Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 11-14-2012, 06:11 PM
  #11911
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Originally Posted by nacho_gas
New Kanai options today
Wide Hub (Front)
http://buggysrc.blogspot.com.es/2012...el-kyosho.html
Seems clear to me that they are really trying to give the car a more "European feel" to best suit the track in Argentina. Wider hubs and added unsprung weight really benefit a flowing, high speed track with lots of shallow angle/high speed turns and high grip.
Everything looks tip top and K-Car Klassy
hookem34 is offline
Old 11-14-2012, 09:23 PM
  #11912
AZRC4Me's Avatar
Think "stability, predictability".
The grey springs are dialed, we've been running them a lot on higher bite tracks down here lately. Seems to balance the car out a little better.
AZRC4Me is offline
Old 11-14-2012, 10:17 PM
  #11913
losi68's Avatar
Are you running the grey springs all the way around?
losi68 is offline
Old 11-14-2012, 11:12 PM
  #11914
AZRC4Me's Avatar
no, they don't make grey springs for the rear.
AZRC4Me is offline
Old 11-14-2012, 11:45 PM
  #11915
pointforward's Avatar
What i'd really like to see from Kyosho are replacement pins for drive shafts.
pointforward is offline
Old 11-15-2012, 01:07 AM
  #11916
Trader Rating: 25 (100%+)
Keep dreaming.....Kyosho make great cars but they are also unscrupulous business people who make odd size pins so we spend money buying whole drive shafts. That is also the reason for the 91 and 93 axles when 92mm would work on the front and rear with all the common suspension settings.
I realize that may be a bit harsh but what other reason is there?
smelly62 is offline
Old 11-15-2012, 04:40 AM
  #11917
hookem34's Avatar
Are you havinging to go up in oil wt when using? 700-750 ish CST?
hookem34 is offline
Old 11-15-2012, 09:22 AM
  #11918
Is it fair to say to run the 93 mm all the way around instead of the 91 mm or is it just preference? Addtionally glad to be back to the "K" car!
C. Nutz is offline
Old 11-15-2012, 10:43 AM
  #11919
AZRC4Me's Avatar
Not really, mainly due to the weather. It's a little colder here now, so what once was 600-650 now feels like 700ish. In warmer weather it'd be worth it to experiment with small incremental increases in shock oil viscosity.
I would only run the 93s up front, if you run them in the rear with the narrow track width, they'll likely bottom out in the diff cups under full compression.
AZRC4Me is offline
Old 11-15-2012, 10:51 AM
  #11920
Energyzer's Avatar
Isn't the unsprung weight supposed to add more grip on low grip conditions?! The track in Argentina seems to be everything but a high grip one...
Correct me if i'm wrong!
Energyzer is offline
Old 11-15-2012, 11:56 AM
  #11921
Shh
Soapy is offline
Old 11-15-2012, 12:29 PM
  #11922
hookem34's Avatar
If the wheels (and other unsprung bits) have less inertia, the suspension reacts faster to bumps meaning the wheels stay in contact with the road better.
So adding more weight increases the inertia needed to make the suspension react, thus smoothing out the cars reactions.
hookem34 is offline
Old 11-15-2012, 01:55 PM
  #11923
Energyzer's Avatar
But more weight on the wheels (or as near to them as possible) should help keeping them in contact with the track, thus giving you more overall traction. I guess...
Isn't the advantage of unsprung weight, related to the fact that, when the buggy turns, it leans to one of the sides making the chassis roll. The more weight you have the more the chassis will roll (more or less, because you have other variables involved). Isn't it so? And since those weights are not "connected" to the suspension they won't make the chassis roll/wash out. Right?
Old 11-15-2012, 02:53 PM
  #11924
Interesting how the unsprung weight debate has come full circle.
I need a couple Kyosho guys who are willing to volunteer to test a couple products. Must run MP9 or ST-RR and must run the stock Kyosho clutch and stock Kyosho shoes. IM me if interested...and must be planning to practice or race sometime in the next week or so. Thanks!
lknracer is offline
Old 11-15-2012, 05:15 PM
  #11925
My take on this inertia thing is that the tyre is forced to comform to the surface of the track rather than have the suspension react thereby creating a more consistant contact patch between the tyre and the surface.
smelly62 is offline
