Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 11-11-2012, 11:20 PM
  #11836
Just finished building my TKI3. Must say, has to be the worst instructions manual and setup sheets of all the modern buggies i have built.
Guess i will run in the diffs and re-shim them tomorrow, just a very slight notch on them.
RePeTe is offline
Old 11-11-2012, 11:22 PM
  #11837
Obligatory fresh build picture.
RePeTe is offline
Old 11-12-2012, 12:04 AM
  #11838
Trader Rating: 40 (100%+)
Holy shit that was fast.
BrakeTurnAccelerate is offline
Old 11-12-2012, 04:06 AM
  #11839
McD44's Avatar
Trader Rating: 16 (100%+)
Just found the need to buy more front a-arms. I did some research in this thread about boiling the plastic parts and it seems that it was recommended a few hundred pages ago. Is that still the consensus?
McD44 is offline
Old 11-12-2012, 07:12 AM
  #11840
juninho_foz's Avatar
MP9 TKI3 joining the team, leaving the MBX6R did .. right? kkkkk
juninho_foz is offline
Old 11-12-2012, 07:44 AM
  #11841
Trader Rating: 25 (100%+)
The latest WC front arms are better but not indestructable. Also the 777 arms can be made to fit, I haven't done it but Jerome Agoine from France has done it. The 777 arms are strong as. Both my son and I raced 777 since they came out until they were replaced by the MP9 and we never broke a front arm, broke everything around them but never the arm.
smelly62 is offline
Old 11-12-2012, 09:25 AM
  #11842
mrpw23's Avatar
Default Conversion question
I'm looking to convert my TKi2 for the winter.
Which conversion kit should I use?
Kyosho or Tekno?
Thanks for any advice.
PW
mrpw23 is offline
Old 11-12-2012, 09:47 AM
  #11843
HH
HH's Avatar
Originally Posted by evolution03
I hate keeping a watch on my droop because of the droop screws digging in the chassis.
I've used these Losi Droop Screw "strikes" on several different chassis. They will usually last longer than your chassis, but if not, they are replaceable. You'll just need to drill and tap for #4-40 thread where the droop screws make contact with your chassis then screw them in from the top side of the chassis with some red loctite.
Using spacers in your shocks to limit downtravel as a replacement for droop screws is a very bad idea in 1:8 scale IMO. This method is common for 1:10 scale but it puts too much stress on the shocks in 1:8. You could possibly use shock limiters in addition to droop screws (although I wouldn't) to control your droop settings. Either way you should always set your droop so the load is on the droop screws and not your shocks.
HH is offline
Old 11-12-2012, 03:13 PM
  #11844
KWT-NITRO's Avatar
Hey guys,
A small question here! Are the rear hubs that come with the TKI3 kit the +2mm ones?
I have the +2mm on my TKI2 with 93 shafts
Now am building my new TKI3 and also put the 93 shafts but they seem to be sittin deeper in the outdrive than my other MP9 !!!
Cheers
Ali
KWT-NITRO is offline
Old 11-12-2012, 04:09 PM
  #11845
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Originally Posted by KWT-NITRO
Hey guys,
Cheers
Ali
they are the same.
hookem34 is offline
Old 11-12-2012, 04:46 PM
  #11846
is yours done yet?
RePeTe is offline
Old 11-12-2012, 05:33 PM
  #11847
is yours done yet?
Waiting on servos & then a bunch of pics, but yea..
Old 11-12-2012, 06:42 PM
  #11848
Hey guys,
Cheers
Ali
HaHa one day hopefully not too far in the future Kyosho will do the right thing by us poor MP9 owners and start making 92mm axles. I reckon they would make massive sales for the item if they did.
smelly62 is offline
Old 11-12-2012, 07:12 PM
  #11849
Guest
Default THE GREAT KANAI
KANAI HAS
LOSIRACER77 is offline
Old 11-12-2012, 07:34 PM
  #11850
nacho_gas's Avatar
Originally Posted by LOSIRACER77
KANAI HAS POSTED SOME NEW PARTS ON FACE BOOK
I GUESS THEY R WEIGHTS?????
More options for MP9
weights to the front Knuckle Arm and Rear Hub
Front Knuckle Arm
-IFW437 10gr
-IFW437 15gr
Rear Hub
-IFW438 10gr
-IFW438 15gr
You can see this link
http://buggysrc.blogspot.com.es/2012...yosho-mp9.html
nacho_gas is offline
