Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 11-22-2012, 08:05 PM
  #11986
Trader Rating: 25 (100%+)
Originally Posted by 151 RACN
ha guy's , does anyone no what motor mounts you have to have to be able to use a lock nut and bolt on the motor mount plate. i seen cody kings car has smaller mounts on his car from last years worlds pics on neobuggy. i must have over tightened one of the the small bolt (stripped plate) that holds to the plate. thanks for any info on this matter. its for the tki3 car
The blocks were released with the TKI3. The standard 6mm bolts are too short and don't go all the way through. I got hold of some 8mm and no probs with stripping threads now. Nuts are good insurance but with a little blue loctite on 8mm bolts they are not required. Also keeping this area of the car as light as possible is good for the balance.
smelly62 is offline
Old 11-22-2012, 08:07 PM
  #11987
smelly62 is offline
Old 11-23-2012, 08:23 AM
  #11988
Trader Rating: 22 (100%+)
Default cheap tki2 on ebay ending soon
http://www.ebay.com/itm/230883925871...84.m1555.l2649
mugen21 is offline
Old 11-23-2012, 04:43 PM
  #11989
mjealey's Avatar
All right guys, I just ordered a kit and will be here Tuesday! I love my OS Speeds so that will provide the power and keep my perfect KO Propo servos I have been running in the Mugen. I ordered the 1.3x8. Pistons, 93mm units for the front, orange springs f/r, and a spare set of arms! Also, a Proline body that I will have Larry at Kustom RC Graphics paint up for me! I am excited for a new challenge and look forward to trying this car! I must say out of the 100's threads I have sen this has been the most informative and well ran threads as it never gets off topic and some of the main Kyosho guys are on this thread unlike many other brands........
With all that being said, I have read every post on the last 50 pages and just want a summary to refresh on some basic build tips and hints????
Also, I will search here in a minute but does the TKI3 come with the narrow or the +2 rear hubs on it?
My paycheck next week will go to the aluminum front hubs......
Thanks in advance and any and all tips would be appreciated!
mjealey is offline
Old 11-23-2012, 04:46 PM
  #11990
mjealey's Avatar
One other thing, I see a lot of guys running the Kcar lose their mesh a lot! The engine mount screws are always coming loose and eating clutch bells. I guess red loctite or what is up with that as I know the engine mount system isn't as conventional as other brands......
mjealey is offline
Old 11-23-2012, 05:12 PM
  #11991
Jammin57's Avatar
Trader Rating: 120 (100%+)
The tki2 and 3 comes with the offset rear aluminum hubs and used the narrow hexes and there is nothing wrong with the mounts I have ran kyosho for years and never had one come loose
Jammin57 is offline
Old 11-23-2012, 05:57 PM
  #11992
mjealey's Avatar
Ok so it comes with the wide on the rear? What is the main handling difference one notices in going to the narrower rear hub setup?
mjealey is offline
Old 11-23-2012, 06:02 PM
  #11993
i think what he is talking about is the hub carriers are 2mm offset in rear. The hex the rim mounts to in rear is considered narrow it makes wheelbase in rear more narrow than the front. Most off the pro guys run the regular hex in rear with narrow track width adjustment. Which is adjustable with pills that insert in the arm.
evolution03 is offline
Old 11-23-2012, 06:08 PM
  #11994
mjealey's Avatar
Oh man I am a little confused but I know it is simple and will make sense once I tear into the kit and build it. I know Mugen through and through and run the +2 rear hubs on it but sounds like the my Paul has more adjustments with the hubs and hexes.... It will all make since once I see it and look at parts!
mjealey is offline
Old 11-23-2012, 06:48 PM
  #11995
rfleck's Avatar
Trader Rating: 58 (100%+)
Originally Posted by AZRC4Me
If anyone is on the fence about getting a TKI3, they're listed on Amain's Pre Black Friday special page. I got the email, and they're listed at 799. Doesn't get much better than that. Special pricing starts tomorrow at 5am pst.
Pre Black Friday Specials
Regarding the shaft lengths, I think everyone must run them differently . Some guys like Marty Korn run 93mm all the way around, I run 93/91 f/r, Cody runs the same, some guys run 91s all the way around, and apparently some guys run 91/93 f/r! Some guys even run the MP7.5 shafts, and I've heard of guys running the 777 shafts too. The only thing I can say for certain is I've never seen 93s pop out, but I've never seen 91s pop out of the rear either. This is with the narrow track width in the rear. If you run 91s anywhere, be sure to put the shims on first, then install the shaft. 93s, you install the shaft, then add the shims.
Hard to resist, plunge taken
rfleck is offline
Old 11-23-2012, 07:54 PM
  #11996
losi68's Avatar
You will not beleave the setup options this car has!!! The master mind behide this buggy no other buggy comes close!!! Pay close attention building it ....Your gonna love this buggy ..I put stock set up in my buggy first to see how it handled before chaging it!!!I am still running it ...
losi68 is offline
Old 11-23-2012, 10:39 PM
  #11997
AZRC4Me's Avatar
Ok, there's two types of rear hubs. There's a "standard" set, which were standard on the earlier MP9 kits:
IFW410
And these are the 2mm offset hubs which are now standard in the MP9 TKI3 kits:
IFW414
I believe the kits come with these in the rear for wheel hexes:
IFW326GM
They're 1mm narrower than the ones in the front, which are these:
IFW107GM
We typically run the IFW107s in the rear as well as front. The narrower hubs will help lock the rear in a little bit more. Hope that clears it up a bit for you.
AZRC4Me is offline
Old 11-24-2012, 05:05 AM
  #11998
mjealey's Avatar
IFW410
IFW414
IFW326GM
IFW107GM
Ok, thanks Sean. It is all making sense now. I downloaded the manual and setup sheets and it made everything come together. I get it now. I guess I will also order IFW107 hubs and I should be golden! Thanks for the help!
mjealey is offline
Old 11-24-2012, 05:25 AM
  #11999
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
IFW410
IFW414
IFW326GM
IFW107GM
So you prefer the longer "front" hexes all around, as opposed to the included "narrow" rear hexes that are standard on the tki2/3?
hookem34 is offline
Old 11-24-2012, 08:05 AM
  #12000
AZRC4Me's Avatar
For sure, that's what I use as my default base setup.
AZRC4Me is offline
