #12009
McD44's Avatar
Drill your chassis? Can you explain?
McD44 is offline
Old 11-24-2012, 09:25 PM
  #12010
Guest
I think Sean is talking about the clutch bell rubbing the chassis, so drill out a hole under the bell so it doesn't rub.
LOSIRACER77 is offline
Old 11-24-2012, 09:46 PM
  #12011
AZRC4Me's Avatar
Yep...Pitpop's original post
AZRC4Me is offline
Old 11-25-2012, 06:13 AM
  #12012
McD44's Avatar
That's what I thought you were referring to. I just bought a replacement chassis for the mp9 that I bought used. The old chassis has the hole, I'll drill the new one too.
Thanks!
McD44 is offline
Old 11-25-2012, 04:47 PM
  #12013
Afun's Avatar
Trader Rating: 19 (95%+)
Originally Posted by LOSIRACER77
U DONT HAVE TO GET THE 93MM JUST YET, I GOT A NEW KIT AND HAVE NOT POPPED 1 OUT YET. I WOULD TELL U TO GET THE 1.3 X 8 SHOCK PISTONS, AND U GOT TO ORDER 2 PACKS, 2 PISTONS IN 1 PACKAGE.
MAYBE THE ORANGE SPRINGS FRONT AND REAR AND THE YELLOW ONLY REAR ONLY.. AND U REALLY DONT HAVE TO BUY THE SPRINGS JUST THE PISTONS
Pitpop recommended the 93mm shafts in the front. Cody is running this set up. When severe flex occurred my 91mm on one side would pop out.
Also, the small engine mount screws below on the chassis, I now use red threadlock. The blue would not work good enough. I wish they would have made the engine blocks smaller so you could fit a lock nut for added security.
I do have a theory with my issues with engine mount screws coming undone. First of all, the screws that go into the engine blocks that come with the kit may not be long enough.. Also, extended use of a competition heat to warm up the engine, may be the cause of these screws coming undone. My Two Cents...
Afun is offline
Old 11-25-2012, 05:52 PM
  #12014
What is the part number theft the 1.3x8 flat pistons everyone is recommending?
Drip is offline
Old 11-25-2012, 06:07 PM
  #12015
Guest
here u go http://www.infernosonly.com/Kyosho_1...oif347-138.htm
